Custom WinDBG command line.
Sysprogs forums Forums Other tools & products Custom WinDBG command line.
  • #201
    I user windbg over virtualKD pipe to debug both x64 and x86 OS’s. My host is Windows 7 x64. I would like vmmon64 to automatically launch WinDBG with the commandline that I specify. I don’t need to change the command line depending on the guest OS (but this feature would be extremely helpful), but vmmon should simply append the command line options I specify. I wonder if this is possible without modyfying the source.
    I can’t really use the custom launch setting becuase the pipe name changes, it would require me to change the command line everytime.
    Senthil
    #1446
    Senthil
    All right, modified the code to do the same.
    Still I am wondering if I could have gotten away without re-building it.
    Senthil
