Exception Handling for Linux
Sysprogs forums Forums VisualGDB Exception Handling for Linux
  • #6812
    pedley
    Please excuse a fairly basic question by a refugee from Windows C#, needing to program a control system in C++ on a Raspberry Pi. I am evaluating VGDB, using VGDB on VS2012 under Win7 with the cross-compiler and then running on the Pi. After a bit of a struggle, everything appears to be working OK.
    This is probably as much a question about GDB than VGDB but I shall appreciate any help available.
    As one of the first basic steps I am trying to test a custom exception handler to be used throughout the system. (V)GDB appears to issue a signal and stops execution whenever a system exception occurs and control flow never reaches the C++ exception handler, even after clicking ‘Continue’. What I need is for the program to handle all exceptions it is capable of catching without interruption ie using the c++ catch {} rather than stopping on signals.
    How to achieve this with VGDB, please (basic steps will be appreciated)? I presumably have a full version for evaluation. Will these steps be available from the Linux version?
    Help much appreciated.
    #6813
    Normally “continue” should work. If it does not, please try clicking the “signals” tool button in the GDB Session window. This will open a GDB-specific dialog with GDB signals allowing you to change their handling. If this does not help, please let us know a specific signal that is not working and send us a full GDB log (obtained by enabling debug logging on the GDB Settings page of VisualGDB Project Properties).
