Environment variables in c++ via remote debug
Sysprogs forums › Forums › VisualGDB › Environment variables in c++ via remote debug
  • #779
    Lonko
    we are building app on build machine and deploying to target arm box.
    We need TZ environment variable set, so that all times in c++ are set correctly. But here comes a catch that i need a bit of help 🙂
    If i start the compiled program directly in shell on target box and the program executes:
    getenv("TZ") // returns  "MET-1MEDT,M3.5.0,M10.5.0/03:00" which is correct
    But when i do remote debugging
    getenv("TZ") // it always returns NULL!
    Any idea how to solve this? Why in remote debugging the env variables are not set?
    Best regards,
    Lonko
    #3039
    It’s a known bug that will be fixed in the next maintenance release. As a workaround, please switch the GDB mode to “Custom mode”, then click “customize” in the gdbserver command editor and specify your variables there.
