Sysprogs forums › Forums › VisualGDB › esptool.py Error
- This topic has 1 reply, 2 voices, and was last updated 5 years, 11 months ago by
May 10, 2020 at 14:58 #28094
ilkerdagli
Participant<div>
Hello, i can’t start my project. Please help me.
C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe flash
[1/735] Building C object xtensa-debug-module/CMakeFiles/xtensa-debug-module.dir/eri.c.obj
[2/735] Building C object xtensa-debug-module/CMakeFiles/xtensa-debug-module.dir/trax.c.obj
[3/735] Building C object app_trace/CMakeFiles/app_trace.dir/host_file_io.c.obj
[4/735] Building C object freertos/CMakeFiles/freertos.dir/FreeRTOS-openocd.c.obj
[5/735] Building C object app_trace/CMakeFiles/app_trace.dir/app_trace.c.obj
[6/735] Building C object app_trace/CMakeFiles/app_trace.dir/gcov/gcov_rtio.c.obj
[7/735] Building C object freertos/CMakeFiles/freertos.dir/list.c.obj
[8/735] Building C object app_trace/CMakeFiles/app_trace.dir/app_trace_util.c.obj
[9/735] Building C object freertos/CMakeFiles/freertos.dir/croutine.c.obj
[10/735] Building ASM object freertos/CMakeFiles/freertos.dir/portasm.S.obj
[11/735] Building C object freertos/CMakeFiles/freertos.dir/queue.c.obj
[12/735] Building ASM object freertos/CMakeFiles/freertos.dir/xtensa_context.S.obj
[13/735] Linking C static library xtensa-debug-module\libxtensa-debug-module.a
[14/735] Building ASM object freertos/CMakeFiles/freertos.dir/xtensa_intr_asm.S.obj
[15/735] Building C object freertos/CMakeFiles/freertos.dir/xtensa_init.c.obj
[16/735] Linking C static library app_trace\libapp_trace.a
[17/735] Building C object freertos/CMakeFiles/freertos.dir/event_groups.c.obj
[18/735] Building C object freertos/CMakeFiles/freertos.dir/port.c.obj
[19/735] Building C object freertos/CMakeFiles/freertos.dir/xtensa_intr.c.obj
[20/735] Building ASM object freertos/CMakeFiles/freertos.dir/xtensa_vector_defaults.S.obj
[21/735] Building ASM object freertos/CMakeFiles/freertos.dir/xtensa_vectors.S.obj
[22/735] Building C object freertos/CMakeFiles/freertos.dir/timers.c.obj
[23/735] Building C object freertos/CMakeFiles/freertos.dir/xtensa_overlay_os_hook.c.obj
[24/735] Building C object newlib/CMakeFiles/newlib.dir/random.c.obj
[25/735] Building C object newlib/CMakeFiles/newlib.dir/pthread.c.obj
[26/735] Building C object newlib/CMakeFiles/newlib.dir/reent_init.c.obj
[27/735] Building C object newlib/CMakeFiles/newlib.dir/locks.c.obj
[28/735] Building C object vfs/CMakeFiles/vfs.dir/vfs_uart.c.obj
[29/735] Building C object freertos/CMakeFiles/freertos.dir/tasks.c.obj
[30/735] Building C object newlib/CMakeFiles/newlib.dir/termios.c.obj
[31/735] Building C object newlib/CMakeFiles/newlib.dir/select.c.obj
[32/735] Building C object newlib/CMakeFiles/newlib.dir/syscall_table.c.obj
[33/735] Building C object newlib/CMakeFiles/newlib.dir/syscalls.c.obj
[34/735] Building C object vfs/CMakeFiles/vfs.dir/vfs.c.obj
[35/735] Building C object newlib/CMakeFiles/newlib.dir/time.c.obj
[36/735] Linking C static library freertos\libfreertos.a
[37/735] Linking C static library vfs\libvfs.a
[38/735] Building C object driver/CMakeFiles/driver.dir/can.c.obj
[39/735] Building C object driver/CMakeFiles/driver.dir/gpio.c.obj
[40/735] Linking C static library newlib\libnewlib.a
[41/735] Building C object esp_ringbuf/CMakeFiles/esp_ringbuf.dir/ringbuf.c.obj
[42/735] Building C object driver/CMakeFiles/driver.dir/periph_ctrl.c.obj
[43/735] Building C object driver/CMakeFiles/driver.dir/ledc.c.obj
[44/735] Building C object driver/CMakeFiles/driver.dir/i2c.c.obj
[45/735] Building C object driver/CMakeFiles/driver.dir/rmt.c.obj
[46/735] Building C object driver/CMakeFiles/driver.dir/i2s.c.obj
[47/735] Building C object driver/CMakeFiles/driver.dir/pcnt.c.obj
[48/735] Building C object driver/CMakeFiles/driver.dir/mcpwm.c.obj
[49/735] Building C object driver/CMakeFiles/driver.dir/sdspi_crc.c.obj
[50/735] Building C object driver/CMakeFiles/driver.dir/sdspi_transaction.c.obj
[51/735] Building C object driver/CMakeFiles/driver.dir/sdspi_host.c.obj
[52/735] Building C object driver/CMakeFiles/driver.dir/sdmmc_transaction.c.obj
[53/735] Linking C static library esp_ringbuf\libesp_ringbuf.a
[54/735] Building C object driver/CMakeFiles/driver.dir/sdmmc_host.c.obj
[55/735] Building C object driver/CMakeFiles/driver.dir/rtc_module.c.obj
[56/735] Building C object driver/CMakeFiles/driver.dir/sigmadelta.c.obj
[57/735] Building C object driver/CMakeFiles/driver.dir/sdio_slave.c.obj
[58/735] Building C object esp_event/CMakeFiles/esp_event.dir/esp_event_private.c.obj
[59/735] Building C object ethernet/CMakeFiles/ethernet.dir/emac_dev.c.obj
[60/735] Building C object esp_event/CMakeFiles/esp_event.dir/esp_event.c.obj
[61/735] Building C object driver/CMakeFiles/driver.dir/spi_slave.c.obj
[62/735] Building C object esp_event/CMakeFiles/esp_event.dir/default_event_loop.c.obj
[63/735] Building C object driver/CMakeFiles/driver.dir/timer.c.obj
[64/735] Building C object driver/CMakeFiles/driver.dir/spi_common.c.obj
[65/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/inet_chksum.c.obj
[66/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/init.c.obj
[67/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/mem.c.obj
[68/735] Building C object driver/CMakeFiles/driver.dir/spi_master.c.obj
[69/735] Linking C static library esp_event\libesp_event.a
[70/735] Building C object ethernet/CMakeFiles/ethernet.dir/eth_phy/phy_lan8720.c.obj
[71/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/memp.c.obj
[72/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/netif.c.obj
[73/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ip.c.obj
[74/735] Building C object ethernet/CMakeFiles/ethernet.dir/eth_phy/phy_tlk110.c.obj
[75/735] Building C object ethernet/CMakeFiles/ethernet.dir/eth_phy/phy_common.c.obj
[76/735] Building C object driver/CMakeFiles/driver.dir/uart.c.obj
[77/735] Building C object ethernet/CMakeFiles/ethernet.dir/emac_main.c.obj
[78/735] Building C object lwip/CMakeFiles/lwip.dir/apps/ping/esp_ping.c.obj
[79/735] Building C object lwip/CMakeFiles/lwip.dir/apps/dhcpserver/dhcpserver.c.obj
[80/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/netifapi.c.obj
[81/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/api_lib.c.obj
[82/735] Linking C static library driver\libdriver.a
[83/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/err.c.obj
[84/735] Building C object lwip/CMakeFiles/lwip.dir/apps/ping/ping.c.obj
[85/735] Linking C static library ethernet\libethernet.a
[86/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/api_msg.c.obj
[87/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/netbuf.c.obj
[88/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/netdb.c.obj
[89/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/tcpip.c.obj
[90/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/def.c.obj
[91/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/dns.c.obj
[92/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/apps/sntp/sntp.c.obj
[93/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/stats.c.obj
[94/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/sys.c.obj
[95/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/api/sockets.c.obj
[96/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/tcp_in.c.obj
[97/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/raw.c.obj
[98/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/autoip.c.obj
[99/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/timeouts.c.obj
[100/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/pbuf.c.obj
[101/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/tcp.c.obj
[102/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/etharp.c.obj
[103/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/udp.c.obj
[104/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/dhcp.c.obj
[105/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/ip4_addr.c.obj
[106/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/ip4.c.obj
[107/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/ip4_frag.c.obj
[108/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/tcp_out.c.obj
[109/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/igmp.c.obj
[110/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv4/icmp.c.obj
[111/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/ip6_addr.c.obj
[112/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/dhcp6.c.obj
[113/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/inet6.c.obj
[114/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/icmp6.c.obj
[115/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/ethip6.c.obj
[116/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/ip6.c.obj
[117/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/pppol2tp.c.obj
[118/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/ip6_frag.c.obj
[119/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/mld6.c.obj
[120/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/upap.c.obj
[121/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/pppoe.c.obj
[122/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/pppapi.c.obj
[123/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/pppos.c.obj
[124/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/pppcrypt.c.obj
[125/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/ccp.c.obj
[126/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/core/ipv6/nd6.c.obj
[127/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ethernetif.c.obj
[128/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ethernet.c.obj
[129/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/ecp.c.obj
[130/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/auth.c.obj
[131/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/lowpan6.c.obj
[132/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/slipif.c.obj
[133/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/eap.c.obj
[134/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/chap_ms.c.obj
[135/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/demand.c.obj
[136/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/chap-new.c.obj
[137/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/chap-md5.c.obj
[138/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/lcp.c.obj
[139/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/eui64.c.obj
[140/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/magic.c.obj
[141/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/ipv6cp.c.obj
[142/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/mppe.c.obj
[143/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/fsm.c.obj
[144/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/ipcp.c.obj
[145/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/multilink.c.obj
[146/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/ppp.c.obj
[147/735] Generating linker script…
[148/735] Building C object esp_http_client/CMakeFiles/esp_http_client.dir/lib/http_utils.c.obj
[149/735] Building C object esp_http_client/CMakeFiles/esp_http_client.dir/lib/http_header.c.obj
[150/735] Building C object jsmn/CMakeFiles/jsmn.dir/src/jsmn.c.obj
[151/735] Building CXX object cxx/CMakeFiles/cxx.dir/cxx_exception_stubs.cpp.obj
[152/735] Building C object esp_http_server/CMakeFiles/esp_http_server.dir/src/httpd_main.c.obj
[153/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/async.c.obj
[154/735] Building C object esp_http_server/CMakeFiles/esp_http_server.dir/src/httpd_parse.c.obj
[155/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/address.c.obj
[156/735] Linking C static library jsmn\libjsmn.a
[157/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/coap_time.c.obj
[158/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/block.c.obj
[159/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/hashkey.c.obj
[160/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/encode.c.obj
[161/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/option.c.obj
[162/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/mem.c.obj
[163/735] Building CXX object cxx/CMakeFiles/cxx.dir/cxx_guards.cpp.obj
[164/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/pdu.c.obj
[165/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/debug.c.obj
[166/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/subscribe.c.obj
[167/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/str.c.obj
[168/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/net.c.obj
[169/735] Building C object console/CMakeFiles/console.dir/split_argv.c.obj
[170/735] Linking CXX static library cxx\libcxx.a
[171/735] Building C object console/CMakeFiles/console.dir/commands.c.obj
[172/735] Building C object coap/CMakeFiles/coap.dir/port/coap_io_socket.c.obj
[173/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/uri.c.obj
[174/735] Building C object console/CMakeFiles/console.dir/linenoise/linenoise.c.obj
[175/735] Building C object coap/CMakeFiles/coap.dir/libcoap/src/resource.c.obj
[176/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_debug.c.obj
[177/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_callbacks.c.obj
[178/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_buf.c.obj
[179/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_hd_huffman_data.c.obj
[180/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_hd_huffman.c.obj
[181/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_http.c.obj
[182/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_map.c.obj
[183/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_frame.c.obj
[184/735] Linking C static library coap\libcoap.a
[185/735] Building C object console/CMakeFiles/console.dir/argtable3/argtable3.c.obj
[186/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_option.c.obj
[187/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_helper.c.obj
[188/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_npn.c.obj
[189/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_outbound_item.c.obj
[190/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_pq.c.obj
[191/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_mem.c.obj
[192/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_priority_spec.c.obj
[193/735] Linking C static library console\libconsole.a
[194/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_hd.c.obj
[195/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_rcbuf.c.obj
[196/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_queue.c.obj
[197/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_submit.c.obj
[198/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_version.c.obj
[199/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_stream.c.obj
[200/735] Building C object tcp_transport/CMakeFiles/tcp_transport.dir/transport.c.obj
[201/735] Building C object esp_adc_cal/CMakeFiles/esp_adc_cal.dir/esp_adc_cal.c.obj
[202/735] Building C object tcp_transport/CMakeFiles/tcp_transport.dir/transport_ws.c.obj
[203/735] Building C object tcp_transport/CMakeFiles/tcp_transport.dir/transport_ssl.c.obj
[204/735] Building C object esp-tls/CMakeFiles/esp-tls.dir/esp_tls.c.obj
[205/735] Generating dummy_main_src.c
[206/735] Building C object tcp_transport/CMakeFiles/tcp_transport.dir/transport_utils.c.obj
[207/735] Building C object nghttp/CMakeFiles/nghttp.dir/port/http_parser.c.obj
[208/735] Building C object tcp_transport/CMakeFiles/tcp_transport.dir/transport_tcp.c.obj
[209/735] Linking C static library esp_adc_cal\libesp_adc_cal.a
[210/735] Building C object esp_http_client/CMakeFiles/esp_http_client.dir/lib/http_auth.c.obj
[211/735] Building C object soc/CMakeFiles/soc.dir/esp32/gpio_periph.c.obj
[212/735] Linking C static library esp-tls\libesp-tls.a
[213/735] Building C object esp_http_client/CMakeFiles/esp_http_client.dir/esp_http_client.c.obj
[214/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_periph.c.obj
[215/735] Building C object soc/CMakeFiles/soc.dir/esp32/cpu_util.c.obj
[216/735] Building C object nghttp/CMakeFiles/nghttp.dir/nghttp2/lib/nghttp2_session.c.obj
[217/735] Linking C static library tcp_transport\libtcp_transport.a
[218/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_init.c.obj
[219/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_pm.c.obj
[220/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_time.c.obj
[221/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_clk_init.c.obj
[222/735] Linking C static library esp_http_client\libesp_http_client.a
[223/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_clk.c.obj
[224/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_sleep.c.obj
[225/735] Linking C static library nghttp\libnghttp.a
[226/735] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_wdt.c.obj
[227/735] Building C object soc/CMakeFiles/soc.dir/esp32/sdmmc_periph.c.obj
[228/735] Building C object soc/CMakeFiles/soc.dir/esp32/sdio_slave_periph.c.obj
[229/735] Building C object soc/CMakeFiles/soc.dir/esp32/soc_memory_layout.c.obj
[230/735] Building C object soc/CMakeFiles/soc.dir/esp32/spi_periph.c.obj
[231/735] Building C object soc/CMakeFiles/soc.dir/src/memory_layout_utils.c.obj
[232/735] Building C object log/CMakeFiles/log.dir/log.c.obj
[233/735] Building C object heap/CMakeFiles/heap.dir/heap_caps_init.c.obj
[234/735] Building C object heap/CMakeFiles/heap.dir/heap_trace.c.obj
[235/735] Building C object heap/CMakeFiles/heap.dir/heap_caps.c.obj
[236/735] Linking C static library soc\libsoc.a
[237/735] Building C object esp_http_server/CMakeFiles/esp_http_server.dir/src/httpd_uri.c.obj
[238/735] Linking C static library log\liblog.a
[239/735] Building C object heap/CMakeFiles/heap.dir/multi_heap.c.obj
[240/735] Building C object esp_http_server/CMakeFiles/esp_http_server.dir/src/util/ctrl_sock.c.obj
[241/735] Building C object expat/CMakeFiles/expat.dir/expat/expat/lib/loadlibrary.c.obj
[242/735] Building C object expat/CMakeFiles/expat.dir/expat/expat/lib/xmltok_ns.c.obj
[243/735] Building C object esp_http_server/CMakeFiles/esp_http_server.dir/src/httpd_txrx.c.obj
[244/735] Building C object expat/CMakeFiles/expat.dir/expat/expat/lib/xmltok_impl.c.obj
[245/735] Building C object esp_https_ota/CMakeFiles/esp_https_ota.dir/src/esp_https_ota.c.obj
[246/735] Linking C static library heap\libheap.a
[247/735] Building C object esp_http_server/CMakeFiles/esp_http_server.dir/src/httpd_sess.c.obj
[248/735] Building CXX object asio/CMakeFiles/asio.dir/asio/asio/src/asio.cpp.obj
[249/735] Building C object expat/CMakeFiles/expat.dir/expat/expat/lib/xmlrole.c.obj
[250/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/Partition.cpp.obj
[251/735] Linking C static library esp_https_ota\libesp_https_ota.a
[252/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/WL_Ext_Perf.cpp.obj
[253/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/SPI_Flash.cpp.obj
[254/735] Linking C static library esp_http_server\libesp_http_server.a
[255/735] Linking CXX static library asio\libasio.a
[256/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/crc32.cpp.obj
[257/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/WL_Ext_Safe.cpp.obj
[258/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/WL_Flash.cpp.obj
[259/735] Building CXX object wear_levelling/CMakeFiles/wear_levelling.dir/wear_levelling.cpp.obj
[260/735] Building C object sdmmc/CMakeFiles/sdmmc.dir/sdmmc_common.c.obj
[261/735] Building C object sdmmc/CMakeFiles/sdmmc.dir/sdmmc_cmd.c.obj
[262/735] Building C object sdmmc/CMakeFiles/sdmmc.dir/sdmmc_init.c.obj
[263/735] Building C object sdmmc/CMakeFiles/sdmmc.dir/sdmmc_io.c.obj
[264/735] Building C object sdmmc/CMakeFiles/sdmmc.dir/sdmmc_mmc.c.obj
[265/735] Building C object sdmmc/CMakeFiles/sdmmc.dir/sdmmc_sd.c.obj
[266/735] Linking CXX static library wear_levelling\libwear_levelling.a
[267/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/diskio_wl.c.obj
[268/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/diskio_sdmmc.c.obj
[269/735] Building C object expat/CMakeFiles/expat.dir/expat/expat/lib/xmlparse.c.obj
[270/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/diskio.c.obj
[271/735] Linking C static library sdmmc\libsdmmc.a
[272/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/diskio_rawflash.c.obj
[273/735] Building C object expat/CMakeFiles/expat.dir/expat/expat/lib/xmltok.c.obj
[274/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/vfs_fat_sdmmc.c.obj
[275/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbfuncdiag.c.obj
[276/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/ff.c.obj
[277/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/ffunicode.c.obj
[278/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/ffsystem.c.obj
[279/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/rtu/mbcrc.c.obj
[280/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbfunccoils.c.obj
[281/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/vfs_fat_spiflash.c.obj
[282/735] Linking C static library expat\libexpat.a
[283/735] Building C object fatfs/CMakeFiles/fatfs.dir/src/vfs_fat.c.obj
[284/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/ascii/mbascii.c.obj
[285/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbfuncother.c.obj
[286/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbfuncinput.c.obj
[287/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbfuncholding.c.obj
[288/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/rtu/mbrtu.c.obj
[289/735] Linking C static library fatfs\libfatfs.a
[290/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/port/portother.c.obj
[291/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbfuncdisc.c.obj
[292/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/functions/mbutils.c.obj
[293/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/port/portserial.c.obj
[294/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/port/porttimer.c.obj
[295/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/port/portevent.c.obj
[296/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/tcp/mbtcp.c.obj
[297/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_aead/xchacha20poly1305/sodium/aead_xchacha20poly1305.c.obj
[298/735] Building C object json/CMakeFiles/json.dir/cJSON/test.c.obj
[299/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus/mb.c.obj
[300/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.obj
[301/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box.c.obj
[302/735] Building C object freemodbus/CMakeFiles/freemodbus.dir/modbus_controller/mbcontroller.c.obj
[303/735] Building C object json/CMakeFiles/json.dir/cJSON/cJSON_Utils.c.obj
[304/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_auth/crypto_auth.c.obj
[305/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_auth/hmacsha512/auth_hmacsha512.c.obj
[306/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_auth/hmacsha256/auth_hmacsha256.c.obj
[307/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_auth/hmacsha512256/auth_hmacsha512256.c.obj
[308/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_core/hchacha20/core_hchacha20.c.obj
[309/735] Building C object json/CMakeFiles/json.dir/cJSON/cJSON.c.obj
[310/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xsalsa20poly1305/box_curve25519xsalsa20poly1305.c.obj
[311/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box_seal.c.obj
[312/735] Linking C static library freemodbus\libfreemodbus.a
[313/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box_easy.c.obj
[314/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_core/hsalsa20/ref2/core_hsalsa20_ref2.c.obj
[315/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/generichash_blake2.c.obj
[316/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_curve25519xchacha20poly1305.c.obj
[317/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/crypto_generichash.c.obj
[318/735] Linking C static library json\libjson.a
[319/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-avx2.c.obj
[320/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_core/hsalsa20/core_hsalsa20.c.obj
[321/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_core/salsa/ref/core_salsa_ref.c.obj
[322/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ssse3.c.obj
[323/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-sse41.c.obj
[324/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.c.obj
[325/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.c.obj
[326/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_hash/crypto_hash.c.obj
[327/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_kdf/crypto_kdf.c.obj
[328/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_hash/sha512/hash_sha512.c.obj
[329/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_kdf/blake2b/kdf_blake2b.c.obj
[330/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_hash/sha256/hash_sha256.c.obj
[331/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_kx/crypto_kx.c.obj
[332/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.obj
[333/735] Building C object lwip/CMakeFiles/lwip.dir/port/esp32/vfs_lwip.c.obj
[334/735] Building C object lwip/CMakeFiles/lwip.dir/port/esp32/netif/ethernetif.c.obj
[335/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/utils.c.obj
[336/735] Building C object lwip/CMakeFiles/lwip.dir/lwip/src/netif/ppp/vj.c.obj
[337/735] Building C object lwip/CMakeFiles/lwip.dir/port/esp32/debug/lwip_debug.c.obj
[338/735] Building C object lwip/CMakeFiles/lwip.dir/port/esp32/netif/wlanif.c.obj
[339/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_hash/sha512/cp/hash_sha512_cp.c.obj
[340/735] Building C object lwip/CMakeFiles/lwip.dir/port/esp32/freertos/sys_arch.c.obj
[341/735] Building C object spi_flash/CMakeFiles/spi_flash.dir/spi_flash_rom_patch.c.obj
[342/735] Building C object app_update/CMakeFiles/app_update.dir/esp_ota_ops.c.obj
[343/735] Building C object spi_flash/CMakeFiles/spi_flash.dir/cache_utils.c.obj
[344/735] Generating partition-table.bin
[345/735] Building C object spi_flash/CMakeFiles/spi_flash.dir/flash_mmap.c.obj
[346/735] Linking C static library lwip\liblwip.a
[347/735] Building C object spi_flash/CMakeFiles/spi_flash.dir/flash_ops.c.obj
[348/735] Linking C static library app_update\libapp_update.a
[349/735] Building C object spi_flash/CMakeFiles/spi_flash.dir/partition.c.obj
[350/735] Building C object tcpip_adapter/CMakeFiles/tcpip_adapter.dir/tcpip_adapter_lwip.c.obj
[351/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/aesni.c.obj
[352/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/aria.c.obj
[353/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/aes.c.obj
[354/735] Linking C static library tcpip_adapter\libtcpip_adapter.a
[355/735] Linking C static library spi_flash\libspi_flash.a
[356/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/arc4.c.obj
[357/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/asn1write.c.obj
[358/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/blowfish.c.obj
[359/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/base64.c.obj
[360/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/chachapoly.c.obj
[361/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/asn1parse.c.obj
[362/735] Creating directories for ‘bootloader’
[363/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/certs.c.obj
[364/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/chacha20.c.obj
[365/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/cmac.c.obj
[366/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/cipher.c.obj
[367/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ccm.c.obj
[368/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/camellia.c.obj
[369/735] No download step for ‘bootloader’
[370/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/bignum.c.obj
[371/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_core/curve25519/ref10/curve25519_ref10.c.obj
[372/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/debug.c.obj
[373/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ecdh.c.obj
[374/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/des.c.obj
[375/735] No update step for ‘bootloader’
[376/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/cipher_wrap.c.obj
[377/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/dhm.c.obj
[378/735] No patch step for ‘bootloader’
[379/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ctr_drbg.c.obj
[380/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/entropy_poll.c.obj
[381/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ecjpake.c.obj
[382/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/hkdf.c.obj
[383/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ecdsa.c.obj
[384/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/entropy.c.obj
[385/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ecp_curves.c.obj
[386/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ecp.c.obj
[387/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/md.c.obj
[388/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/havege.c.obj
[389/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/gcm.c.obj
[390/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/nist_kw.c.obj
[391/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/hmac_drbg.c.obj
[392/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/md4.c.obj
[393/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/md2.c.obj
[394/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/net_sockets.c.obj
[395/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/memory_buffer_alloc.c.obj
[396/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/error.c.obj
[397/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/md5.c.obj
[398/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/md_wrap.c.obj
[399/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pk.c.obj
[400/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pkcs11.c.obj
[401/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/padlock.c.obj
[402/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pk_wrap.c.obj
[403/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/oid.c.obj
[404/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pem.c.obj
[405/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/platform_util.c.obj
[406/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/poly1305.c.obj
[407/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pkcs12.c.obj
[408/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/platform.c.obj
[409/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pkcs5.c.obj
[410/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pkwrite.c.obj
[411/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/sha1.c.obj
[412/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ripemd160.c.obj
[413/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/pkparse.c.obj
[414/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/rsa_internal.c.obj
[415/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/sha512.c.obj
[416/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ref.c.obj
[417/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_cache.c.obj
[418/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/sha256.c.obj
[419/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/rsa.c.obj
[420/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_ops.cpp.obj
[421/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_cookie.c.obj
[422/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_cli.c.obj
[423/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_ciphersuites.c.obj
[424/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_types.cpp.obj
[425/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_item_hash_list.cpp.obj
[426/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/timing.c.obj
[427/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/version_features.c.obj
[428/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_tls.c.obj
[429/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_pagemanager.cpp.obj
[430/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_storage.cpp.obj
[431/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_ticket.c.obj
[432/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_page.cpp.obj
[433/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/version.c.obj
[434/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509_create.c.obj
[435/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_srv.c.obj
[436/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/threading.c.obj
[437/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/xtea.c.obj
[438/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509.c.obj
[439/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509write_csr.c.obj
[440/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/esp_sha1.c.obj
[441/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/esp_sha512.c.obj
[442/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509_crl.c.obj
[443/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509_csr.c.obj
[444/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509write_crt.c.obj
[445/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/esp_bignum.c.obj
[446/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/mbedtls/library/x509_crt.c.obj
[447/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/esp_sha256.c.obj
[448/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/mbedtls_debug.c.obj
[449/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/esp_mem.c.obj
[450/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_clock.c.obj
[451/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/esp_hardware.c.obj
[452/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_flash.c.obj
[453/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_sha.c.obj
[454/735] Building C object mbedtls/CMakeFiles/mbedtls.dir/port/net_sockets.c.obj
[455/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_common.c.obj
[456/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/efuse.c.obj
[457/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_random.c.obj
[458/735] Building C object micro-ecc/CMakeFiles/micro-ecc.dir/micro-ecc/uECC.c.obj
[459/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/flash_partitions.c.obj
[460/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/esp_image_format.c.obj
[461/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/secure_boot_signatures.c.obj
[462/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/flash_encrypt.c.obj
[463/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_utility.c.obj
[464/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/flash_qio_mode.c.obj
[465/735] Linking C static library micro-ecc\libmicro-ecc.a
[466/735] Linking C static library mbedtls\libmbedtls.a
[467/735] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/secure_boot.c.obj
[468/735] Building C object pthread/CMakeFiles/pthread.dir/pthread_local_storage.c.obj
[469/735] Building C object pthread/CMakeFiles/pthread.dir/pthread_cond_var.c.obj
[470/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/port/os_xtensa.c.obj
[471/735] Linking C static library bootloader_support\libbootloader_support.a
[472/735] Building C object pthread/CMakeFiles/pthread.dir/pthread.c.obj
[473/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/aes-cbc.c.obj
[474/735] Building C object smartconfig_ack/CMakeFiles/smartconfig_ack.dir/smartconfig_ack.c.obj
[475/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/aes-unwrap.c.obj
[476/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/aes-internal-enc.c.obj
[477/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/aes-internal-dec.c.obj
[478/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/aes-wrap.c.obj
[479/735] Linking C static library pthread\libpthread.a
[480/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/aes-internal.c.obj
[481/735] Linking C static library smartconfig_ack\libsmartconfig_ack.a
[482/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_encr.cpp.obj
[483/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/crypto_internal-rsa.c.obj
[484/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/crypto_internal-cipher.c.obj
[485/735] Building CXX object nvs_flash/CMakeFiles/nvs_flash.dir/src/nvs_api.cpp.obj
[486/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/crypto_internal.c.obj
[487/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/crypto_internal-modexp.c.obj
[488/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/crypto_mbedtls.c.obj
[489/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/md4-internal.c.obj
[490/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/des-internal.c.obj
[491/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/dh_groups.c.obj
[492/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/md5-internal.c.obj
[493/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/bignum.c.obj
[494/735] Linking CXX static library nvs_flash\libnvs_flash.a
[495/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/md5.c.obj
[496/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/dh_group5.c.obj
[497/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/sha1.c.obj
[498/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/ms_funcs.c.obj
[499/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/sha1-internal.c.obj
[500/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/sha256-internal.c.obj
[501/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/rc4.c.obj
[502/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/sha1-pbkdf2.c.obj
[503/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_aes-unwrap.c.obj
[504/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_aes-wrap.c.obj
[505/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/crypto/sha256.c.obj
[506/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_aes-cbc.c.obj
[507/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/chap.c.obj
[508/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_crypto_internal-cipher.c.obj
[509/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_crypto_internal-modexp.c.obj
[510/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_sha256-internal.c.obj
[511/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_crypto_internal.c.obj
[512/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/fast_crypto/fast_sha256.c.obj
[513/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_common.c.obj
[514/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap.c.obj
[515/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_peap_common.c.obj
[516/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_mschapv2.c.obj
[517/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_tls.c.obj
[518/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_peap.c.obj
[519/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/pkcs1.c.obj
[520/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/asn1.c.obj
[521/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/pkcs5.c.obj
[522/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_tls_common.c.obj
[523/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/mschapv2.c.obj
[524/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/pkcs8.c.obj
[525/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/eap_peer/eap_ttls.c.obj
[526/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tls_internal.c.obj
[527/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/bignum.c.obj
[528/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_client_read.c.obj
[529/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/rsa.c.obj
[530/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_client.c.obj
[531/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_server.c.obj
[532/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_server_read.c.obj
[533/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_record.c.obj
[534/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_client_write.c.obj
[535/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/utils/ext_password.c.obj
[536/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_cred.c.obj
[537/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_common.c.obj
[538/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/utils/base64.c.obj
[539/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/tlsv1_server_write.c.obj
[540/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/eap_common.c.obj
[541/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/uuid.c.obj
[542/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wpa2/tls/x509v3.c.obj
[543/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_attr_process.c.obj
[544/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps.c.obj
[545/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_common.c.obj
[546/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_dev_attr.c.obj
[547/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_attr_parse.c.obj
[548/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_attr_build.c.obj
[549/735] Building C object esp32/CMakeFiles/esp32.dir/lib_printf.c.obj
[550/735] Building C object esp32/CMakeFiles/esp32.dir/ipc.c.obj
[551/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_enrollee.c.obj
[552/735] Building C object esp32/CMakeFiles/esp32.dir/hw_random.c.obj
[553/735] Building C object esp32/CMakeFiles/esp32.dir/phy_init.c.obj
[554/735] Building C object esp32/CMakeFiles/esp32.dir/int_wdt.c.obj
[555/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_validate.c.obj
[556/735] Building C object esp32/CMakeFiles/esp32.dir/intr_alloc.c.obj
[557/735] Building C object wpa_supplicant/CMakeFiles/wpa_supplicant.dir/src/wps/wps_registrar.c.obj
[558/735] Building C object esp32/CMakeFiles/esp32.dir/reset_reason.c.obj
[559/735] Building C object esp32/CMakeFiles/esp32.dir/restore.c.obj
[560/735] Building C object esp32/CMakeFiles/esp32.dir/pm_esp32.c.obj
[561/735] Building C object esp32/CMakeFiles/esp32.dir/pm_locks.c.obj
[562/735] Building C object esp32/CMakeFiles/esp32.dir/panic.c.obj
[563/735] Building C object esp32/CMakeFiles/esp32.dir/pm_trace.c.obj
[564/735] Building C object esp32/CMakeFiles/esp32.dir/task_wdt.c.obj
[565/735] Building C object esp32/CMakeFiles/esp32.dir/spiram_psram.c.obj
[566/735] Building C object esp32/CMakeFiles/esp32.dir/sleep_modes.c.obj
[567/735] Building C object esp32/CMakeFiles/esp32.dir/stack_check.c.obj
[568/735] Building C object esp32/CMakeFiles/esp32.dir/wifi_init.c.obj
[569/735] Building C object esp32/CMakeFiles/esp32.dir/spiram.c.obj
[570/735] Building C object CMakeFiles/hello-world.elf.dir/dummy_main_src.c.obj
[571/735] Building C object esp32/CMakeFiles/esp32.dir/wifi_os_adapter.c.obj
[572/735] Building C object esp32/CMakeFiles/esp32.dir/system_api.c.obj
[573/735] Building C object esp32/CMakeFiles/esp32.dir/hwcrypto/sha.c.obj
[574/735] Building C object esp32/CMakeFiles/esp32.dir/hwcrypto/aes.c.obj
[575/735] Building C object esp32/CMakeFiles/esp32.dir/freertos_hooks.c.obj
[576/735] Building C object esp32/CMakeFiles/esp32.dir/event_default_handlers.c.obj
[577/735] Building C object esp32/CMakeFiles/esp32.dir/gdbstub.c.obj
[578/735] Building C object esp32/CMakeFiles/esp32.dir/fast_crypto_ops.c.obj
[579/735] Building C object esp32/CMakeFiles/esp32.dir/coexist.c.obj
[580/735] Building C object esp32/CMakeFiles/esp32.dir/event_loop.c.obj
[581/735] Building C object esp32/CMakeFiles/esp32.dir/ets_timer_legacy.c.obj
[582/735] Building C object esp32/CMakeFiles/esp32.dir/brownout.c.obj
[583/735] Linking C static library wpa_supplicant\libwpa_supplicant.a
[584/735] Building C object esp32/CMakeFiles/esp32.dir/cache_sram_mmu.c.obj
[585/735] Building C object esp32/CMakeFiles/esp32.dir/clk.c.obj
[586/735] Building ASM object esp32/CMakeFiles/esp32.dir/dport_panic_highint_hdl.S.obj
[587/735] Building C object esp32/CMakeFiles/esp32.dir/cache_err_int.c.obj
[588/735] Building C object esp32/CMakeFiles/esp32.dir/core_dump.c.obj
[589/735] Building C object esp32/CMakeFiles/esp32.dir/dbg_stubs.c.obj
[590/735] Building C object esp32/CMakeFiles/esp32.dir/crosscore_int.c.obj
[591/735] Building C object esp32/CMakeFiles/esp32.dir/cpu_start.c.obj
[592/735] Building C object esp32/CMakeFiles/esp32.dir/dport_access.c.obj
[593/735] Building C object esp32/CMakeFiles/esp32.dir/esp_err_to_name.c.obj
[594/735] Building C object openssl/CMakeFiles/openssl.dir/platform/ssl_port.c.obj
[595/735] Building C object esp32/CMakeFiles/esp32.dir/esp_timer_esp32.c.obj
[596/735] Building C object esp32/CMakeFiles/esp32.dir/esp_timer.c.obj
[597/735] Building C object openssl/CMakeFiles/openssl.dir/library/ssl_x509.c.obj
[598/735] Building C object esp32/CMakeFiles/esp32.dir/esp_himem.c.obj
[599/735] Building C object openssl/CMakeFiles/openssl.dir/platform/ssl_pm.c.obj
[600/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_onetimeauth/poly1305/sse2/poly1305_sse2.c.obj
[601/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.obj
[602/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/crypto_pwhash.c.obj
[603/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.obj
[604/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.obj
[605/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/argon2.c.obj
[606/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/blake2b-long.c.obj
[607/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-fill-block-ssse3.c.obj
[608/735] Linking C static library esp32\libesp32.a
[609/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/pwhash_argon2i.c.obj
[610/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-core.c.obj
[611/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/scrypt_platform.c.obj
[612/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-encoding.c.obj
[613/735] Building C object protobuf-c/CMakeFiles/protobuf-c.dir/protobuf-c/protobuf-c/protobuf-c.c.obj
[614/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/pbkdf2-sha256.c.obj
[615/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/pwhash_scryptsalsa208sha256.c.obj
[616/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/crypto_scrypt-common.c.obj
[617/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/sse/pwhash_scryptsalsa208sha256_sse.c.obj
[618/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.obj
[619/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/nosse/pwhash_scryptsalsa208sha256_nosse.c.obj
[620/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/donna_c64/curve25519_donna_c64.c.obj
[621/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/curve25519_sandy2x.c.obj
[622/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/consts.S.obj
[623/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/crypto_scalarmult.c.obj
[624/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.obj
[625/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/fe51_pack.S.obj
[626/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-fill-block-ref.c.obj
[627/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/fe51_mul.S.obj
[628/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/ladder.S.obj
[629/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/fe51_nsquare.S.obj
[630/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/fe_frombytes_sandy2x.c.obj
[631/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/fe51_invert.c.obj
[632/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox.c.obj
[633/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/sandy2x.S.obj
[634/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_scalarmult/curve25519/sandy2x/ladder_base.S.obj
[635/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox_easy.c.obj
[636/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_shorthash/siphash24/shorthash_siphash24.c.obj
[637/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_secretbox/xchacha20poly1305/secretbox_xchacha20poly1305.c.obj
[638/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_shorthash/crypto_shorthash.c.obj
[639/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_shorthash/siphash24/shorthash_siphashx24.c.obj
[640/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_secretbox/xsalsa20poly1305/secretbox_xsalsa20poly1305.c.obj
[641/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_shorthash/siphash24/ref/shorthash_siphash24_ref.c.obj
[642/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_shorthash/siphash24/ref/shorthash_siphashx24_ref.c.obj
[643/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_sign/ed25519/ref10/open.c.obj
[644/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_sign/ed25519/ref10/obsolete.c.obj
[645/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_sign/ed25519/ref10/sign.c.obj
[646/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/stream_aes128ctr.c.obj
[647/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_sign/ed25519/sign_ed25519.c.obj
[648/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_sign/crypto_sign.c.obj
[649/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_sign/ed25519/ref10/keypair.c.obj
[650/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/consts_aes128ctr.c.obj
[651/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/stream_aes128ctr_nacl.c.obj
[652/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/int128_aes128ctr.c.obj
[653/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/crypto_stream.c.obj
[654/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/chacha20/dolbeau/chacha20_dolbeau-avx2.c.obj
[655/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/chacha20/dolbeau/chacha20_dolbeau-ssse3.c.obj
[656/735] Building ASM object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6-asm.S.obj
[657/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/chacha20/stream_chacha20.c.obj
[658/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-avx2.c.obj
[659/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa20/ref/salsa20_ref.c.obj
[660/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa20/stream_salsa20.c.obj
[661/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6.c.obj
[662/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-sse2.c.obj
[663/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa2012/stream_salsa2012.c.obj
[664/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa208/stream_salsa208.c.obj
[665/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa208/ref/stream_salsa208_ref.c.obj
[666/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.obj
[667/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/salsa2012/ref/stream_salsa2012_ref.c.obj
[668/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/xchacha20/stream_xchacha20.c.obj
[669/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/randombytes/randombytes.c.obj
[670/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_verify/sodium/verify.c.obj
[671/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/randombytes/sysrandom/randombytes_sysrandom.c.obj
[672/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/afternm_aes128ctr.c.obj
[673/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/beforenm_aes128ctr.c.obj
[674/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/randombytes/salsa20/randombytes_salsa20_random.c.obj
[675/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/randombytes/nativeclient/randombytes_nativeclient.c.obj
[676/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/xsalsa20/stream_xsalsa20.c.obj
[677/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/crypto_stream/aes128ctr/nacl/xor_afternm_aes128ctr.c.obj
[678/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/sodium/runtime.c.obj
[679/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/sodium/version.c.obj
[680/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/sodium/core.c.obj
[681/735] Building C object libsodium/CMakeFiles/libsodium.dir/port/randombytes_esp32.c.obj
[682/735] Building C object libsodium/CMakeFiles/libsodium.dir/libsodium/src/libsodium/sodium/utils.c.obj
[683/735] Building C object libsodium/CMakeFiles/libsodium.dir/port/crypto_hash_mbedtls/crypto_hash_sha512_mbedtls.c.obj
[684/735] Building C object libsodium/CMakeFiles/libsodium.dir/port/crypto_hash_mbedtls/crypto_hash_sha256_mbedtls.c.obj
[685/735] Building C object openssl/CMakeFiles/openssl.dir/library/ssl_cert.c.obj
[686/735] Building C object mqtt/CMakeFiles/mqtt.dir/esp-mqtt/lib/mqtt_outbox.c.obj
[687/735] Building C object openssl/CMakeFiles/openssl.dir/library/ssl_lib.c.obj
[688/735] Building C object mdns/CMakeFiles/mdns.dir/mdns_console.c.obj
[689/735] Linking C static library libsodium\liblibsodium.a
[690/735] Building C object mqtt/CMakeFiles/mqtt.dir/esp-mqtt/lib/mqtt_msg.c.obj
[691/735] Building C object mdns/CMakeFiles/mdns.dir/mdns_networking.c.obj
[692/735] Building C object mqtt/CMakeFiles/mqtt.dir/esp-mqtt/mqtt_client.c.obj
[693/735] Building C object openssl/CMakeFiles/openssl.dir/library/ssl_methods.c.obj
[694/735] Building C object openssl/CMakeFiles/openssl.dir/library/ssl_stack.c.obj
[695/735] Performing configure step for ‘bootloader’
— Found Git: C:/SysGCC/esp32/usr/bin/git.exe (found version “2.19.0”)
— Component names: soc bootloader spi_flash micro-ecc bootloader_support esptool_py partition_table esp32 log main
— Component paths: C:/SysGCC/esp32/esp-idf/v3.2/components/soc;C:/SysGCC/esp32/esp-idf/v3.2/components/bootloader;C:/SysGCC/esp32/esp-idf/v3.2/components/spi_flash;C:/SysGCC/esp32/esp-idf/v3.2/components/micro-ecc;C:/SysGCC/esp32/esp-idf/v3.2/components/bootloader_support;C:/SysGCC/esp32/esp-idf/v3.2/components/esptool_py;C:/SysGCC/esp32/esp-idf/v3.2/components/partition_table;C:/SysGCC/esp32/esp-idf/v3.2/components/esp32;C:/SysGCC/esp32/esp-idf/v3.2/components/log;C:/SysGCC/esp32/esp-idf/v3.2/components/bootloader/subproject/main
— The ASM compiler identification is GNU
— Found assembler: C:/SysGCC/esp32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
— The C compiler identification is GNU 5.2.0
— The CXX compiler identification is GNU 5.2.0
— Check for working C compiler: C:/SysGCC/esp32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
— Check for working C compiler: C:/SysGCC/esp32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe — works
— Detecting C compiler ABI info
— Detecting C compiler ABI info – done
— Detecting C compile features
— Detecting C compile features – done
— Check for working CXX compiler: C:/SysGCC/esp32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
— Check for working CXX compiler: C:/SysGCC/esp32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe — works
— Detecting CXX compiler ABI info
— Detecting CXX compiler ABI info – done
— Detecting CXX compile features
— Detecting CXX compile features – done
— Component libraries: soc;spi_flash;micro-ecc;bootloader_support;esp32;log;main
— Adding linker script C:/SysGCC/esp32/esp-idf/v3.2/components/bootloader/subproject/main/esp32.bootloader.ld
— Adding linker script C:/SysGCC/esp32/esp-idf/v3.2/components/bootloader/subproject/main/esp32.bootloader.rom.ld
— Adding linker script C:/SysGCC/esp32/esp-idf/v3.2/components/esp32/ld/esp32.rom.ld
— Adding linker script C:/SysGCC/esp32/esp-idf/v3.2/components/esp32/ld/esp32.rom.spiram_incompatible_fns.ld
— Adding linker script C:/SysGCC/esp32/esp-idf/v3.2/components/esp32/ld/esp32.peripherals.ld
— Configuring done
— Generating done
— Build files have been written to: C:/VisualGDB/EmbeddedProject5/VisualGDB/Debug/bootloader
[696/735] Building C object openssl/CMakeFiles/openssl.dir/library/ssl_pkey.c.obj
[697/735] Linking C static library protobuf-c\libprotobuf-c.a
[698/735] Building C object protocomm/CMakeFiles/protocomm.dir/src/security/security0.c.obj
[699/735] Building C object mqtt/CMakeFiles/mqtt.dir/esp-mqtt/lib/platform_esp32_idf.c.obj
[700/735] Building C object protocomm/CMakeFiles/protocomm.dir/src/common/protocomm.c.obj
[701/735] Building C object protocomm/CMakeFiles/protocomm.dir/proto-c/session.pb-c.c.obj
[702/735] Building C object protocomm/CMakeFiles/protocomm.dir/src/security/security1.c.obj
[703/735] Linking C static library openssl\libopenssl.a
[704/735] Building C object protocomm/CMakeFiles/protocomm.dir/src/transports/protocomm_console.c.obj
[705/735] Building C object protocomm/CMakeFiles/protocomm.dir/proto-c/sec1.pb-c.c.obj
[706/735] Building C object protocomm/CMakeFiles/protocomm.dir/src/transports/protocomm_httpd.c.obj
[707/735] Building C object protocomm/CMakeFiles/protocomm.dir/proto-c/constants.pb-c.c.obj
[708/735] Linking C static library mqtt\libmqtt.a
[709/735] Building C object protocomm/CMakeFiles/protocomm.dir/proto-c/sec0.pb-c.c.obj
[710/735] Building C object mdns/CMakeFiles/mdns.dir/mdns.c.obj
[711/735] Building C object spiffs/CMakeFiles/spiffs.dir/spiffs_api.c.obj
[712/735] Building C object spiffs/CMakeFiles/spiffs.dir/spiffs/src/spiffs_cache.c.obj
[713/735] Building C object spiffs/CMakeFiles/spiffs.dir/spiffs/src/spiffs_check.c.obj
[714/735] Building C object ulp/CMakeFiles/ulp.dir/ulp.c.obj
[715/735] Building C object spiffs/CMakeFiles/spiffs.dir/spiffs/src/spiffs_gc.c.obj
[716/735] Linking C static library mdns\libmdns.a
[717/735] Building C object spiffs/CMakeFiles/spiffs.dir/esp_spiffs.c.obj
[718/735] Building C object spiffs/CMakeFiles/spiffs.dir/spiffs/src/spiffs_hydrogen.c.obj
[719/735] Linking C static library protocomm\libprotocomm.a
[720/735] Building C object spiffs/CMakeFiles/spiffs.dir/spiffs/src/spiffs_nucleus.c.obj
[721/735] Building C object wifi_provisioning/CMakeFiles/wifi_provisioning.dir/proto-c/wifi_constants.pb-c.c.obj
[722/735] Building C object ulp/CMakeFiles/ulp.dir/ulp_macro.c.obj
[723/735] Building C object wifi_provisioning/CMakeFiles/wifi_provisioning.dir/src/wifi_config.c.obj
[724/735] Building C object wifi_provisioning/CMakeFiles/wifi_provisioning.dir/proto-c/wifi_config.pb-c.c.obj
[725/735] Linking C static library spiffs\libspiffs.a
[726/735] Building C object main/CMakeFiles/main.dir/hello_world_main.c.obj
[727/735] Linking C static library ulp\libulp.a
[728/735] Linking C static library wifi_provisioning\libwifi_provisioning.a
[729/735] Linking C static library main\libmain.a
[730/735] Linking CXX executable hello-world.elf
[731/735] Performing build step for ‘bootloader’
[1/43] Generating dummy_main_src.c
[2/43] Building C object soc/CMakeFiles/soc.dir/esp32/cpu_util.c.obj
[3/43] Building C object soc/CMakeFiles/soc.dir/esp32/gpio_periph.c.obj
[4/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_init.c.obj
[5/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_clk.c.obj
[6/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_clk_init.c.obj
[7/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_pm.c.obj
[8/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_sleep.c.obj
[9/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_periph.c.obj
[10/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_time.c.obj
[11/43] Building C object CMakeFiles/bootloader.elf.dir/dummy_main_src.c.obj
[12/43] Building C object soc/CMakeFiles/soc.dir/esp32/rtc_wdt.c.obj
[13/43] Building C object soc/CMakeFiles/soc.dir/esp32/soc_memory_layout.c.obj
[14/43] Building C object soc/CMakeFiles/soc.dir/esp32/sdmmc_periph.c.obj
[15/43] Building C object soc/CMakeFiles/soc.dir/esp32/spi_periph.c.obj
[16/43] Building C object soc/CMakeFiles/soc.dir/esp32/sdio_slave_periph.c.obj
[17/43] Building C object soc/CMakeFiles/soc.dir/src/memory_layout_utils.c.obj
[18/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_sha.c.obj
[19/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_clock.c.obj
[20/43] Building C object spi_flash/CMakeFiles/spi_flash.dir/spi_flash_rom_patch.c.obj
[21/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_flash.c.obj
[22/43] Building C object micro-ecc/CMakeFiles/micro-ecc.dir/micro-ecc/uECC.c.obj
[23/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_random.c.obj
[24/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_common.c.obj
[25/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/efuse.c.obj
[26/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/flash_partitions.c.obj
[27/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_utility.c.obj
[28/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/flash_qio_mode.c.obj
[29/43] Linking C static library soc\libsoc.a
[30/43] Linking C static library spi_flash\libspi_flash.a
[31/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/flash_encrypt.c.obj
[32/43] Linking C static library micro-ecc\libmicro-ecc.a
[33/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/secure_boot_signatures.c.obj
[34/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/esp_image_format.c.obj
[35/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/secure_boot.c.obj
[36/43] Building C object log/CMakeFiles/log.dir/log.c.obj
[37/43] Building C object main/CMakeFiles/main.dir/bootloader_start.c.obj
[38/43] Building C object bootloader_support/CMakeFiles/bootloader_support.dir/src/bootloader_init.c.obj
[39/43] Linking C static library log\liblog.a
[40/43] Linking C static library main\libmain.a
[41/43] Linking C static library bootloader_support\libbootloader_support.a
[42/43] Linking C executable bootloader.elf
[43/43] Generating bootloader.bin
esptool.py v2.6-beta1
[732/735] Generating hello-world.bin
[733/735] No install step for ‘bootloader’
[734/735] Completed ‘bootloader’
[734/735] cmd.exe /C “cd /D C:\SysGCC\esp32\esp-idf\v3.2\components\esptool_py && C:\Users\Hem_Üretim\AppData\Local\VisualGDB\CMake\bin\cmake.exe -D IDF_PATH=”C:/SysGCC/esp32/esp-idf/v3.2″ -D ESPTOOLPY=”python C:/SysGCC/esp32/esp-idf/v3.2/components/esptool_py/esptool/esptool.py –chip esp32″ -D ESPTOOL_ARGS=”write_flash @flash_project_args” -D ESPTOOL_WORKING_DIR=”C:/VisualGDB/EmbeddedProject5/VisualGDB/Debug” -P run_esptool.cmake”
Note: esptool.py will search for a serial port. To specify a port, set the ESPPORT environment variable.
Note: Using default baud rate 460800. To modify, set ESPBAUD environment variable.
esptool.py –chip esp32 -b 460800 write_flash –flash_mode dio –flash_size detect –flash_freq 40m 0x1000 bootloader/bootloader.bin 0x8000 partition_table/partition-table.bin 0x10000 hello-world.bin
Found 1 serial ports
Serial port COM1
Connecting…….._____….._____….._____….._____….._____….._____….._____
COM1 failed to connect: Failed to connect to ESP32: Timed out waiting for packet headerA fatal error occurred: All of the 1 available serial ports could not connect to a Espressif device.
CMake Error at run_esptool.cmake:45 (message):
esptool.py failedFAILED: CMakeFiles/flash
ninja: build stopped: subcommand failed.
Command exited with code 1
Executable: C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe
Arguments: flash
Directory: C:\VisualGDB\EmbeddedProject5/VisualGDB/Debug
Command-line action failed========== Project Build Summary ==========
EmbeddedProject5 built in 01:08
========== Build: 0 Succeeded, 1 Failed ==========</div>
<div></div>
<div>Exception Details</div>
<div>VisualGDB version: 5.5.4.3540</div>
<div>—————— tl2 ——————</div>
<div>tl2: Failed to open ‘C:\VisualGDB\EmbeddedProject5\run_esptool.cmake’. —> System.IO.FileNotFoundException: Belge açılamadı. Adı değiştirilmiş, silinmiş veya taşınmış olabilir.</div>
<div> konum: System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)</div>
<div> konum: Microsoft.VisualStudio.Shell.VsShellUtilities.OpenDocument(IServiceProvider provider, String fullPath, Guid logicalView, IVsUIHierarchy& hierarchy, UInt32& itemID, IVsWindowFrame& windowFrame, IVsTextView& view)</div>
<div> konum: zi.v(String d, Int32 a, Int32 c, ed2 b)</div>
<div> — İç özel durum yığını izlemesinin sonu —</div>
<div> konum: co.q(hr2 a)</div>
<div> trace=[zi.v:68, co.q:0]</div>
<div>—————— Inner exception ——————</div>
<div>—————— System.IO.FileNotFoundException ——————</div>
<div>System.IO.FileNotFoundException: Belge açılamadı. Adı değiştirilmiş, silinmiş veya taşınmış olabilir.</div>
<div> trace=[System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal:-1, Microsoft.VisualStudio.Shell.VsShellUtilities.OpenDocument:48, zi.v:43]</div>
May 10, 2020 at 15:49 #28097support
This looks like an issue with the ESP-IDF itself and not something specific to VisualGDB. Please see our ESP-IDF troubleshooting instructions for help with narrowing this down.
