Sysprogs forums › Forums › VisualGDB › Error compiling STemWin example
- This topic has 4 replies, 2 voices, and was last updated 8 years, 2 months ago by
AndyFraser.
January 13, 2018 at 15:16 #13424
AndyFraser
ParticipantI follow the steps here: https://visualgdb.com/tutorials/arm/stemwin/
But when I compile I get “Error Missing D:\bin\arm-eabi-gcc.exe”.
In project properties, the Toolchain is set “ARM in C:\SysGCC\arm-eabi”
What am I missing ?
Andy
January 13, 2018 at 23:16 #13430support
This looks like an incomplete toolchain installation. Please try restarting Visual Studio and creating a new project with the same toolchain. If it doesn’t help, please let us know if you are using GNU Make or MSBuild.
January 14, 2018 at 18:29 #13443AndyFraser
ParticipantI followed the same steps as the stemwin example but selected the simple LED blink project with the same results.
The stemwin example suggests MS Build which is what I used both times.
If I build LEDBlink with GNU make I get one warning about void.
If I build the stemwin example I get a lot of errors:
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TREEVIEW_CreateIndirect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WIDGET_Effect_Simple.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WIDGET.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TREEVIEW.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT_SetWrapMode.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT_SetTextColor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT_SetTextAlign.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT_SetText.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT_SetFont.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT_CreateIndirect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TEXT.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SLIDER_SkinFlex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SLIDER_Skin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SLIDER.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SCROLLBAR_SkinFlex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SCROLLBAR_Skin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SCROLLBAR.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR_SkinFlex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR_Skin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR_SetTextAlign.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR_SetMinMax.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR_SetFont.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR_CreateIndirect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(PROGBAR.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetSort.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetSel.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetRBorder.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetLBorder.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetItemColor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetGridVis.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_SetAutoScroll.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_InsertRow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_GetNumRows.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_GetNumColumns.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_GetHeader.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_DeleteRow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(ICONVIEW.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(HEADER_SkinFlex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(HEADER_Skin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(HEADER_SetDragLimit.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(HEADER_GetSel.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(HEADER.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DRAW.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ARRAY_ResizeItem.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ARRAY_InsertItem.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ARRAY_DeleteItem.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ARRAY.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GRAPH_SCALE.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GRAPH_DATA_YT.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GRAPH.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN_SkinFlex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN_Skin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN_SetColors.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN_Get.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN_CreateIndirect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(DIALOG.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(BUTTON_SkinFlex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(BUTTON_Skin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(BUTTON_CreateIndirect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(BUTTON.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__UpdateChildPositions.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__SendMessage.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__Screen2Client.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__IsEnabled.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__IsAncestor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_ValidateWindow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_UserData.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Timer.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Show.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetWindowPos.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetUserClipRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetTrans.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetSize.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetScrollbar.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetScrollState.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetFocusOnPrevChild.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetFocusOnNextChild.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetFocus.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetCreateFlags.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetCaptureMove.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetCapture.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SetCallback.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SendMessageNoPara.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_ResizeWindow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_NotifyParent.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_MoveChildTo.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Move.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Motion.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_MemDev.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_MakeModal.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_IsWindow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_IsVisible.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_IsFocussable.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Hide.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_HasFocus.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_HasCaptured.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetWindowSize.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetWindowRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetScrollbar.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetScrollState.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetScrollPartner.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetParent.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetOrg.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetNextSibling.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetInsideRectExScrollbar.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetInsideRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetId.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetFocussedWindow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetFlags.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetFirstChild.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetDialogItem.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetDesktopWindow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetClientWindow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetClientRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetBkColor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_CriticalHandle.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_CheckScrollPos.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_BringToTop.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_BringToBottom.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_Write.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_StaticDevices.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_SetOrg.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_Perspective.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_MoveAndFade.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_GetYSize.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_GetXSize.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_GetPos.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_GetDataPtr.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_CreateFixed.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_Banding.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_32.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FComic24B_ASCII.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F6x8.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F16_ASCII.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F13_ASCII.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F13_1.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F13B_ASCII.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F10S_ASCII.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(F08_ASCII.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDRV_Lin_32.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_UpdateColorIndices.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_SetClipRectEx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_Set.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_RLEAlpha.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_RLE4.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_Mirror.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_Info.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_GetEx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__strlen.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__sqrt32.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__memset.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__SinHQ.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__SetText.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__SetPixelAlpha.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__ReduceRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__ManageCache.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__IntersectRects.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__IntersectRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DrawTwinArc.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivideRound32.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__CompactPixelIndices.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__Alpha.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_WaitEvent.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Valf.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Val.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Timer.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Time.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_TOUCH.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Stream.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetTextMode.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetTextAlign.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetPixelIndex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetOrg.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetLineStyle.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetFont.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetDrawMode.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetDefault.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetColorIndex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetColor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetClipRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SetAlpha.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SelectLayer.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SelectLCD.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SaveContext.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SPRITE.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SIF_PropFrm.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SIF_PropExtFrmInfo.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_SIF.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_RectsIntersect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Realloc.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Pen.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_PID.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_OnKey.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_MoveRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_MergeRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_MULTIBUF.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Goto.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetYSizeOfFont.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetVersionString.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetStringDistX.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetOrg.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetLineStyle.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetFontSizeY.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetDrawMode.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetColor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetClientRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_GetBitmapPixelIndex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_FillRectEx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_FillRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Exec.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_EncExt.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawVLine.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawPixel.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawLine.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawHLine.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawGraphEx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawGradient.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawFocusRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap_A16.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap_8888.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap_565.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap_555.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap_444.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap_24.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmapMag.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawBitmap.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DispStringInRectWrap.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DispStringInRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DispStringHCenter.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DispStringAt.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DispString.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DispChar.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Device.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorHeaderM.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossSI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossS.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossMI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossM.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossLI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossL.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowSI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowS.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowMI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowM.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowLI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowL.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Curs1.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Core.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Color2Index.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ClearRectEx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Circ.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CharPExt.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CharP.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CharM.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CharLine.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Char.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_Alloc.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_AddDecShift.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_AddDecMin.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ALLOC_AllocZero.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_ALLOC_AllocInit.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_2DLib.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M8888I_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M888.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M565.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M555_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M444_16_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M444_12_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M444_12_1_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_888_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_8888_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_8888.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_888.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_565.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_555_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_444_16_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_444_12_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_444_12_1_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_0.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M8888I.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M4444I.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M1555I.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_88666I.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_8666.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_1616I.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_16.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIAA_Char4Ext.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIAA_Char4.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIAA_Char2Ext.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIAA_Char2.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WIDGET_SetEffect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WIDGET_Effect_None.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(TREEVIEW_Image.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SCROLLBAR_GetValue.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(SCROLLBAR_Create.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_GetWrapMode.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_GetSel.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_GetItemText.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LISTVIEW_DisableRow.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(FRAMEWIN__UpdateButtons.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__SendMessageNoPara.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__GetPrevSibling.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__GetLastSibling.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__GetFocussedChild.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__GetFirstSibling.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Touch.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_SendToParent.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_Screen2Win.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_PID__GetPrevState.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_OnKey.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_GetDesktopWindowEx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM_ForEachDesc.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_WriteToActiveOpaque.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_WriteToActiveAlpha.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_UsageBM.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_Usage.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_ReduceYSize.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUIDEV_Clear.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_SelectLCD.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_ReadRect.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_RLE8.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_RLE32.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_RLE16.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_NextPixelAPI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_GetPixelColor.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_GetP.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_GetNumDisplays.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_GetColorIndex.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(LCD_AA.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__strcmp.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__Wrap.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__Read.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__HandleEOLine.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__GetNumChars.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__GetFontSizeY.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__ExpandPixelIndices.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DrawBitmap16bpp.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivTbl_63_255.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivTbl_31_255.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivTbl_255_63.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivTbl_255_31.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivTbl_255_15.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI__DivTbl_15_255.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_UC_EncodeNone.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_UC.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_StreamCreate.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_FillPolygon.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_DrawPoint.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorPalI.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorPal.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorHeaderMPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossSPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossMPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorCrossLPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowSPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowMPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CursorArrowLPx.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUI_CalcColorDist.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(GUICC_M888_Index2Color.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__SendMessageIfEnabled.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__IsChild.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error C:\Users\xxxxxx\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/VendorSamples/STM32Cube_FW_F4_V1.16.0/Middlewares/ST/STemWin/Lib/STemWin532_CM4_GCC.a(WM__ForEachDesc.o) uses VFP register arguments, Debug/EmbeddedProject2.elf does not EmbeddedProject2 c:\sysgcc\arm-eabi\arm-eabi\bin\ld.exe 1
Error ld returned 1 exit status EmbeddedProject2 D:\VisualGDB\Projects\EmbeddedProject2\EmbeddedProject2\collect2.exe 1
Error Command-line action failed EmbeddedProject2 D:\VisualGDB\Projects\EmbeddedProject2\EmbeddedProject2\VisualGDB 1
Error Build has failed. See the Output window for more details. EmbeddedProject2 D:\VisualGDB\Projects\EmbeddedProject2\EmbeddedProject2\EXEC 1
Error MSB3073 The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /rebuild “D:\VisualGDB\Projects\EmbeddedProject2\EmbeddedProject2\EmbeddedProject2.vcxproj” “/solution:D:\VisualGDB\Projects\EmbeddedProject2\EmbeddedProject2.sln” “/config:Debug” “/platform:Win32″” exited with code 1. EmbeddedProject2 C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.MakeFile.Targets 49Andy
January 15, 2018 at 06:22 #13445support
This could happen if you were using the previous version of the STM32 BSP with the original GNU ARM toolchain (not the toolchain shipped by us). Please double-check that you have the latest version of the STM32 BSP.
January 15, 2018 at 23:34 #13465AndyFraser
ParticipantI re-installed the STM32 BSP and it is working fine now.
Thanks for your help.
Andy
