Error When Building Bootloader+App [cmake]
Sysprogs forums Forums VisualGDB Error When Building Bootloader+App [cmake]
  • #34944
    bflannery
    I am running into an issue when I try to build my Application that includes the bootloader as an embedded resource.
    The application runs entirely out of SRAM because the actual binary is stored in external flash memory.
    The bootloader builds and flashes fine when built/debug in isolation.
    The build process can’t make it past “Wrapping”
    The linker produces this error:
    [1/7] Updating EmbeddedResources.h
    [2/7] Wrapping C:/<redacted>/build/VisualGDB/Debug/<redacted>.bin
    FAILED: <redacted>_embedded_bin.o0
    cmd.exe /C "cd /D C:<redacted> && c:\SysGCC\arm-eabi\bin\arm-none-eabi-ld.exe -r -b binary C:<redacted>/build/VisualGDB/Debug/<redacted>.bin -o C:<redacted>/build/VisualGDB/Debug/<redacted>_embedded_bin.o0"
    c:\SysGCC\arm-eabi\bin\arm-none-eabi-ld.exe: final link failed: memory exhausted
    Any insight would be appreciated.
    #34945
    Looks like something about your project breaks the linker. As far as VisualGDB is concerned, it starts the build, sees the error message and reports it as expected.
    You can try enabling verbose mode, getting the exact gcc/linker command lines, and asking in the binutils mailing lists if you need further help.
    #34946
    bflannery
    Figured it out. I had a section in my bootloader linkerscript not markedĀ (NOLOAD) that should have been.
    #34973
    bflannery
    Is there any reason that the application bootloader would not be produced when built?
    I have theĀ GENERATE_BIN option on both BSP based executables. The bootloader target produces a .bin file but the application does not.
    #34974
    bflannery
    I mangled my first sentence in that last post. It should read:
    “Is there any reason that the application bin file would not be produced when built?”
    #34985
    Sorry, we are not aware of any specific setting that would interfere with it. If one project works distinctly different from another one, you can try comparing the project files side-by-side and merging differences between them to see at which point the behavior changes.
    #35039
    bflannery
    So you only get the binaries when you build at the cmake project level. If you right click and build the debug targets directly it does not generate the binary file or hex file. Only the elf.
