ESP32S-WROOM GBD Debugging
Sysprogs forums Forums VisualGDB ESP32S-WROOM GBD Debugging
  • #31558
    Sam a
    At the moment I am trying to create a using a Hiletgo ESP32S-WROOM board (v1.1 if it matters), and I am having some trouble. Initially the ESP-IDF package was giving cert errors but that was an easy fix. Now I am able to load up a program onto the board (for example flash) by holding down the IO0 button, however once I am done flashing visualgdb claims it could not find the device for actual debugging after the fact. I can confirm that it is indeed flashing the program however since when I hit the enable button on the board (From my understanding the reset) the blue led starts blinking, and when I change the code to blink at different rates it corresponds to it. However, with all of this the debugging is important.
    Visual GDB V5.6
    Using the ESP32/ESP8266 project option
    Using ESP-IDF 4.3.1 (Latest version at the moment, visualgdb fetched it for me)
    CMake Build Settings: Ninja underlying build system
    Debug using OpenOCD, JTAG/SWD Programmer: ESP32 Devkit option
    JTAG/SWD Frequency: 3000
    Debugged device: ESP32
    Error:
    C:\Users\myUser\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 59162” -c “telnet_port 59160” -f interface/ftdi/esp32_devkitj_v1.cfg -c “adapter_khz 3000” -f target/esp32.cfg -c “echo VisualGDB_OpenOCD_Ready”
    Open On-Chip Debugger 0.10.0 (2021-07-16)
    Licensed under GNU GPL v2
    For bug reports, read
    adapter speed: 20000 kHz
    adapter speed: 3000 kHz
    Info : Listening on port 59160 for telnet connections
    Error: no device found
    Error: unable to open ftdi device with vid 0403, pid 6010, description ‘*’, serial ‘*’ at bus location ‘*’
    Error: unable to open ftdi device with vid 0403, pid 6014, description ‘*’, serial ‘*’ at bus location ‘*’
    Error: No JTAG interface configured yet. Issue ‘init’ command in startup scripts before communicating with targets.
    Error: Failed to clear OCDDCR_ENABLEOCD!
    #31559
    Sam a
    Also as for hardware I simply just have the ESP32 board mentioned above connected via usb to my host machine, with the SILABS cp210x windows drivers installed.
    #31560
    paulh001
    Did you install correct USB driver using Zadig for interface 0?
    For me I have to use libusbK driver other drivers did not work for me.
    Also it worked on Windows 10 but lately it stopped working and could not get it working again.
    Now on Windows 11 and works again.
    Maybe this helps
    #31561
    Hi All,
    @paulh001
    , thanks for suggesting it.
    @Sam_a, you can find more information about OpenOCD and drivers on this page.
    #31564
    Sam a
    Hi, I got my hands on an ESP-PROG for jtag debugging, when I switch to flash via jtagger vs com port, it cannot be detected for im assuming the same reason debugging would not work. However setting the port to COM15 for the jtagger in arduino allows me to program it, but through visualGDB I can’t seem to detect it. Is it because I am not supposed to be using OpenOCD with it? Or the script for the ESP-PROG does not exist?
    As for the zadig usb drivers, I am not exactly sure what I would have to do there. When I first plugged in my ESP-PROG to my host machine it installed the drivers and I could see two new com ports, one I assume for receiving and I was indeed able to communicate with it.
    EDIT: Using the ‘Program ESP32 Program into FLASH memory’ option I was just able to at least program the board using the ESP-PROG, however clicking ‘start’ to begin a debug session + flash does not work.
    • This reply was modified 4 years, 4 months ago by Sam a.
    #31566
    Programming via COM port does not utilize JTAG or OpenOCD. It simply uploads the image to the built-in bootloader using esptool.py. You can achieve the same effect with VisualGDB by right-clicking on the project in Solution Explorer and selecting “Program FLASH memory”.
    In order to do JTAG debugging, VisualGDB uses the OpenOCD port maintained by Espressif. If it doesn’t work with your hardware, please refer to the documentation from Espressif to get it working.
    If you can confirm that OpenOCD works outside VisualGDB, but not when used by VisualGDB, please let us know the email address associated with your license, and we will gladly help you configure VisualGDB to replicate the results of running it manually.
    #31567
    Sam a
    After making a few driver changes the debugger seems to be functioning now, solved.
