error running raspberry pi 3 target compiler
Sysprogs forums Forums VisualGDB error running raspberry pi 3 target compiler
  • #11702
    elinir2000
    The command: gcc -H -mcpu=cortex-a8 -mfloat-abi=hard -mfpu=neon arm1.cpp
    produces the executable but visualGDB produced the error:
    1 [Clang IntelliSense] Error: NEON intrinsics require NEON instruction set on target c:\dev\cpp\learn\arm4\arm4\arm_neon.h 4026 1
    Error 2 error : #error NEON intrinsics require NEON instruction set on target C:\dev\cpp\learn\arm4\arm4\arm_neon.h 4026 2 arm4
    Error 3 error : Command-line action failed C:\dev\cpp\learn\arm4\arm4\VisualGDB arm4
    #11704
    It looks like the arm_neon.h file contains some checks that deem the current configuration (determined from checking built-in preprocessor macros via #ifdef’s) invalid. The best way to investigate it would be to look into the file that produces the error and see which exact #ifdef tests it performs.
    #11708
    elinir2000
    Thank you.
    I have set these flags   -mcpu=cortex-a8 -mfloat-abi=hard -mfpu=neon -H     in CMake project settings in CFLAG and CXXFLAGS fields, but I got the same error as I do not believe that the compiler ‘sees’ these flags.
    Is there a way to see what flags are applied when the compiler is trying to produce the .o file and the executable ?
    Eli
    #11710
    Yes, you can add “VERBOSE=1” to make (not CMake) command template and rebuild the project. This should get CMake to print the command lines it is using.
