Define Remote machine using external variable
Sysprogs forums › Forums › VisualGDB › Define Remote machine using external variable
  • #34375
    lashmuelE
    I need to define connection in VisualGDB->Project settings->Remote Machine->Deployment machine using external/Environment variables. how can i do it?
    The reason for this is because we want that few users using the same project but each one wanna run the application on different machine without change the VisualGDB project settings, as every time you select different Deployment machine you actually change the vgdbsettings file unless you undo the selection change which we wanna avoid this solution.
    Best regards
    Shmuel
    #34376
    We would advise using SSH Host Aliases. You can find a detailed tutorial here: https://visualgdb.com/tutorials/linux/aliases/
