Downgrading Embedded BSP version, how?
Sysprogs forums Forums VisualGDB Downgrading Embedded BSP version, how?
  • #11254
    RichardElex
    I have been developing an application on a Nordic NRF5x device on VisualGDB v12.0.
    Unfortunately, either by mistake or it did automatically, the version has upgraded to v13.0.
    Now I am getting errors and I have not found a way to select the older BSP.
    Going into Tools->Manage VisualGDB Packages, I can see both version v12.0 and v13.0v, but I can not see a way of selecting v12.0 anywhere in the VisualGDB properties or any where else.
    I am using:
    VisualGDB Embedded Edition version 5.2.
    Any help will be much appreciate.
    #11256
    You can download the previous versions of the BSPs here:  http://visualgdb.com/hwsupport/
    Then simply install them via “Install a package from file”
    #30778
    rayhu007
    In the tools menu -> Visual GDB -> Manage Visual GDB Packages
    check “show old versions”
    find the old version and download it, then you can use it in your code.
