Sysprogs forums › Forums › VisualGDB › Esp32 debug not working on windows 7 evaluation
- This topic has 2 replies, 2 voices, and was last updated 7 years, 4 months ago by
snahmad75.
November 3, 2018 at 17:46 #22547
snahmad75
ParticipantI am evaluating visual GDB. We will buy once it is working for us.
Trial version in use.
My hello world project debug works.
Platform : Windows 7
Visual studio 2015.
Olimex ARM-UDB-OCD-H is attached to SD card to Esp32 Wrover.
using latest ESP32 master branch.
Debug Test does not work as well.
also command gdb not working.
but
I am getting this error with my project.
C:\SysGCC\esp32\esp32-bsp\OpenOCD\bin\openocd.exe -c “gdb_port 51250” -c “telnet_port 51251” -f interface/ftdi/olimex-arm-usb-ocd-h.cfg -c “adapter_khz 3000” -f target/esp32.cfg -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.9.0 (2018-10-12)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 3000 kHz
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select <transport>’.
esp32 interrupt mask on
Info : clock speed 3000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Trying to use configured scan chain anyway…
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: Exception reading pc!Info : Target halted. PRO_CPU: PC=0x00000000 (active) APP_CPU: PC=0x00000000
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data – a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure ‘init’
in procedure ‘ocd_bouncer’
in procedure ‘esp_smp_break_config’
in procedure ‘esp32’ called at file “target/esp32.cfg”, line 54
in procedure ‘esp_core_halt’
in procedure ‘esp32’ called at file “target/esp32.cfg”, line 44
at file “embedded:startup.tcl”, line 21Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : cpu0: Failed reading 4 bytes at address 0x3FF00030
Error: Failed to read target memory (-4)!
cpu0: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
cpu1: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
Info : accepting ‘gdb’ connection on tcp/51250
Warn : cpu0: Failed reading 5880 bytes at address 0x40090000
Error: no working area available, can’t alloc space for stub code!
Error: Failed to load stub (-308)!
Error: Algorithm run faied (-308)!
Error: Faied to run flasher stub (-308)!
Error: Failed to get flash mappings (-308)!
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use ‘gdb_memory_map disable’.
Error: attempted ‘gdb’ connection rejectedThanks,
Naeem
November 3, 2018 at 19:00 #22549support
This looks like a wiring issue. Please double-check your schematics. If you are not sure, please try the ESP-WROVER module that comes with a built-in JTAG interface.
November 4, 2018 at 12:51 #22561snahmad75
Participantok, i will try ESP-WROVER module then comes with built-in JTAG then in few days.
