Error: Can’t connect to virtualbox target host
Sysprogs forums Forums VisualDDK/VirtualKD discussion Error: Can’t connect to virtualbox target host
  • #138
    Hi all,,
    Help me, im a newbie for driver debugging
    i was install visualddk in visual studio 2008 team system, and im using VirtualBox v3.0.8
    but i can’t syncronyze visualddk with VirtualBox
    my virtualBox konfiguration like this:
    * using host-only to communicate real computer to virtual box host
    this is erro output in visualddk:
    Help me please,, and show me the right configuration for visualddk & virtualbox
    #1260
    Make sure that you can ping the VM from the host. I had to setup the host-to-VM networking stuff so that the VM could communicate with the host. Make sure firewalls are off or have the right ports open, in the VM the make sure the visuallDDK app is running as admin.
    Hope this helps a little
    #1261
    This problem is not related to network communication (pinging & etc).
    Did you install the VBoxDD.DLL file from VisualDDK according to installation instructions (http://virtualkd.sysprogs.org/#installation)?
    #1262
    Tanks for suggestion bazis,,,
    I’ve rename vboxdd.dll to vboxdd0.dll in virtual box directory and I’ve copied the vboxdd.dll from visualddk to virtualbox directory, but still problem…
    #1263
    Ok, did you run the VMINSTALL.EXE on the VM? Did you select the “Windows [VirtualKD]” as the operating system to boot on the VM?
    #1264
    I’ve installed on the target host vminstall.exe, and I was booting with the way the above…
    but still problem…. πŸ˜₯
    #1265
    Please try debugging using WinDbg+VirtualKD (start VMMON.EXE or VMMON64.EXE, select your VM, select the correct OS instance, press “Run Debugger” from VMMON).
    If the WinDbg debugging fails as well, double-check your VM settings and VirtualKD installation.
    If WinDbg debugging works, but VisualDDK still fails, ensure that the correct VM name is specified and that you are not running WinDbg while connecting from VisualDDK.
    Anyway, feel free to post here after you try WinDbg.
    #1266
    Bazis thanks to his guidance, your post is very helpful
    I was able to debug the driver using visualddk
