Sysprogs forums › Forums › VisualGDB › error MSB3073 exited with code 1
- This topic has 3 replies, 3 voices, and was last updated 6 years, 8 months ago by
June 1, 2017 at 13:29 #11365
karlis77
ParticipantHi. I got new PC with windows 10 and wanted to get all my projects from bit bucket but when I got them I can’t build them.
I can’t seem to find the solution for this error. I would really appreciate some help. You can see the errors and output below.
Error Command-line action failed Power_board_V1.7 C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7\VisualGDB 1
Error Build has failed. See the Output window for more details. Power_board_V1.7 C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7\EXEC 1
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7\Power_board_V1.7.vcxproj” “/solution:C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7.sln” “/config:Debug” “/platform:Win32″” exited with code 1. Power_board_V1.7 C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.MakeFile.Targets 441>—— Build started: Project: Power_board_V1.7, Configuration: Debug Win32 ——
1>VisualGDB : warning : Found a source file with spaces in the path: “C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7\..\..\..\..\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32\STM32F0xxxx\StartupFiles\startup_stm32f030xc.c”. If the build fails, please rename/move it.
1>VisualGDB: Run “cmd.exe /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug” in directory “C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7” on local computer
1>make: *** No rule to make target
../../../../AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F0xxxx/StartupFiles/startup_stm32f030xc.c', needed byDebug/startup_stm32f030xc.o’. Stop.1>————————————————————-
1>Command exited with code 2
1>Executable: cmd.exe
1>Arguments: /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug
1>Directory: C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7\Power_board_V1.7.vcxproj” “/solution:C:\Users\Raivis-STROPS\Desktop\power board kods\Power_board_V1.7.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
1>Done building project “Power_board_V1.7.vcxproj” — FAILED.
This topic was modified 8 years, 10 months ago by
karlis77.
June 2, 2017 at 01:47 #11378support
One big cause of tricky problems could be this one:
GNU Make really doesn’t support paths with spaces, so this may cause very strange bugs. Other than that, please try opening VisualGDB Project Properties and changing the MCU type back and forth. This should force VisualGDB to regenerate the relevant parts of the project.
This reply was modified 8 years, 10 months ago by
July 25, 2019 at 09:29 #25450SHA
Participanthow to changing the MCU type please ?
July 25, 2019 at 16:15 #25456support
KeymasterPlease use the first page of VisualGDB Project Properties to change the MCU type.
