Error compiling ProfilerDriver_STM32_HAL.cpp
Sysprogs forums › Forums › VisualGDB › Error compiling ProfilerDriver_STM32_HAL.cpp
  • #25727
    Gordon01
    I’m using the latest version of VisualGDB (-r12) and immediately after adding “Fast Semihosting and Embedded Profiler” I cannot compile the project.
    The compiler says:
    1>ProfilerDriver_STM32_HAL.cpp
    1>C:/Users/waviot-research/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/ProfilerDriver_STM32_HAL.cpp: In function ‘void UpdateProfilerTimerFrequency()’:
    1>C:\Users\waviot-research\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\ProfilerDriver_STM32_HAL.cpp(108,31): error : ‘struct TIM_Base_InitTypeDef’ has no member named ‘RepetitionCounter’
    1> s_SamplingProfilerTimer.Init.RepetitionCounter = 0;
    1> ^~~~~~~~~~~~~~~~~
    1>Сборка проекта “AQUA3.vcxproj” завершена с ошибкой.
    If I comment out the 108s line of “ProfilerDriver_STM32_HAL.cpp” everything seems to be fine but that looks wrong.
    #25728
    Gordon01
    Additions: I was used version 1.1 of embedded profiler framework.
    After updating to latest version 3.1 I’m getting the same error but commenting out the line with
    doesn’t solve a problem, the compiler now says this:
    1>C:\Users\WAVIOT~1\AppData\Local\Temp\cc81gx2V.s: Assembler messages:
    1>C:\Users\WAVIOT~1\AppData\Local\Temp\cc81gx2V.s(343): error : immediate value out of range
    #25747
    Thanks for confirming your license status. It looks like you are using an STM32 device/firmware version that was not tested with our profiler framework. Please let us know your MCU type and any settings you explicitly specify in the wizard when creating the project, and we should be able to reproduce and fix the problem.
    #25752
    Gordon01
    The device is STM32L071KB.
    All settings in the wizard are defaults.
    #25755
    Thanks for getting back to us. We have released an update to the profiler framework resolving the issue. Please update it via Tools->VisualGDB->Manage VisualGDB Packages.
    #25759
    Gordon01
    Everything is working now, thank you for the support!
