Sysprogs forums › Forums › VisualGDB › ESP32 Jlink Programming fails
- This topic has 5 replies, 2 voices, and was last updated 7 years, 3 months ago by
December 10, 2018 at 23:24 #23015
JakobN
ParticipantUnfortunaley i can’t get the ESP32 to debug.
it seems to flash but cant read ?
do you have any idea to solve the problem?
You must be logged in to view attached files.December 11, 2018 at 03:49 #23017support
This looks like a TCP communication error between VisualGDB and OpenOCD. Please try restarting your computer and disabling the firewall, as it might be blocking OpenOCD.
If the error persists, please try ignoring the error and starting a debug session. Then check both OpenOCD and gdb logs for more detailed error messages.
December 12, 2018 at 12:40 #23027JakobN
tried it with 2 different Systems, same effect. All Firewall disabled.
I tried to connect manually, failure as in picture. I also tried to set GDBServerDelay (like https://sysprogs.com/w/forums/topic/openocd-issue/) higher, then it could connect 1 or 2 times, but now agian its not working.
Thanks for your help
You must be logged in to view attached files.December 12, 2018 at 19:03 #23031support
It looks like you are using the ARM build of gdb that is not compatible with the ESP32 devices. Please use our ESP32 toolchain instead. You can find a detailed step-by-step tutorial here: https://visualgdb.com/tutorials/esp32/esp-idf/
December 12, 2018 at 19:49 #23032JakobN
Participantah then i took the wrong fiel for the manual testing. Where is the gdb exe for the ESP32.
The error is still the same
System.Exception: FLASH programming failed. Please review the gdb/OpenOCD logs for details.bei ESP8266DebugPackage.ESP32DebugController.LoadFLASH(DebugStartContext context, IDebugStartService service, ISimpleGDBSession session, ESP32OpenOCDSettings settings, ESP32GDBStub stub)bei ESP8266DebugPackage.ESP32DebugController.ESP32GDBStub.RunLoadCommand(IDebugStartService service, ISimpleGDBSession session, String cmd)bei OpenOCDPackage.OpenOCDDebugController.OpenOCDGDBStub.ConnectGDBToStub(IDebugStartService service, ISimpleGDBSession session)bei c8.j(ua d, t82 c, gw1 a, EmbeddedTraceSettings b)bei tq1.o_2(DebugCustomizationSettings a)bei ph2.z2()bei mf2.e_4()bei VisualGDB.GDBDebugEngine.u(es a, c1 b)GDBVisualGDB is licensed to-gdb-version=thread-group-added,id="i1"~"GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 7.10\n"~"Copyright (C) 2015 Free Software Foundation, Inc.\n"~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>This is free software: you are free to change and redistribute it.There is NO WARRANTY, to the extent permitted by law. Type "show copying"and "show warranty" for details.~"This GDB was configured as \"--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf\".\nType \"show configuration\" for configuration details."This GDB was configured as "--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf".Type "show configuration" for configuration details.~"\nFor bug reporting instructions, please see:\n"~"<http://www.gnu.org/software/gdb/bugs/>.\n"~"Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n"Find the GDB manual and other documentation resources online at:<http://www.gnu.org/software/gdb/documentation/>.~"For help, type \"help\".\n"~"Type \"apropos word\" to search for commands related to \"word\"...\n"~"Reading symbols from C:/Users/JakobN/source/repos/EmbeddedProject5/EmbeddedProject5/VisualGDB/Debug/blink.elf..."~"done.\n"~"GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 7.10\n"~"Copyright (C) 2015 Free Software Foundation, Inc.\n"~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>This is free software: you are free to change and redistribute it.There is NO WARRANTY, to the extent permitted by law. Type "show copying"and "show warranty" for details.~"This GDB was configured as \"--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf\".\nType \"show configuration\" for configuration details."This GDB was configured as "--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf".Type "show configuration" for configuration details.~"\nFor bug reporting instructions, please see:\n"~"<http://www.gnu.org/software/gdb/bugs/>.\n"~"Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n"Find the GDB manual and other documentation resources online at:<http://www.gnu.org/software/gdb/documentation/>.~"For help, type \"help\".\n"~"Type \"apropos word\" to search for commands related to \"word\".\n"^done-list-features^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info","language-option","info-gdb-mi-command","undefined-command-error-code","exec-run-start-option"]-gdb-set disassembly-flavor intel^error,msg="No symbol \"disassembly\" in current context."-gdb-set print demangle off^doneset remotetimeout 60&"set remotetimeout 60\n"=cmd-param-changed,param="remotetimeout",value="60"^donetarget remote :53667&"target remote :53667\n"~"Remote debugging using :53667\n"&"Remote communication error. Target disconnected.: No error.\n"^error,msg="Remote communication error. Target disconnected.: No error."mon gdb_breakpoint_override hard&"mon gdb_breakpoint_override hard\n"&"\"monitor\" command not supported by this target.\n"^error,msg="\"monitor\" command not supported by this target."mon reset halt&"mon reset halt\n"&"\"monitor\" command not supported by this target.\n"^error,msg="\"monitor\" command not supported by this target."mon program_esp32 "C:/Users/JakobN/source/repos/EmbeddedProject5/EmbeddedProject5/VisualGDB/Debug/bootloader/bootloader.bin" 0x1000&"mon program_esp32 \"C:/Users/JakobN/source/repos/EmbeddedProject5/EmbeddedProject5/VisualGDB/Debug/bootloader/bootloader.bin\" 0x1000\n"&"\"monitor\" command not supported by this target.\n"^error,msg="\"monitor\" command not supported by this target."-target-disconnect^error,msg="You can't do that when your target is `exec'"-gdb-exit^exitOPENOCDc:\SysGCC\esp32\esp32-bsp\OpenOCD\bin\openocd.exe -c "gdb_port 53667" -c "telnet_port 53668" -f interface/jlink.cfg -c "adapter_khz 3000" -f target/esp32.cfg -c "echo VisualGDB_OpenOCD_Ready"Open On-Chip Debugger 0.9.0 (2018-10-12)Licensed under GNU GPL v2For bug reports, readhttp://openocd.org/doc/doxygen/bugs.htmladapter speed: 3000 kHzInfo : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.esp32 interrupt mask onVisualGDB_OpenOCD_ReadyInfo : No device selected, using first device.Info : J-Link V9 compiled Apr 20 2018 16:47:26Info : Hardware version: 9.50Info : VTarget = 2.995 VInfo : clock speed 3000 kHzInfo : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).cpu0: Current bits set: BreakIn BreakOut RunStallIncpu1: Current bits set: noneInfo : esp32: Debug controller was reset (pwrstat=0xE5, after clear 0x5F).Info : accepting 'gdb' connection on tcp/53667Error: cpu0: esp32_fetch_all_regs (line 255): DSR (120034E5) indicates target still busy!Info : Target halted. PRO_CPU: PC=0x40007BA1 (active) APP_CPU: PC=0x00000000Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).Info : Target halted. PRO_CPU: PC=0x00000000 (active) APP_CPU: PC=0x00000000Info : Flash mapping 0: 0x3ffc0590 -> 0x3ffc0590, 1048321 KBInfo : Flash mapping 1: 0x3ffc0590 -> 0x3ffc0590, 1048321 KBInfo : Flash mapping 2: 0xb76fd8 -> 0xf5b099f, 10559 KBInfo : Flash mapping 3: 0x2a59638 -> 0x2a3e490, 43441 KBInfo : Flash mapping 4: 0xa4fccc -> 0x4921f9, 43365 KBInfo : Flash mapping 5: 0x17 -> 0x1401978, 4543 KBInfo : Flash mapping 6: 0x2a5cc18 -> 0xf5b09cf, 10559 KBInfo : Flash mapping 7: 0xa4fcc8 -> 0x20c, 6457 KBInfo : Flash mapping 8: 0x1 -> 0x2b, 43257 KBInfo : Flash mapping 9: 0x2a6c480 -> 0x0, 4516 KBInfo : Flash mapping 10: 0x0 -> 0xa4fccc, 43257 KBInfo : Flash mapping 11: 0x760eca20 -> 0x40386bd0, 4194303 KBInfo : Flash mapping 12: 0x760d70d4 -> 0x60164f, 43257 KBInfo : Flash mapping 13: 0x6c666d -> 0x6c68fe, 43257 KBInfo : Flash mapping 14: 0x1f -> 0x0, 0 KBInfo : Flash mapping 15: 0x2a59638 -> 0xa4fca4, 0 KBInfo : Flash mapping 16: 0xa4ffcc -> 0x2a3e490, 0 KBInfo : Flash mapping 17: 0x2a779a0 -> 0xa4fd4c, 4502 KBInfo : Flash mapping 18: 0x2a3e490 -> 0x64d850, 0 KBInfo : Flash mapping 19: 0x64dbf0 -> 0x64da18, 43458 KBInfo : Flash mapping 20: 0x2a709c8 -> 0x604faf, 43296 KBInfo : Flash mapping 21: 0xa4fd01 -> 0x0, 22752 KBInfo : Flash mapping 22: 0xb8c7e8 -> 0x10, 0 KBInfo : Flash mapping 23: 0x186a0 -> 0x1, 0 KBInfo : Flash mapping 24: 0xffb3b4c0 -> 0x74d9ec, 10559 KBInfo : Flash mapping 25: 0xfffffffc -> 0x0, 0 KBInfo : Flash mapping 26: 0x204 -> 0x144, 0 KBInfo : Flash mapping 27: 0xb8c7e8 -> 0x144, 11769 KBInfo : Flash mapping 28: 0x6f32c6f5 -> 0xa4fdac, 1821897 KBInfo : Flash mapping 29: 0xb8c898 -> 0xb82700, 1821897 KBInfo : Flash mapping 30: 0x6f3329a7 -> 0xb7e538, 0 KBInfo : Flash mapping 31: 0xa4fdd0 -> 0x0, 0 KBInfo : Flash mapping 32: 0x100 -> 0x1, 0 KBInfo : Flash mapping 33: 0x262c2db1 -> 0xa4fdd8, 10559 KBInfo : Flash mapping 34: 0x75b85c9b -> 0x144, 0 KBInfo : Flash mapping 35: 0xa4fdd0 -> 0xa4fe0c, 1928727 KBInfo : Flash mapping 36: 0xa4ffcc -> 0x75b8a2b0, 0 KBInfo : Flash mapping 37: 0xf5b087f -> 0x2a599ac, 4500 KBInfo : Flash mapping 38: 0x144 -> 0x1, 4 KBInfo : Flash mapping 39: 0xa4fe0c -> 0x4, 1949399 KBInfo : Flash mapping 40: 0x0 -> 0x0, 0 KBInfo : Flash mapping 41: 0x1 -> 0xd1a4, 128 KBInfo : Flash mapping 42: 0x1400000 -> 0x0, 0 KBInfo : Flash mapping 43: 0x2a3cd88 -> 0x2a3cd89, 6455 KBInfo : Flash mapping 44: 0xa4feb8 -> 0x467ad7, 6455 KBInfo : Flash mapping 45: 0x2a3cd88 -> 0xffffffff, 4505 KBInfo : Flash mapping 46: 0x466bb0 -> 0x466010, 43432 KBInfo : Flash mapping 47: 0xffffffff -> 0x1401978, 0 KBInfo : Flash mapping 48: 0x1401894 -> 0x1401978, 0 KBInfo : Flash mapping 49: 0x1401894 -> 0xa4feb8, 4103 KBInfo : Flash mapping 50: 0x1401978 -> 0x6381ed, 20485 KBInfo : Flash mapping 51: 0x6381f4 -> 0x6381ac, 1949399 KBInfo : Flash mapping 52: 0xa4ffcc -> 0x760eca20, 20485 KBInfo : Flash mapping 53: 0x1d -> 0x1401894, 6337 KBInfo : Flash mapping 54: 0xd -> 0x1401790, 0 KBInfo : Flash mapping 55: 0x0 -> 0x1d, 20486 KBInfo : Flash mapping 56: 0xa4ff80 -> 0x4013eb, 0 KBInfo : Flash mapping 57: 0x1401790 -> 0x1401ee8, 0 KBInfo : Flash mapping 58: 0x0 -> 0x0, 0 KBInfo : Flash mapping 59: 0x0 -> 0xcccccccc, 3355443 KBInfo : Flash mapping 60: 0xcccccccc -> 0xcccccccc, 3355443 KBInfo : Flash mapping 61: 0xcccccccc -> 0xcccccccc, 3355443 KBInfo : Flash mapping 62: 0x0 -> 0x0, 10559 KBInfo : Flash mapping 63: 0x34 -> 0x1401790, 20486 KBInfo : Flash mapping 64: 0x81000000 -> 0x0, 0 KBInfo : Flash mapping 65: 0x0 -> 0x0, 0 KBInfo : Flash mapping 66: 0x0 -> 0x0, 0 KBInfo : Flash mapping 67: 0x0 -> 0x0, 0 KBInfo : Flash mapping 68: 0x0 -> 0x0, 0 KBInfo : Flash mapping 69: 0x0 -> 0x0, 0 KBInfo : Flash mapping 70: 0x0 -> 0x0, 4101 KBInfo : Flash mapping 71: 0x401500 -> 0xa4ff94, 3416 KBInfo : Flash mapping 72: 0x401500 -> 0x401500, 10559 KBInfo : Flash mapping 73: 0x755f8484 -> 0x356000, 1923041 KBInfo : Flash mapping 74: 0x689e1fe1 -> 0xa4ffdc, 1949518 KBInfo : Flash mapping 75: 0x356000 -> 0xf7e5caae, 0 KBInfo : Flash mapping 76: 0x0 -> 0x356000, 0 KBInfo : Flash mapping 77: 0x0 -> 0x0, 0 KBInfo : Flash mapping 78: 0xf7e5caae -> 0xa4ffa0, 0 KBInfo : Flash mapping 79: 0xa4ffe4 -> 0x76fe2bd0, 2101747 KBInfo : Flash mapping 80: 0x0 -> 0xa4ffec, 1949518 KBInfo : Flash mapping 81: 0xffffffff -> 0x76fef2f2, 0 KBInfo : Flash mapping 82: 0x0 -> 0x401500, 3416 KBDecember 12, 2018 at 19:55 #23033support
Thanks for the logs. It looks like the ESP32 chip does not respond properly to JTAG commands and OpenOCD drops the connection:
Please try erasing the target FLASH memory using esptool.py. If this doesn’t help, please share the OpenOCD log above with Espressif and check if they know any workarounds (we do not have access to the internal Espressif’s documentation, so it’s hard for us to provide any more specific help when it comes to communication issues between various components that are not maintained by us).
