ESP32 Reduce compile time Sysprogs forums › Forums › VisualGDB › ESP32 Reduce compile time This topic has 1 reply, 2 voices, and was last updated 7 years, 7 months ago by support. Log In Register Lost Password Viewing 2 posts - 1 through 2 (of 2 total) Author Posts August 28, 2018 at 13:54 #21821 mikemoyParticipant When compiling for ESP32, typically you would use the -j parameter for how many cores your system has to speed up the compile process. Is there a place we can add this option to, as compiling for the ESP32 is laborious slow without it. August 28, 2018 at 16:29 #21828 supportKeymaster Hi, Normally VisualGDB will add it automatically based on your CPU core count, so no action is required. You can also specify it manually via VisualGDB Project Properties -> ESP-IDF Project -> Additional Arguments. Author Posts Log In Register Lost Password Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
