I created a simple Arduino UNO project with the Built-in GDB simulator.
I followed your tutorial: https://visualgdb.com/tutorials/arduino/ and everything worked fine.
But if I want to debug the project and I jump across the delay(1000) routine, the debugger gets stuck.
If I remove the delays, it works fine.
Is this a limitation of the built-in GDB simulator?
PS: If I set the breakpoint under the delay routines, the debugger will never trigger the breakpoint (see attached screenshot).
You must be
