ESP-IDF load error
Sysprogs forums Forums VisualGDB ESP-IDF load error
  • #21819
    mattia
    I’m using the ESP-IDF wizard for ESP32 with visualGDB5.4; I had to reinstall my software to a faster SSD, and now I have this problem:
    If I create an ESP32 project on my local SSD, I have no problem
    If I create an Embedded project on the server harddisk, I have no problem
    If I create an ESP32 project on the server harddisk, I have this problem:
    Checking if any source files need uploading…
    Missing \\Server-pc\qeed\Ufficio_tecnico\Progetti_in_corso\QC-POWER-T2\FW\DISPLAY\EmbeddedProject1\sdkconfig-debug. Running c:\SysGCC\esp32\bin\bash.exe –login -c “export IDF_PATH=/esp-idf/v3.0 && export BATCH_BUILD=1 && export LANG=en_US && cd \\Server-pc\qeed\Ufficio_tecnico\Progetti_in_corso\QC-POWER-T2\FW\DISPLAY\EmbeddedProject1 && make defconfig BUILD_DIR_BASE=’\\Server-pc\qeed\Ufficio_tecnico\Progetti_in_corso\QC-POWER-T2\FW\DISPLAY\EmbeddedProject1\VisualGDBCache\EmbeddedProject1-Debug-VisualGDB/CodeSenseDir’ SDKCONFIG=’\\Server-pc\qeed\Ufficio_tecnico\Progetti_in_corso\QC-POWER-T2\FW\DISPLAY\EmbeddedProject1/sdkconfig-debug’ V=0″…
    l12: Command-line action failed
    in l91.m4(CommandLineAction d, String f, eb e, CommandFlags c, String b, Boolean a)
    in l91.b3(CustomActionBase e, eb c, Boolean b, String d, Boolean a)
    in z51.l.i_2(nc a)
    in l2.c(String a)
    in l2.j_2()
    in lk1.f()
    and I can’t load the project nor compile it. What could be the problem?
    Thank you,
    Mattia Berton
    #21826
    Looks like the Cygwin environment might not be compatible with the UNC paths. Please ensure both the ESP32 toolchain and your project are located on a regular drive letter-based path (e.g. x:\folder\subfolder) and are not using the UNC paths (\\server\share).
