Sysprogs forums › Forums › VisualGDB › ESP32 Unit test broken in 5.5 ?
- This topic has 4 replies, 2 voices, and was last updated 5 years, 4 months ago by
christophe.
October 29, 2020 at 00:11 #29413
christophe
ParticipantI’m running on the latest VisualGDB 5.5R2 and trying to do a simple unit test on IDF ESP32 project.
I got the popup informing me that enabling unit tests will automatically do some operations, in particular, setting application tracing destination to memory.
If i try to create a unit test, building is ok, but when i attempt to run it, i receive an error message saying that tracing destination must be set to memory. (effectively, the option wasn’t not automatically set). But even if i set it manually, i’m still receiving the same error message, and i’m unable to launch the unit tests
October 29, 2020 at 10:52 #29418support
No problem, please try this build: VisualGDB-5.5.102.3879.msi
November 2, 2020 at 12:13 #29430christophe
With this version, the tracing application “data destination” is correctly set to “trace memory”, but when i try to compile the unit test, the build still stops on the #error. Here is the build log:
[934/945] Building C object esp-idf/SysprogsUnitTestInterface/CMakeFiles/__idf_SysprogsUnitTestInterface.dir/SysprogsUnitTestInterface.c.obj
FAILED: esp-idf/SysprogsUnitTestInterface/CMakeFiles/__idf_SysprogsUnitTestInterface.dir/SysprogsUnitTestInterface.c.obj
C:\SysGCC\esp32\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DBUILDING_UNIT_TESTS -DUNITY_INCLUDE_CONFIG_H -Iconfig -IC:/SysGCC/esp32/esp-idf/SysprogsComponents/SysprogsUnitTestInterface -IC:/SysGCC/esp32/esp-idf/v4.2/components/newlib/platform_include -IC:/SysGCC/esp32/esp-idf/v4.2/components/freertos/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/freertos/xtensa/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/heap/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/log/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/lwip/include/apps -IC:/SysGCC/esp32/esp-idf/v4.2/components/lwip/include/apps/sntp -IC:/SysGCC/esp32/esp-idf/v4.2/components/lwip/lwip/src/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/lwip/port/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/lwip/port/esp32/include/arch -IC:/SysGCC/esp32/esp-idf/v4.2/components/soc/src/esp32/. -IC:/SysGCC/esp32/esp-idf/v4.2/components/soc/src/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/soc/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_rom/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_common/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_system/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/xtensa/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/xtensa/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/driver/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/driver/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_ringbuf/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/efuse/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/efuse/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/espcoredump/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_timer/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_ipc/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/soc/soc/esp32/. -IC:/SysGCC/esp32/esp-idf/v4.2/components/soc/soc/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/soc/soc/esp32/../include -IC:/SysGCC/esp32/esp-idf/v4.2/components/vfs/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_wifi/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_wifi/esp32/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_event/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_netif/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_eth/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/tcpip_adapter/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/app_trace/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/esp_gdbstub/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/unity/include -IC:/SysGCC/esp32/esp-idf/v4.2/components/unity/unity/src -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\”v4.2-dev-1995-g636b964c8-dirty\” -DESP_PLATFORM -MD -MT esp-idf/SysprogsUnitTestInterface/CMakeFiles/__idf_SysprogsUnitTestInterface.dir/SysprogsUnitTestInterface.c.obj -MF esp-idf\SysprogsUnitTestInterface\CMakeFiles\__idf_SysprogsUnitTestInterface.dir\SysprogsUnitTestInterface.c.obj.d -o esp-idf/SysprogsUnitTestInterface/CMakeFiles/__idf_SysprogsUnitTestInterface.dir/SysprogsUnitTestInterface.c.obj -c C:/SysGCC/esp32/esp-idf/SysprogsComponents/SysprogsUnitTestInterface/SysprogsUnitTestInterface.c
C:/SysGCC/esp32/esp-idf/SysprogsComponents/SysprogsUnitTestInterface/SysprogsUnitTestInterface.c:8:2: error: #error Please set the Application Level Tracing -> Data Destination setting in ESP-IDF confguration to ‘Trace Memory’
^~~~~November 2, 2020 at 12:15 #29431support
KeymasterNo problem, please try replacing the SysprogsUnitTestInterface.c inside the toolchain with the updated version from the VisualGDB directory. This should fix the setting check.
November 2, 2020 at 22:56 #29432christophe
Seems working well by replacing the sysprogsUnitTestInterface.c file.
