Evaluating VisualGDB
Sysprogs forums Forums VisualGDB Evaluating VisualGDB
  • #981
    mhs
    I’m new here and I want start with VisualGDB in VS2013.
    So far so good…
    I’m using the m68kelf toolchain and the first what I had to say no devices possible in this case.
    It’s correct ?
    Normaly I can start gdb following:
    m68k-elf-gdb remote target|m68k-elf-sprite pe://USBMultilink/ m5235evb
    In commandline it’s working fine.
    But if I start the debug session in VS the first command -list-Features is unknown.
    How I have to adjust the debug session ?
    Thx a lot.
    Michael
    #5844
    As m68k devices are not as popular as the ARM ones, we don’t provide fully-automatic wizard templates. Instead you can follow the legacy device tutorial to specify the flags manually.
    In order to get debugging to work please add the “-interpreter mi” argument to GDB command line (or use the ‘custom GDB stub’ mode if you want VisualGDB to set the command line arguments automatically).
    • This reply was modified 11 years ago by support.
