Embedded Linux. Can I use unit tests for the telnet target
Sysprogs forums › Forums › VisualGDB › Embedded Linux. Can I use unit tests for the telnet target
  • #27842
    viordash
    To debug and deploy code on my device (Soc Hi3518) I use telnet transport (https://visualgdb.com/tutorials/custom/transports/). SSH is not available
    How I can use the unit testing in this environment? When I make Run All, I see output, “Pipe-based test reporting only supported on SSH-based Linux targets”
    #27856
    This error happens because the tests use a separate pipe (created with mkfifo) to report structured tests outputs to VisualGDB, and telnet doesn’t allow easily multiplexing multiple streams.
    Does your target have mkfifo + netcat installed? If yes, please try checking if you can launch netcat in the background over telnet and let it forward a mkfifo-ed pipe to TCP. If yes, we can extend the custom target interface to allow running unit tests (your implementation would need to “open” a remote pipe and return a .Net Stream object corresponding to it, that will be independent from the regular telnet output).
    #27860
    viordash
    I’ll do it later and let you know
    #30940
    viordash
    Hi
    Sorry for the long absence.
    I have checked the utilities you mentioned, mkfifo + netcat. They are in the system and work.
    I would be very grateful if you extend the custom target interface so that I can fully run tests
    #30958
    No problem and thanks for your pull request with adding proper timeout handling to the telnet target.
    We have added a new ITargetWithRawPipes interface to VisualGDBExtensibility.dll that should be implemented by the telnet target:
    public interface ITargetWithRawPipes : ICustomRemoteTarget
        Stream OpenPipeForReading(string path);
    VisualGDB will call the OpenPipeForReading() method, supplying it the full path of the pipe on the Linux machine (e.g. /tmp/pipe). The target should open it and return a readable stream that VisualGDB will read from a background thread.
    Note that the pipe output can contain arbitrary bytes and not just printable characters, so the target may need special handling to escape/unescape them properly. We highly advise testing it by reading a test file containing all possible 256 byte values.
