Debug vs Program ESP32
Sysprogs forums › Forums › VisualGDB › Debug vs Program ESP32
  • #32941
    Fastlane99
    I have finally “mastered”* Visual GDB and I am programming and debugging a Pi Pico via another Pico, and an ESP32 DevKitC via an Olimex ARM-USB-OCD-H.
    The issue I have (which I can get round messily) is that when I select “Start without debugging” I have no idea what is happening. The ESP32 appears to load, but it doesn’t run. In debug it is no problem.
    I get round it by right-clicking the project, selecting Visual GDB Project Properties, and selecting COM15 (the USB/serial connection). I would prefer if it simply loaded and ran the code.
    If it can’t, so be it.
    *kludged
    #32942
    According to our records, your license does not have an active technical support. If you believe it is a mistake, please contact our support via the contact form.
    #32946
    Fastlane99
    I have no idea if it has or not. Sorry, I thought this was a forum, not a technical support portal.
