I have installed esp32 toolchain. It have been installed via VisualGDB project creator wizard.
For my project I want to execute idf.py menuconfig but i can npt do this because in “Developer power shell I receive replay: “Please use idf.py only in an ESP-IDF shell environment”.
Unfortunately VisualGDB do not create a shortcut to ESP-IDF shell environment so my question are:
1) How to create “ESP-IDF shell environment”?
or
2) How to execute idf.py menuconfig or other idf command in VisualGDB?
You can try dumping the build command into a batch file as shown here. It will contain all the necessary environment variables, so you can then modify it to run idf.py or any other command.
