Have to say it has been very bad experience using WinCDEmu on a vista 64bit.
First install, asked to get in test signing mode. Restarted computer, nothing happened. Guess need to restart the installation, this time works.
It takes a while to “finalize” the installation. Then click a .iso file, use popup menu to select mount, a “install new hardware” icon appears. After it runs a LONG time, it says it is finished, yet NOTHING appears. Not the cd drive, nothing indicates the image has been mounted, and apparently nothing in MyComputer shows the mounted CD.
Then restarted the computer, and tried to uninstall WinCDEmu, the uninstall says it is finished, yet NOTHING is removed. The folders are still there, the extensions for pop-up menus are still there. WTF! Had to manually remove things from uninstall menu, from disk, and from registry. Spent a good 4 hours carefully removing everything, and in the process unfortunately corrupted Winzip, so had to reinstall winzip. WTF!
Finally go back to Deamon Lite, took minutes to install and works instantly. I regretted I even though about using this tool. Guess lots has to be done before this project can be usable.
Usually I don’t spend any more minutes on a crappy software, but this being a opensoure one I would like to spend some time to share the experience so people can know the problems.
Keep working, folks!
