Hi folks,
thanks for the excellent work supporting JTAG debugging on the esp8266/lx106.
I’m trying something a little different – I have an Olimex esp8266-EVB wired and built the sysprogs version of openOCD in Linux and would like to 1) confirm that wiring is correct and JTAG is working and 2) if possible, use plain old gdb to do my debugging.
I’m using an Olimex ARM-USB-TINY-H and have wired my board according to the tutorials. Output from openOCD is below:
[test@u:~/src/openocd] 130 $ sudo /usr/local/bin/openocd -f tcl/interface/ftdi/olimex-arm-usb-tiny-h.cfg -f tcl/target/esp8266.cfg
Open On-Chip Debugger 0.9.0-dirty (2015-12-12-15:35)
Licensed under GNU GPL v2
For bug reports, read
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
adapter speed: 1000 kHz
stop_wdt
Info : clock speed 1000 kHz
Info : TAP esp8266.cpu does not have IDCODE
Warn : Warning: Target not halted, breakpoint/watchpoint state may be unpredictable.
undefined debug reason 7 – target needs reset
Warn : target not halted
Warn : xtensa_poll: DOSR has set InOCDMode without the Exception flag. Unexpected. DOSR=0x04
target state: halted
Info : halted: PC: 0x44
Info : debug cause: 0x0
Info : dropped ‘gdb’ connection
From gdb I attempt to connect and issue monitor reset, monitor halt, and monitor reset halt. monitor halt produces the warning above (DOSR has set InOCDMode …), I get an error in gdb indicating that monitor reset halt isn’t supported for xtensa.
I’m stumbling around in the dark here so apologies for that. Is it possible to confirm that my setup is correct in this configuration? And can plain gdb be used?
Appreciate any help.
