Dynamic library debug
Sysprogs forums Forums VisualGDB Dynamic library debug
  • #7951
    Char
    My solution has tho projects main executable and *.so project that dynamicly loaded with dlopen.
    When i hit breakpoint in lib project – VisualGDB downloads this file from server instead of using project file?
    Or if it impossible can i apply defines to auto download sources?
    #7954
    The main project needs to reference the library projects. Then VisualGDB will automatically grab the path mappings from them when debugging the main project.
    Alternatively you can specify the mappings for the library sources manually via VisualGDB Project Properties -> Path Mapping.
    #7960
    Char
    Thak you. Path mapping good for me
    #8014
    Char
    Is it possible to make patch mapping different per user?
    for example if gui not exist – i can manually make CustomSourceDirectories sections in .user project file?
    #8016
    You can set per-user variables and simply reference them in the path mappings.
    #8027
    Char
    I know about per user variables. bit i want something different  behavior – i want add path mapping only for me, not different paths for different users.
    #8033
    This is not supported directly, however can be easily achieved with per-user variables: simply set them so that other users will have an irrelevant mapping (like /tmp/suchpath <=> c:\nosuchpath) and you will get the same effect.
    #8253
    Char
    If i use empty or not exist patch it dont add default patches to intellisence
    #8258
    Not sure what you meant. Adding a non-existent path to IntelliSense should have no effect and be the same as not adding any path there.
