ESP8266 – failed to connect to GDB stub
Sysprogs forums Forums VisualGDB ESP8266 – failed to connect to GDB stub
Viewing 16 post (of 16 total)
  • #20061
    The new toolchain should not flash any other file apart from esp_init_data_default.bin. You can also disable the esp_init_data_default.bin flashing by setting the “FLASH Initialization file” under the advanced settings to an empty string to see if the new programming step affects the problem.
