ESP8266 project convert to Standalone
Sysprogs forums Forums VisualGDB ESP8266 project convert to Standalone
  • #21313
    Andrzej.T
    When I try convert ESP8266 project to standalone, I get a message:
    VisualGDB version: 5.4.3.2193
    ------------------ System.NullReferenceException ------------------
       at VisualGDB.Common_GUI.WPF.Property_pages.EmbeddedDebugPropertyPage2.ControllerImpl.TryUpdateProjectContext(sb2 newProjectContext, n8 ctx2)
       at s11.v.m(v c, sb2 a, n8 b)
       at s11.n1(sb2 a, h1 b)
       at s11.p(Boolean a, eb2 b, String d, Action c)
       at s11.v.d.b(Object a, eb2 b)
       at fl.i(Object b, EventArgs a)
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
       at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
       at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
       at System.Windows.Window.ShowHelper(Object booleanBox)
       at System.Windows.Window.Show()
       at System.Windows.Window.ShowDialog()
       at nj.GDBProjectProperties.ExecuteForProject(nj addin, Object objPrj)
    and then Visual Studio 2017 crashes.
    A<span id=”result_box” lang=”en”>fter restarting Visual Studio and the compilation process I received a message: </span>
    <span id="result_box" lang="en">cannot find entry symbol _start; not setting start address</span>
    1>------------------- Memory utilization report -------------------
    1>Used SPIFLASH: 0 bytes out of 16MB (0%) [-219K]
    1>Used INSTR_RAM: 0 bytes out of 32KB (0%) [-25K]
    1>Used DATA_RAM: 0 bytes out of 80KB (0%) [-25K]
    I could ask for help in solving the problem.
    Regards
    Andrzej.T
    #21318
    Thanks for reporting this, looks like our bug. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.3.2348.msi
    #21324
    Andrzej.T
    Thanks a lot.
    But now debugging not working, the Segger J-Link debugging method has disappeared.
    #21330
    Please try installing the experimental J-Link package from http://sysprogs.com/files/tmp/segger-dmsp-5.1preview1.vgdbxedp.
    You can install it into VisualGDB via Tools->VisualGDB->Manage VisualGDB Packages.
    #21422
    Andrzej.T
    But I do not see the Segger J-Link debugging method.
    • This reply was modified 7 years, 7 months ago by Andrzej.T.
    #21426
    Sorry for the confusion. Could you please confirm whether the method disappeared for ESP8266/ESP32 devices or for ARM devices?
    The ESP8266/ESP32 devices are not supported by the Segger J-Link GDB Stub, so the only way to use Segger J-Link with them is via OpenOCD (VisualGDB supports it). You can use this mode by selecting OpenOCD as the debug method and then picking J-Link as the interface (or switching to the “USB Devices” view and letting VisualGDB handle the debug method selection automatically).
