The IDF_PATH should actually be handled by VisualGDB directly. Normally it takes the list of IDF checkouts from the toolchain directory, however if you are keeping a custom checkout together with your codebase, we could add a per-user list of IDF checkouts. So once you configure (once per development machine) that the “com.yourcompany.idf-patched” is located in c:\projects\idf, VisualGDB will find it automatically from all projects.
