Enabling Reset Device After Programming wipes flash
Sysprogs forums › Forums › VisualGDB › Enabling Reset Device After Programming wipes flash
  • #27444
    curtis.hendrix
    I’m trying to track down an unrelated problem on an MKV31F256, and I checked the “Reset device After programming” option under VisualGDB Project Properties->Debug setting.
    Now when I start a debugging session, the program is written to flash and is then immediately erased.  It only happens when the “After programming” option is selected.  I’m watching flash with Segger’s J-Mem app set to refresh every 100msecs.  I can see the program get written to flash when I start a debugging session and then flash is immediately erase.
    Is this supposed to happen?  I would expect the “Reset device” device setting would be to reset the CPU, not reset the whole micro to factory defaults.
    #27446
    curtis.hendrix
    I think I just answered my own question.  Well, more like found a workaround.
    The J-Link was originally configured for the “allow security” option.  I changed that to the normal MKV31F256xxx under “Debugged device” and now it looks like everything is working.
