Sysprogs forums › Forums › VisualGDB › Custom RTOS support fails at stack-list-frames
- This topic has 10 replies, 2 voices, and was last updated 8 years, 7 months ago by
August 29, 2017 at 12:18 #12209
Otatiaro
ParticipantHello,
I’m having an issue with custom RTOS support. It was previously working, but I did a lot of refactoring (names only) and now it always hangs when trying to get the stack frames of my threads.
Here is the GDB log:
<div>VisualGDB is licensed to Thomas Legrand at EZNOV
e:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi D:\GIT\remote\Firmware\VisualGDB\Debug\MantaRemote.elf
-gdb-version
=thread-group-added,id=”i1″
GNU gdb (GDB) 7.12
Copyright (C) 2016 Free Software Foundation, Inc.
This GDB was configured as “–host=i686-pc-mingw32 –target=arm-eabi”.
For help, type “help”.
Reading symbols from D:\GIT\remote\Firmware\VisualGDB\Debug\MantaRemote.elf…
done.
GNU gdb (GDB) 7.12
OK
-list-features
No symbol “disassembly” in current context.
-gdb-set print demangle off
OK
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015f98″,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”83″,thread-groups=[“i1″],times=”0″,original-location=”main”}
target remote :62754
&”target remote :62754\n”
Remote debugging using :62754
__NOP () at src/opsy/Vendor/STM32/../cmsis_gcc.h:375
375 __ASM volatile (“nop”);
*stopped,frame={addr=”0x08015da0″,func=”__NOP”,args=[],file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”,line=”375″},thread-id=”1″,stopped-threads=”all”
OK
mon reset
&”mon reset\n”
Resetting target
OK
info shared
&”info shared\n”
No shared libraries loaded at this time.
OK
load
&”load\n”
Loading section boot_vector, size 0x10000 lma 0x8000000
+download,{section=”boot_vector”,section-size=”65536″,total-size=”564346″}
+download,{section=”boot_vector”,section-sent=”16352″,section-size=”65536″,total-sent=”16352″,total-size=”564346″}
Loading section .text, size 0x8620 lma 0x8010000
+download,{section=”.text”,section-size=”34336″,total-size=”564346″}
Loading section .rodata, size 0x8264 lma 0x8018620
+download,{section=”.rodata”,section-size=”33380″,total-size=”564346″}
Loading section .ARM, size 0x8 lma 0x8020884
+download,{section=”.ARM”,section-size=”8″,total-size=”564346″}
Loading section .init_array, size 0x10 lma 0x802088c
+download,{section=”.init_array”,section-size=”16″,total-size=”564346″}
Loading section .fini_array, size 0x4 lma 0x802089c
+download,{section=”.fini_array”,section-size=”4″,total-size=”564346″}
Loading section .data, size 0x6c lma 0x80208a0
+download,{section=”.data”,section-size=”108″,total-size=”564346″}
Start address 0x8015f94, load size 133388
Transfer rate: 13026 KB/sec, 8892 bytes/write.
OK
mon reset
&”mon reset\n”
Resetting target
OK
-data-evaluate-expression “sizeof(void *)”
^done,value=”4″
-data-evaluate-expression “sizeof(int)”
^done,value=”4″
-data-evaluate-expression “sizeof(short)”
-data-evaluate-expression “sizeof(long)”
^done,value=”2″
^done,value=”4″
-data-evaluate-expression “sizeof(long long)”
^done,value=”8″
-data-evaluate-expression “sizeof(char)”
^done,value=”1″
-data-evaluate-expression “sizeof(wchar_t)”
^done,value=”4″
-data-evaluate-expression “sizeof(float)”
^done,value=”4″
-data-evaluate-expression “sizeof(double)”
^done,value=”8″
-data-evaluate-expression “sizeof(long double)”
^done,value=”8″
info target
&”info target\n”
Symbols from “D:\GIT\remote\Firmware\VisualGDB\Debug\MantaRemote.elf”.
Remote serial target in gdb-specific protocol:
Debugging a target over a serial line.
While running this, GDB does not access memory from…
Local exec file:
`D:\GIT\remote\Firmware\VisualGDB\Debug\MantaRemote.elf’, file type elf32-littlearm.
Entry point: 0x8015f94
0x08000000 – 0x08010000 is boot_vector
0x08010000 – 0x08018620 is .text
0x08018620 – 0x08020884 is .rodata
0x08020884 – 0x0802088c is .ARM
0x0802088c – 0x0802089c is .init_array
0x0802089c – 0x080208a0 is .fini_array
0x20000000 – 0x2000006c is .data
0x20000200 – 0x20006174 is .bss
OK
-break-insert -f D:/GIT/remote/Firmware/src/main.cpp:48
^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015dfa”,func=”<lambda(uint32_t)>::operator()(uint32_t) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”48″,thread-groups=[“i1″],times=”0″,original-location=”D:/GIT/remote/Firmware/src/main.cpp:48″}
-break-after 2 0
OK
info symbol 0x8015dfa
&”info symbol 0x8015dfa\n”
_ZNKUlmE0_clEm + 10 in section .text
OK
info line *0x8015dfa
&”info line *0x8015dfa\n”
Line 48 of “src/main.cpp” starts at address 0x8015dfa <<lambda(uint32_t)>::operator()(uint32_t) const+10> and ends at 0x8015dfe <<lambda(uint32_t)>::operator()(uint32_t) const+14>.
OK
-file-list-exec-source-files
^done,files=[{file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”},{file=”src/opsy/Kernel/task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/../Logs/ListenerBase.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\ListenerBase.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Logs/breakOnSeverity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\breakOnSeverity.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/drivers/buzzer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\buzzer.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/drivers/imu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.hpp”},{file=”src/userInterface.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\userInterface.hpp”},{file=”src/opsy/Logs/sysviewListener.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\sysviewListener.hpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/opsy/Vendor/STM32/stm32l471xx.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\STM32\\stm32l471xx.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdint.h”},{file=”src/opsy/Kernel/svcCallEnum.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\svcCallEnum.hpp”},{file=”src/opsy/Kernel/waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Kernel/../Logs/Severity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\Severity.hpp”},{file=”src/opsy/Matrix/point.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\point.hpp”},{file=”src/opsy/Kernel/../Vendor/Segger/SEGGER_SYSVIEW.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_SYSVIEW.h”},{file=”src/opsy/Kernel/../Data/fifo.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Data\\fifo.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/c++config.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\c++config.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/cpp_type_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\cpp_type_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cmath”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cmath”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/type_traits”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\type_traits”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/stl_pair.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\stl_pair.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/exception_ptr.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\exception_ptr.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug/debug.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug\\debug.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cwchar”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cwchar”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdint”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdint”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/new”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\new”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/clocale”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\clocale”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdlib”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdlib”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdio”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdio”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/basic_string.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\basic_string.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/predefined_ops.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\predefined_ops.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/new_allocator.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\new_allocator.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/numeric_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\numeric_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stddef.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stddef.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/lock.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\lock.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/reent.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\reent.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stdarg.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stdarg.h”},{file=”<built-in>”,fullname=”D:\\GIT\\remote\\Firmware/<built-in>”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/wchar.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\wchar.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/locale.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\locale.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/ctype.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\ctype.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdlib.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdlib.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdio.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdio.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/errno.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\errno.h”},{file=”src/graphics/color.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\color.hpp”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/reent.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/reent.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/mlock.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/mlock.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/string/strnlen.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-nano-2016q3/newlib/libc/string/strnlen.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/sbrkr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/sbrkr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”},{file=”../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/memcpy-armv7m.S”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/memcpy-armv7m.S”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/malloc.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/malloc.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/misc/init.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/misc/../../../../../../../../newlib-nano-2016q3/newlib/libc/misc/init.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/impure.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/impure.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/errno/errno.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/errno/../../../../../../../../newlib-nano-2016q3/newlib/libc/errno/errno.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/cxa_atexit.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/cxa_atexit.c”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/lib1funcs.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/lib1funcs.S”},{file=”../../../../../../gcc-6.2.0/libgcc/libgcc2.c”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/libgcc2.c”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-sf.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-sf.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_copysign.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_copysign.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_scalbn.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_scalbn.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_nan.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_nan.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_finite.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_finite.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/sf_fabs.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/sf_fabs.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/common/s_rint.c”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/common/s_rint.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/s_rint.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/s_rint.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_nan.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_nan.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_matherr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_matherr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_lib_ver.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_lib_ver.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_sqrt.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_sqrt.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_pow.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_pow.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log10.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log10.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_fmod.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_fmod.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_pow.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_pow.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_log10.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_log10.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_fmod.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_fmod.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/math/sf_floor.c”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/math/sf_floor.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/sf_floor.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/sf_floor.c”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_op.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_op.cc”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_ops.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_ops.cc”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/atexit_arm.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/atexit_arm.cc”},{file=”src/opsy/Vendor/Segger/SEGGER_SYSVIEW.c”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_SYSVIEW.c”},{file=”src/opsy/Vendor/Segger/SEGGER_RTT.c”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_RTT.c”},{file=”src/opsy/Logs/logger.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.cpp”},{file=”src/opsy/Kernel/systemView.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.cpp”},{file=”src/opsy/Kernel/../Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/scheduler.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.cpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/drivers/screen.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.cpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/drivers/imu.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/drivers/btnInputs.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/userInterface.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\userInterface.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”src/opsy/Logs/sysviewListener.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\sysviewListener.hpp”},{file=”src/userInterface.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\userInterface.hpp”},{file=”src/drivers/imu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/drivers/buzzer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\buzzer.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/opsy/Logs/breakOnSeverity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\breakOnSeverity.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”src/opsy/Kernel/../Logs/ListenerBase.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\ListenerBase.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”}]
-break-insert -f D:/GIT/remote/Firmware/src/main.cpp:123
^done,bkpt={number=”3″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015fd4″,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”123″,thread-groups=[“i1″],times=”0″,original-location=”D:/GIT/remote/Firmware/src/main.cpp:123″}
-break-after 3 0
OK
info symbol 0x8015fd4
&”info symbol 0x8015fd4\n”
main + 64 in section .text
OK
info line *0x8015fd4
&”info line *0x8015fd4\n”
Line 123 of “src/main.cpp” starts at address 0x8015fd4 <main()+64> and ends at 0x8015fe4 <main()+80>.
OK
-break-insert -f D:/GIT/remote/Firmware/src/opsy/Kernel/scheduler.hpp:77
^done,bkpt={number=”4″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0801309a”,func=”opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”77″,thread-groups=[“i1″],times=”0″,original-location=”D:/GIT/remote/Firmware/src/opsy/Kernel/scheduler.hpp:77″}
-break-after 4 0
OK
info symbol 0x801309a
&”info symbol 0x801309a\n”
_ZN4opsy6kernel9scheduler5startEmmPmRNS0_9idle_taskE + 210 in section .text
OK
info line *0x801309a
&”info line *0x801309a\n”
Line 77 of “src/opsy/Kernel/scheduler.hpp” starts at address 0x801309a <opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)+210> and ends at 0x80130a0 <opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)+216>.
OK
-break-insert -f *0x080130c0
^done,bkpt={number=”5″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080130c0″,func=”opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)”,file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”,line=”190″,thread-groups=[“i1″],times=”0″,original-location=”*0x080130c0″}
-break-after 5 0
OK
-break-disable 5
OK
info symbol 0x80130c0
&”info symbol 0x80130c0\n”
_ZN4opsy6kernel9scheduler5startEmmPmRNS0_9idle_taskE + 248 in section .text
OK
info line *0x80130c0
&”info line *0x80130c0\n”
Line 190 of “src/opsy/Vendor/STM32/../cmsis_gcc.h” starts at address 0x80130be <opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)+246> and ends at 0x80130c4 <opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)+252>.
OK
-break-insert -f D:/GIT/remote/Firmware/src/startup.cpp:117
^done,bkpt={number=”6″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080168ce”,func=”boot()”,file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”,line=”117″,thread-groups=[“i1″],times=”0″,original-location=”D:/GIT/remote/Firmware/src/startup.cpp:117″}
-break-after 6 0
OK
info symbol 0x80168ce
&”info symbol 0x80168ce\n”
boot + 158 in section .text
OK
info line *0x80168ce
&”info line *0x80168ce\n”
Line 117 of “src/startup.cpp” starts at address 0x80168ce <boot()+158> and ends at 0x80168d2 <boot()+162>.
OK
-data-evaluate-expression “&_estack”
^done,value=”0x20017ffc \”$\224a#\”<error: Cannot access memory at address 0x20018000>”
-var-create – * “*((void **)0x20017ff8)”
^done,name=”var1″,numchild=”0″,value=”0xfffffffd”,type=”void *”,has_more=”0″
-var-assign “var1″ 0x61c99259
^done,value=”0x61c99259”
-data-evaluate-expression “\*\(\(void\ \*\*\)0x20017ff8\)”
^done,value=”0x61c99259″
1000-interpreter-exec console flushregs
Register cache flushed.
1000^done
-exec-continue
^running
*running,thread-id=”all”
=breakpoint-modified,bkpt={number=”6″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080168ce”,func=”boot()”,file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”,line=”117″,thread-groups=[“i1″],times=”1″,original-location=”D:/GIT/remote/Firmware/src/startup.cpp:117″}</div>
<div>Breakpoint 6, boot () at src/startup.cpp:117
117 main();
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”6″,frame={addr=”0x080168ce”,func=”boot”,args=[],file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”,line=”117″},thread-id=”1″,stopped-threads=”all”
-data-evaluate-expression “opsy::kernel::scheduler::is_started_”
^done,value=”false”
-break-after 6 0
OK
1001-interpreter-exec console flushregs
1001^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x080168ce”,func=”boot”,file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”,line=”117″},frame={level=”1″,addr=”0xfffffffe”,func=”??”}]
-stack-list-arguments 0
^done,stack-args=[frame={level=”0″,args=[]},frame={level=”1″,args=[]}]
-stack-list-frames
-stack-list-frames
-stack-list-frames
-stack-select-frame 0
OK
1002-interpreter-exec console flushregs
1002^done
-break-delete 1
OK
-exec-step
^running
*stopped,reason=”end-stepping-range”,frame={addr=”0x08015f98″,func=”main”,args=[],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”83″},thread-id=”1″,stopped-threads=”all”
^done,value=”false”
1003-interpreter-exec console flushregs
1003^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x08015f98″,func=”main”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”83″}]
^done,stack-args=[frame={level=”0″,args=[]}]
-stack-list-frames
-stack-list-frames
1004-interpreter-exec console flushregs
1004^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”3″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015fd4″,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”123″,thread-groups=[“i1″],times=”1″,original-location=”D:/GIT/remote/Firmware/src/main.cpp:123″}</div>
<div>Breakpoint 3, main () at src/main.cpp:123
123 scheduler::start(SystemCoreClock, 1000, &__linkStack, idle);
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”3″,frame={addr=”0x08015fd4″,func=”main”,args=[],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”123″},thread-id=”1″,stopped-threads=”all”
^done,value=”false”
-break-after 3 0
OK
1005-interpreter-exec console flushregs
1005^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x08015fd4″,func=”main”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”123″}]
-stack-list-frames
-stack-list-frames
1006-interpreter-exec console flushregs
1006^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”4″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0801309a”,func=”opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”77″,thread-groups=[“i1″],times=”1″,original-location=”D:/GIT/remote/Firmware/src/opsy/Kernel/scheduler.hpp:77″}</div>
<div>Breakpoint 4, opsy::kernel::scheduler::start (core_clock=80000000, tick_clock=1000, main_stack_pointer=0x20017ffc, idle_task=…) at src/opsy/Kernel/scheduler.hpp:77
77 is_started_ = true;
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”4″,frame={addr=”0x0801309a”,func=”opsy::kernel::scheduler::start”,args=[{name=”core_clock”,value=”80000000″},{name=”tick_clock”,value=”1000″},{name=”main_stack_pointer”,value=”0x20017ffc”},{name=”idle_task”,value=”…”}],file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”77″},thread-id=”1″,stopped-threads=”all”
^done,value=”false”
-break-after 4 0
OK
1007-interpreter-exec console flushregs
1007^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x0801309a”,func=”opsy::kernel::scheduler::start”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”77″},frame={level=”1″,addr=”0x08015fe4″,func=”main”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”123″}]
^done,stack-args=[frame={level=”0″,args=[name=”core_clock”,name=”tick_clock”,name=”main_stack_pointer”,name=”idle_task”]},frame={level=”1″,args=[]}]
-stack-list-frames
-stack-list-frames
1008-interpreter-exec console flushregs
1008^done
-exec-continue
^running
=breakpoint-modified,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015dfa”,func=”<lambda(uint32_t)>::operator()(uint32_t) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”48″,thread-groups=[“i1″],times=”1″,original-location=”D:/GIT/remote/Firmware/src/main.cpp:48″}</div>
<div>Breakpoint 2, <lambda(uint32_t)>::operator()(uint32_t) const (__closure=0x0, param=0) at src/main.cpp:48
48 screen::reset();
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”2″,frame={addr=”0x08015dfa”,func=”<lambda(uint32_t)>::operator()(uint32_t) const”,args=[{name=”__closure”,value=”0x0″},{name=”param”,value=”0″}],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”48″},thread-id=”1″,stopped-threads=”all”
^done,value=”true”
-data-evaluate-expression “opsy::kernel::scheduler::active_tasks_count_”
^done,value=”1″
-data-evaluate-expression “opsy::kernel::scheduler::first_task_”
^done,value=”0x20000328 <check>”
-data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20000328\)\)\.name_”
^done,value=”0x8018728 \”Check\””
-data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20000328\)\)\.stack_pointer_”
^done,value=”0x20004334 <check+16396>”
-data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20000328\)\)\.next_task_”
^done,value=”0x0″
-data-evaluate-expression “opsy::kernel::scheduler::current_task_”
-break-after 2 0
OK
1009-interpreter-exec console flushregs
1009^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x08015dfa”,func=”<lambda(uint32_t)>::operator()(uint32_t) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”48″},frame={level=”1″,addr=”0x08015e68″,func=”<lambda(uint32_t)>::_FUN(uint32_t)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”69″},frame={level=”2″,addr=”0x08013820″,func=”opsy::kernel::scheduler::default_isr_handler”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”666″},frame={level=”3″,addr=”0x08018800″,func=”_ZTVN4opsy4logs17break_on_severityE”}]
^done,stack-args=[frame={level=”0″,args=[name=”__closure”,name=”param”]},frame={level=”1″,args=[]},frame={level=”2″,args=[]},frame={level=”3″,args=[]}]
-stack-list-frames
-stack-list-frames
-stack-list-frames
1010-interpreter-exec console flushregs
1010^done
-exec-continue
^running
Program
received signal SIGTRAP, Trace/breakpoint trap.
<lambda()>::operator()(void) const (__closure=0x0) at src/main.cpp:37
37 __NOP();
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x08015da0″,func=”<lambda()>::operator()(void) const”,args=[{name=”__closure”,value=”0x0″}],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”37″},thread-id=”1″,stopped-threads=”all”
^done,value=”true”
^done,value=”1″
^done,value=”0x20004270 <check+16200>”
^done,value=”0x0″
^done,value=”0x0″
^done,value=”0x0″
1011-interpreter-exec console flushregs
1011^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x08015da0″,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”37″},frame={level=”1″,addr=”0x08015dae”,func=”<lambda()>::_FUN(void)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”42″},frame={level=”2″,addr=”0x00000000″,func=”??”}]
^done,stack-args=[frame={level=”0″,args=[name=”__closure”]},frame={level=”1″,args=[]},frame={level=”2″,args=[]}]
-stack-list-frames
-stack-list-frames
^done,value=”0x0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[0]”
^done,value=”4294967277″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[1]”
^done,value=”5″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[2]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[3]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[4]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[5]”
^done,value=”536888132″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[6]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[7]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[8]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[9]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[10]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[11]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[12]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[13]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[14]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[15]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[16]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[17]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[18]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[19]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[20]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[21]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[22]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[23]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[24]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[25]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[26]”
^done,value=”1000″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[27]”
^done,value=”4294967295″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[28]”
^done,value=”1073808384″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[29]”
^done,value=”1000″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[30]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[31]”
^done,value=”134307411″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[32]”
^done,value=”134296222″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[33]”
^done,value=”1627390464″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[34]”
^done,value=”1066401792″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[35]”
^done,value=”1065353216″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[36]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[37]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[38]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[39]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[40]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[41]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[42]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[43]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[44]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[45]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[46]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[47]”
^done,value=”1132462080″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[48]”
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20004270\)\)\[49]”
^done,value=”1059900621″
-data-evaluate-expression “\$CONTROL”
^done,value=”void”
-data-evaluate-expression “\$r4″
^done,value=”0”
-data-evaluate-expression “\$r5″
^done,value=”0”
-data-evaluate-expression “\$r6″
^done,value=”0”
-data-evaluate-expression “\$r7″
^done,value=”536871696”
-data-evaluate-expression “\$r8″
^done,value=”0”
-data-evaluate-expression “\$r9″
^done,value=”0”
-data-evaluate-expression “\$r10″
^done,value=”0”
-data-evaluate-expression “\$r11″
^done,value=”0”
-data-evaluate-expression “\$s31″
^done,value=”0”
-data-evaluate-expression “\$s30″
^done,value=”0”
-data-evaluate-expression “\$s29″
^done,value=”0”
-data-evaluate-expression “\$s28″
^done,value=”0”
-data-evaluate-expression “\$s27″
^done,value=”0”
-data-evaluate-expression “\$s26″
^done,value=”0”
-data-evaluate-expression “\$s25″
^done,value=”0”
-data-evaluate-expression “\$s24″
^done,value=”0”
-data-evaluate-expression “\$s23″
^done,value=”0”
-data-evaluate-expression “\$s22″
^done,value=”0”
-data-evaluate-expression “\$s21″
^done,value=”0”
-data-evaluate-expression “\$s20″
^done,value=”0”
-data-evaluate-expression “\$s19″
^done,value=”0”
-data-evaluate-expression “\$s18″
^done,value=”0”
-data-evaluate-expression “\$s17″
^done,value=”0”
-data-evaluate-expression “\$s16″
^done,value=”0”
-data-evaluate-expression “\$r13″
^done,value=”0x20000310 <idle+236>”
-data-evaluate-expression “\$r0″
^done,value=”0”
-data-evaluate-expression “\$r1″
^done,value=”0”
-data-evaluate-expression “\$r2″
^done,value=”0”
-data-evaluate-expression “\$r3″
^done,value=”0”
-data-evaluate-expression “\$r12″
^done,value=”0”
-data-evaluate-expression “\$lr”
^done,value=”134307247″
-data-evaluate-expression “\$pc”
^done,value=”0x8015da0 <<lambda()>::operator()(void) const+8>”
-data-evaluate-expression “\$r15″
-data-evaluate-expression “\$xPSR”
^done,value=”void”
-data-evaluate-expression “\$s15″
^done,value=”47.9249992”
-data-evaluate-expression “\$s14″
^done,value=”0.0304878056”
-data-evaluate-expression “\$s13″
^done,value=”333.869995”
-data-evaluate-expression “\$s12″
^done,value=”0”
-data-evaluate-expression “\$s11″
^done,value=”0”
-data-evaluate-expression “\$s10″
^done,value=”0”
-data-evaluate-expression “\$s9″
^done,value=”0”
-data-evaluate-expression “\$s8″
^done,value=”0”
-data-evaluate-expression “\$s7″
^done,value=”0”
-data-evaluate-expression “\$s6″
^done,value=”0”
-data-evaluate-expression “\$s5″
^done,value=”0”
-data-evaluate-expression “\$s4″
^done,value=”0”
-data-evaluate-expression “\$s3″
^done,value=”0”
-data-evaluate-expression “\$s2″
^done,value=”0”
-data-evaluate-expression “\$s1″
^done,value=”0”
-data-evaluate-expression “\$s0″
^done,value=”0″
1012-interpreter-exec console flushregs
1013-gdb-set $r4=0x0
1014-gdb-set $r5=0x0
1015-gdb-set $r6=0x0
1016-gdb-set $r7=0x20004344
1017-gdb-set $r8=0x0
1018-gdb-set $r9=0x0
1019-gdb-set $r10=0x0
1020-gdb-set $r11=0x0
1021-gdb-set $s31=0x0
1022-gdb-set $s30=0x0
1023-gdb-set $s29=0x0
1024-gdb-set $s28=0x0
1025-gdb-set $s27=0x0
1026-gdb-set $s26=0x0
1027-gdb-set $s25=0x0
1028-gdb-set $s24=0x0
1029-gdb-set $s23=0x0
1030-gdb-set $s22=0x0
1031-gdb-set $s21=0x0
1032-gdb-set $s20=0x0
1033-gdb-set $s19=0x0
1034-gdb-set $s18=0x0
1035-gdb-set $s17=0x0
1036-gdb-set $s16=0x0
1037-gdb-set $r13=0x20004208
1038-gdb-set $r0=0x3e8
1039-gdb-set $r1=0xffffffff
1040-gdb-set $r2=0x40010400
1041-gdb-set $r3=0x3e8
1042-gdb-set $r12=0x0
1043-gdb-set $lr=0x8015e53
1044-gdb-set $pc=0x801329e
1045-gdb-set $r15=0x801329e
1046-gdb-set $s12=0x0
1047-gdb-set $s11=0x0
1048-gdb-set $s10=0x0
1049-gdb-set $s9=0x0
1050-gdb-set $s8=0x0
1051-gdb-set $s7=0x0
1052-gdb-set $s6=0x0
1053-gdb-set $s5=0x0
1054-gdb-set $s4=0x0
1055-gdb-set $s3=0x0
1056-gdb-set $s2=0x43800000
1057-gdb-set $s1=0x3f900000
1058-gdb-set $s0=0x3f2ccccd
1012^done
1013^done
-stack-list-frames
-stack-list-frames 0 0
The target is not responding to GDB commands.
Stop debugging it?
(y or n) [answered Y; input not from terminal]
=thread-group-exited,id=”i1″
&”Disconnected from target.\n”
../../gdb-7.12/gdb/target.c:2752: internal-error: Can’t determine the current address space of thread process 42000</div>
<div>A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session?
&”\nThis is a bug, please report it.”
&” For instructions, see:\n<http://www.gnu.org/software/gdb/bugs/>.”
&”\n\n”
Create a core file of GDB?
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.</div>
I tried to find this error in GDB sources, found it but it doesn’t really help understand what’s going on … Also when I can get some useful stuff out of my threads (like having only one thread and stopping in its execution, so that it doesn’t rely on RTOS to find the stacks), I get additional stack frames on the bottom of the stack (pointing to different code, or vtable of a different class, whatever).
I’m obviously doing something wrong here, but I’m on it for hours and can’t find a solution 🙁
Thomas.
August 29, 2017 at 13:54 #12211Otatiaro
ParticipantOk I did solve one of the problems, having a wrong stack trace from my tasks.
The answer is pretty funny:
- when a task is finished (the function returns), the task stack (LR especially) is configured to atuomatically call “terminate_current_task()”, so LR is set at the start of this function.
- but GDB does not want to know where the LR points, it wants to know where was the branch that lead to the jump
- so GDB uses the instruction JUST BEFORE the instruction pointer in LR
- in my case, LR was set to the first instruction of the terminate_current_task() function, so GDB was thinking it was called from the previous instruction, which is not, and which is at the very end of another function (in this case, the default_isr_handler()), but then GDB checks the stack allocation for this -wrong- function, and tries to extract the stack frame
- and it’s messed up, GDB tries to interpret garbage data as stack frames.
The solution is … creative:
- my terminate_current_task() function is a function that only calls an SVC service to kill the current task, so I made it naked (no problem), and added a nop assembly instruction at the very end, this will act as a dummy instruction
- then when I configure the task to return to terminate_current_task(), I do not point to the function start, but 2 bytes later, just after the nop instruction (nop is 2 bytes long)
- GDB now thinks the “calling instruction” is the nop, LR works (skips the nop instruction, which is nice …), and I get the correct stack frame, with terminate_current_task() at the very bottom
That’s one problem solved (I used segger ozone to debug at very low level), but, VisualGDB still hangs when trying to display the thread list (and there is a non-running thread). I really need help here.
Thomas.
August 29, 2017 at 22:53 #12215support
KeymasterThe hang could be caused by an issue we recently discovered and fixed. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.7.1759.msi
If the problem persists, please try checking the gdb log for the last commands issued by VisualGDB (you can enable diagnostic gdb logging via the Advanced GDB Settings page of VisualGDB Project Properties).
August 30, 2017 at 10:10 #12224Otatiaro
ParticipantHello,
I’m afraid my problem is not fixed in 1759 🙁
Here is the log:
[ 0 ms] -gdb-version
[ 27 ms] =thread-group-added,id=”i1″
[ 37 ms] ~”GNU gdb (GDB) 7.12\n”
[ 37 ms] ~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
[ 37 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \”show copying\”\nand \”show warranty\” for details.\n”
[ 37 ms] ~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
[ 37 ms] ~”\nFor bug reporting instructions, please see:\n”
[ 37 ms] ~”<http://www.gnu.org/software/gdb/bugs/>.\n”
[ 37 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n”
[ 37 ms] ~”For help, type \”help\”.\n”
[ 37 ms] ~”Type \”apropos word\” to search for commands related to \”word\”…\n”
[ 37 ms] ~”Reading symbols from D:\\GIT\\remote\\Firmware\\VisualGDB\\Debug\\MantaRemote.elf…”
[ 39 ms] ~”done.\n”
[ 51 ms] ~”GNU gdb (GDB) 7.12\n”
[ 51 ms] ~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
[ 52 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \”show copying\”\nand \”show warranty\” for details.\n”
[ 52 ms] ~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
[ 52 ms] ~”\nFor bug reporting instructions, please see:\n”
[ 52 ms] ~”<http://www.gnu.org/software/gdb/bugs/>.\n”
[ 53 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n”
[ 53 ms] ~”For help, type \”help\”.\n”
[ 53 ms] ~”Type \”apropos word\” to search for commands related to \”word\”.\n”
[ 53 ms] ^done
[ 55 ms] -list-features
[ 63 ms] ^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”]
[ 66 ms] -gdb-set disassembly-flavor intel
[ 75 ms] ^error,msg=”No symbol \”disassembly\” in current context.”
[ 75 ms] -gdb-set print demangle off
[ 75 ms] ^done
[ 164 ms] -break-insert -f main
[ 166 ms] ^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015eb8″,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”92″,thread-groups=[“i1″],times=”0″,original-location=”main”}
[ 178 ms] target remote :53339
[ 186 ms] &”target remote :53339\n”
[ 196 ms] ~”Remote debugging using :53339\n”
[ 201 ms] =thread-group-started,id=”i1″,pid=”42000″
[ 202 ms] =thread-created,id=”1″,group-id=”i1″
[ 215 ms] ~”<lambda()>::operator()(void) const (__closure=0x0) at src/main.cpp:35\n”
[ 215 ms] ~”35\t\t\t__NOP();\n”
[ 215 ms] *stopped,frame={addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,args=[{name=”__closure”,value=”0x0″}],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},thread-id=”1″,stopped-threads=”all”
[ 225 ms] ^done
[ 225 ms] mon reset
[ 235 ms] &”mon reset\n”
[ 306 ms] @”Resetting target\r\n”
[ 306 ms] ^done
[ 306 ms] info shared
[ 314 ms] &”info shared\n”
[ 314 ms] ~”No shared libraries loaded at this time.\n”
[ 314 ms] ^done
[ 314 ms] load
[ 324 ms] &”load\n”
[ 324 ms] ~”Loading section boot_vector, size 0x10000 lma 0x8000000\n”
[ 326 ms] +download,{section=”boot_vector”,section-size=”65536″,total-size=”585694″}
[ 326 ms] +download,{section=”boot_vector”,section-sent=”16352″,section-size=”65536″,total-sent=”16352″,total-size=”585694″}
[ 328 ms] ~”Loading section .text, size 0x87a8 lma 0x8010000\n”
[ 329 ms] +download,{section=”.text”,section-size=”34728″,total-size=”585694″}
[ 331 ms] ~”Loading section .rodata, size 0x8f34 lma 0x80187a8\n”
[ 332 ms] +download,{section=”.rodata”,section-size=”36660″,total-size=”585694″}
[ 333 ms] ~”Loading section .ARM, size 0x8 lma 0x80216dc\n”
[ 333 ms] +download,{section=”.ARM”,section-size=”8″,total-size=”585694″}
[ 333 ms] ~”Loading section .init_array, size 0x14 lma 0x80216e4\n”
[ 334 ms] +download,{section=”.init_array”,section-size=”20″,total-size=”585694″}
[ 334 ms] ~”Loading section .fini_array, size 0x4 lma 0x80216f8\n”
[ 334 ms] +download,{section=”.fini_array”,section-size=”4″,total-size=”585694″}
[ 334 ms] ~”Loading section .data, size 0x70 lma 0x80216fc\n”
[ 335 ms] +download,{section=”.data”,section-size=”112″,total-size=”585694″}
[ 335 ms] ~”Start address 0x8015eb4, load size 137068\n”
[ 1027 ms] ~”Transfer rate: 12168 KB/sec, 9137 bytes/write.\n”
[ 1027 ms] ^done
[ 1029 ms] mon reset
[ 1037 ms] &”mon reset\n”
[ 1106 ms] @”Resetting target\r\n”
[ 1106 ms] ^done
[ 1121 ms] -data-evaluate-expression “sizeof(void *)”
[ 1127 ms] ^done,value=”4″
[ 1127 ms] -data-evaluate-expression “sizeof(int)”
[ 1138 ms] ^done,value=”4″
[ 1138 ms] -data-evaluate-expression “sizeof(short)”
[ 1138 ms] ^done,value=”2″
[ 1138 ms] -data-evaluate-expression “sizeof(long)”
[ 1138 ms] -data-evaluate-expression “sizeof(long long)”
[ 1138 ms] ^done,value=”8″
[ 1138 ms] -data-evaluate-expression “sizeof(char)”
[ 1138 ms] ^done,value=”1″
[ 1138 ms] -data-evaluate-expression “sizeof(wchar_t)”
[ 1149 ms] ^done,value=”4″
[ 1149 ms] -data-evaluate-expression “sizeof(float)”
[ 1149 ms] -data-evaluate-expression “sizeof(double)”
[ 1149 ms] ^done,value=”8″
[ 1149 ms] -data-evaluate-expression “sizeof(long double)”
[ 1150 ms] ^done,value=”8″
[ 1600 ms] info target
[ 1601 ms] &”info target\n”
[ 1601 ms] ~”Symbols from \”D:\\GIT\\remote\\Firmware\\VisualGDB\\Debug\\MantaRemote.elf\”.\n”
[ 1601 ms] ~”Remote serial target in gdb-specific protocol:\n”
[ 1601 ms] ~”Debugging a target over a serial line.\n”
[ 1602 ms] ~”\tWhile running this, GDB does not access memory from…\n”
[ 1602 ms] ~”Local exec file:\n”
[ 1602 ms] ~”\t`D:\\GIT\\remote\\Firmware\\VisualGDB\\Debug\\MantaRemote.elf’, file type elf32-littlearm.\n”
[ 1603 ms] ~”\tEntry point: 0x8015eb4\n”
[ 1603 ms] ~”\t0x08000000 – 0x08010000 is boot_vector\n”
[ 1603 ms] ~”\t0x08010000 – 0x080187a8 is .text\n”
[ 1603 ms] ~”\t0x080187a8 – 0x080216dc is .rodata\n”
[ 1603 ms] ~”\t0x080216dc – 0x080216e4 is .ARM\n”
[ 1603 ms] ~”\t0x080216e4 – 0x080216f8 is .init_array\n”
[ 1604 ms] ~”\t0x080216f8 – 0x080216fc is .fini_array\n”
[ 1604 ms] ~”\t0x20000000 – 0x20000070 is .data\n”
[ 1604 ms] ~”\t0x20000200 – 0x20006174 is .bss\n”
[ 1604 ms] ^done
[ 1616 ms] -break-insert -f *0x080130c0
[ 1627 ms] ^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080130c0″,func=”opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”63″,thread-groups=[“i1″],times=”0″,original-location=”*0x080130c0″}
[ 1639 ms] -break-after 2 0
[ 1649 ms] ^done
[ 1650 ms] -break-disable 2
[ 1659 ms] ^done
[ 1678 ms] info symbol 0x80130c0
[ 1679 ms] &”info symbol 0x80130c0\n”
[ 1679 ms] ~”_ZN4opsy6kernel9scheduler5startEmmPmRNS0_9idle_taskE + 92 in section .text\n”
[ 1679 ms] ^done
[ 1683 ms] info line *0x80130c0
[ 1689 ms] &”info line *0x80130c0\n”
[ 1691 ms] ~”Line 63 of \”src/opsy/Kernel/scheduler.hpp\” starts at address 0x80130a8 <opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)+68> and ends at 0x80130c2 <opsy::kernel::scheduler::start(unsigned long, unsigned long, unsigned long*, opsy::kernel::idle_task&)+94>.\n”
[ 1691 ms] ^done
[ 1695 ms] -file-list-exec-source-files
[ 1798 ms] ^done,files=[{file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”},{file=”src/opsy/Kernel/task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/../Logs/ListenerBase.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\ListenerBase.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Logs/breakOnSeverity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\breakOnSeverity.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/drivers/buzzer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\buzzer.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/drivers/imu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.hpp”},{file=”src/userInterface.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\userInterface.hpp”},{file=”src/opsy/Logs/sysviewListener.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\sysviewListener.hpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/opsy/Vendor/STM32/stm32l471xx.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\STM32\\stm32l471xx.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdint.h”},{file=”src/opsy/Kernel/svcCallEnum.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\svcCallEnum.hpp”},{file=”src/opsy/Kernel/waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Kernel/../Logs/Severity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\Severity.hpp”},{file=”src/opsy/Matrix/point.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\point.hpp”},{file=”src/opsy/Kernel/../Vendor/Segger/SEGGER_SYSVIEW.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_SYSVIEW.h”},{file=”src/opsy/Kernel/../Data/fifo.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Data\\fifo.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/c++config.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\c++config.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/cpp_type_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\cpp_type_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cmath”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cmath”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/type_traits”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\type_traits”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/stl_pair.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\stl_pair.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/exception_ptr.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\exception_ptr.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug/debug.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug\\debug.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cwchar”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cwchar”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdint”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdint”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/new”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\new”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/clocale”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\clocale”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdlib”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdlib”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdio”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdio”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/basic_string.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\basic_string.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/predefined_ops.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\predefined_ops.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/new_allocator.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\new_allocator.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/numeric_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\numeric_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stddef.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stddef.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/lock.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\lock.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/reent.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\reent.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stdarg.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stdarg.h”},{file=”<built-in>”,fullname=”D:\\GIT\\remote\\Firmware/<built-in>”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/wchar.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\wchar.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/locale.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\locale.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/ctype.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\ctype.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdlib.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdlib.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdio.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdio.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/errno.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\errno.h”},{file=”src/graphics/color.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\color.hpp”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/reent.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/reent.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/mlock.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/mlock.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/string/strnlen.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-nano-2016q3/newlib/libc/string/strnlen.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/sbrkr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/sbrkr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/string/memset.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-nano-2016q3/newlib/libc/string/memset.c”},{file=”../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/memcpy-armv7m.S”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/memcpy-armv7m.S”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/malloc.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/malloc.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/misc/init.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/misc/../../../../../../../../newlib-nano-2016q3/newlib/libc/misc/init.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/impure.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/impure.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/errno/errno.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/errno/../../../../../../../../newlib-nano-2016q3/newlib/libc/errno/errno.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/cxa_atexit.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/cxa_atexit.c”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/lib1funcs.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/lib1funcs.S”},{file=”../../../../../../gcc-6.2.0/libgcc/libgcc2.c”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/libgcc2.c”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-sf.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-sf.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_copysign.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_copysign.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_scalbn.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_scalbn.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_nan.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_nan.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_finite.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_finite.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/sf_fabs.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/sf_fabs.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/common/s_rint.c”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/common/s_rint.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/s_rint.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/s_rint.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_nan.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_nan.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_matherr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_matherr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_lib_ver.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_lib_ver.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_sqrt.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_sqrt.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_pow.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_pow.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log10.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log10.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_fmod.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_fmod.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_pow.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_pow.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_log10.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_log10.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_fmod.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_fmod.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/math/sf_floor.c”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/math/sf_floor.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/sf_floor.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/sf_floor.c”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_op.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_op.cc”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_ops.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_ops.cc”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/atexit_arm.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/atexit_arm.cc”},{file=”src/opsy/Vendor/Segger/SEGGER_SYSVIEW.c”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_SYSVIEW.c”},{file=”src/opsy/Vendor/Segger/SEGGER_RTT.c”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_RTT.c”},{file=”src/opsy/Logs/logger.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.cpp”},{file=”src/opsy/Kernel/systemView.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.cpp”},{file=”src/opsy/Kernel/../Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/scheduler.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.cpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/drivers/screen.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.cpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/drivers/imu.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/drivers/btnInputs.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.cpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/userInterface.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\userInterface.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”src/opsy/Logs/sysviewListener.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\sysviewListener.hpp”},{file=”src/userInterface.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\userInterface.hpp”},{file=”src/drivers/imu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/drivers/buzzer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\buzzer.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/opsy/Logs/breakOnSeverity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\breakOnSeverity.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”src/opsy/Kernel/../Logs/ListenerBase.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\ListenerBase.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”}]
[ 1806 ms] -break-insert -f D:/GIT/remote/Firmware/src/main.cpp:35
[ 1811 ms] ^done,bkpt={number=”3″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″,thread-groups=[“i1″],times=”0″,original-location=”D:/GIT/remote/Firmware/src/main.cpp:35″}
[ 1811 ms] -break-after 3 0
[ 1811 ms] ^done
[ 1811 ms] info symbol 0x8015c6e
[ 1812 ms] &”info symbol 0x8015c6e\n”
[ 1812 ms] ~”_ZNKUlvE_clEv + 10 in section .text\n”
[ 1812 ms] ^done
[ 1812 ms] info line *0x8015c6e
[ 1813 ms] &”info line *0x8015c6e\n”
[ 1814 ms] ~”Line 35 of \”src/main.cpp\” starts at address 0x8015c6e <<lambda()>::operator()(void) const+10> and ends at 0x8015c70 <<lambda()>::_FUN(void)>.\n”
[ 1814 ms] ^done
[ 1836 ms] -data-evaluate-expression “&_estack”
[ 1850 ms] ^done,value=”0x20017ffc \”$\224ac\”<error: Cannot access memory at address 0x20018000>”
[ 1854 ms] -var-create – * “*((void **)0x20017ff8)”
[ 1861 ms] ^done,name=”var1″,numchild=”0″,value=”0x8013be9 <opsy::kernel::scheduler::pendsv_bootstrap()+40>”,type=”void *”,has_more=”0″
[ 1862 ms] -var-assign “var1″ 0x397296cc
[ 1884 ms] ^done,value=”0x397296cc”
[ 1884 ms] -data-evaluate-expression “\*\(\(void\ \*\*\)0x20017ff8\)”
[ 1885 ms] ^done,value=”0x397296cc”
[ 1897 ms] 1000-interpreter-exec console flushregs
[ 1906 ms] ~”Register cache flushed.\n”
[ 1906 ms] 1000^done
[ 1906 ms] -exec-continue
[ 1917 ms] ^running
[ 1917 ms] *running,thread-id=”all”
[ 1995 ms] =breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015eb8″,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”92″,thread-groups=[“i1″],times=”1″,original-location=”main”}
[ 1997 ms] ~”\n”
[ 1998 ms] ~”Breakpoint 1, main () at src/main.cpp:92\n”
[ 1998 ms] ~”92\t\tlogger::register_listener(bos);\n”
[ 1998 ms] *stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”1″,frame={addr=”0x08015eb8″,func=”main”,args=[],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”92″},thread-id=”1″,stopped-threads=”all”
[ 2003 ms] -data-evaluate-expression “opsy::kernel::scheduler::is_started_”
[ 2013 ms] ^done,value=”false”
[ 2040 ms] 1001-interpreter-exec console flushregs
[ 2045 ms] ~”Register cache flushed.\n”
[ 2047 ms] 1001^done
[ 2053 ms] -break-delete 1
[ 2057 ms] ^done
[ 2057 ms] -exec-continue
[ 2057 ms] ^running
[ 2057 ms] *running,thread-id=”all”
[ 2114 ms] =breakpoint-modified,bkpt={number=”3″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″,thread-groups=[“i1″],times=”1″,original-location=”D:/GIT/remote/Firmware/src/main.cpp:35″}
[ 2117 ms] ~”\n”
[ 2118 ms] ~”Breakpoint 3, <lambda()>::operator()(void) const (__closure=0x0) at src/main.cpp:35\n”
[ 2118 ms] ~”35\t\t\t__NOP();\n”
[ 2118 ms] *stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”3″,frame={addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,args=[{name=”__closure”,value=”0x0″}],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},thread-id=”1″,stopped-threads=”all”
[ 2118 ms] -data-evaluate-expression “opsy::kernel::scheduler::is_started_”
[ 2130 ms] ^done,value=”true”
[ 2131 ms] -data-evaluate-expression “opsy::kernel::scheduler::active_tasks_count_”
[ 2143 ms] ^done,value=”1″
[ 2145 ms] -data-evaluate-expression “opsy::kernel::scheduler::first_task_”
[ 2153 ms] ^done,value=”0x20000328 <check>”
[ 2154 ms] -data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20000328\)\)\.name_”
[ 2165 ms] ^done,value=”0x80188a8 \”User Interface\””
[ 2165 ms] -data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20000328\)\)\.stack_pointer_”
[ 2178 ms] ^done,value=”0x200042f8 <check+16336>”
[ 2178 ms] -data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20000328\)\)\.next_task_”
[ 2181 ms] ^done,value=”0x0″
[ 2181 ms] -data-evaluate-expression “opsy::kernel::scheduler::current_task_”
[ 2192 ms] ^done,value=”0x0″
[ 2192 ms] -data-evaluate-expression “opsy::kernel::scheduler::current_task_”
[ 2193 ms] ^done,value=”0x0″
[ 2216 ms] -break-after 3 0
[ 2225 ms] ^done
[ 2230 ms] 1002-interpreter-exec console flushregs
[ 2235 ms] ~”Register cache flushed.\n”
[ 2236 ms] 1002^done
[ 2236 ms] -stack-list-frames
[ 2239 ms] ^done,stack=[frame={level=”0″,addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},frame={level=”1″,addr=”0x08015c7a”,func=”<lambda()>::_FUN(void)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”40″},frame={level=”2″,addr=”0x00000000″,func=”??”}]
[ 2240 ms] -stack-list-arguments 0
[ 2251 ms] ^done,stack-args=[frame={level=”0″,args=[name=”__closure”]},frame={level=”1″,args=[]},frame={level=”2″,args=[]}]
[ 10809 ms] -stack-list-frames
[ 10817 ms] ^done,stack=[frame={level=”0″,addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},frame={level=”1″,addr=”0x08015c7a”,func=”<lambda()>::_FUN(void)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”40″},frame={level=”2″,addr=”0x00000000″,func=”??”}]
[ 10903 ms] -stack-list-frames
[ 10910 ms] ^done,stack=[frame={level=”0″,addr=”0x08015c6e”,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},frame={level=”1″,addr=”0x08015c7a”,func=”<lambda()>::_FUN(void)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”40″},frame={level=”2″,addr=”0x00000000″,func=”??”}]
[ 10950 ms] -data-evaluate-expression “opsy::kernel::scheduler::current_task_”
[ 10951 ms] ^done,value=”0x0″
[ 10954 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[0]”
[ 10965 ms] ^done,value=”4294967293″
[ 10965 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[1]”
[ 10966 ms] ^done,value=”1″
[ 10967 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[2]”
[ 10977 ms] ^done,value=”0″
[ 10977 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[3]”
[ 10978 ms] ^done,value=”0″
[ 10978 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[4]”
[ 10979 ms] ^done,value=”0″
[ 10979 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[5]”
[ 10979 ms] ^done,value=”536888132″
[ 10979 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[6]”
[ 10980 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[7]”
[ 10980 ms] ^done,value=”0″
[ 10980 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[8]”
[ 10980 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[9]”
[ 10980 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[10]”
[ 10981 ms] ^done,value=”10″
[ 10981 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[11]”
[ 10981 ms] ^done,value=”0″
[ 10981 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[12]”
[ 10981 ms] ^done,value=”262144″
[ 10981 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[13]”
[ 10981 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[14]”
[ 10982 ms] ^done,value=”0″
[ 10982 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[15]”
[ 10982 ms] ^done,value=”134303567″
[ 10982 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[16]”
[ 10982 ms] ^done,value=”134296378″
[ 10982 ms] -data-evaluate-expression “\(\(uint32_t\*\)\(0x200042F8\)\)\[17]”
[ 10983 ms] ^done,value=”1627390464″
[ 10983 ms] -data-evaluate-expression “\$CONTROL”
[ 10993 ms] ^done,value=”void”
[ 10993 ms] -data-evaluate-expression “\$r4″
[ 10993 ms] ^done,value=”0”
[ 10994 ms] -data-evaluate-expression “\$r5″
[ 11004 ms] ^done,value=”0”
[ 11004 ms] -data-evaluate-expression “\$r6″
[ 11014 ms] ^done,value=”0”
[ 11014 ms] -data-evaluate-expression “\$r7″
[ 11015 ms] ^done,value=”536871696”
[ 11015 ms] -data-evaluate-expression “\$r8″
[ 11015 ms] ^done,value=”0”
[ 11015 ms] -data-evaluate-expression “\$r9″
[ 11015 ms] -data-evaluate-expression “\$r10″
[ 11015 ms] -data-evaluate-expression “\$r11″
[ 11016 ms] ^done,value=”0”
[ 11016 ms] -data-evaluate-expression “\$r13″
[ 11016 ms] ^done,value=”0x20000310 <idle+236>”
[ 11016 ms] -data-evaluate-expression “\$r0″
[ 11017 ms] ^done,value=”0”
[ 11017 ms] -data-evaluate-expression “\$r1″
[ 11017 ms] -data-evaluate-expression “\$r2″
[ 11028 ms] ^done,value=”0”
[ 11028 ms] -data-evaluate-expression “\$r3″
[ 11028 ms] -data-evaluate-expression “\$r12″
[ 11028 ms] -data-evaluate-expression “\$lr”
[ 11029 ms] ^done,value=”134306939″
[ 11029 ms] -data-evaluate-expression “\$pc”
[ 11029 ms] ^done,value=”0x8015c6e <<lambda()>::operator()(void) const+10>”
[ 11029 ms] -data-evaluate-expression “\$r15″
[ 11030 ms] ^done,value=”0x8015c6e <<lambda()>::operator()(void) const+10>”
[ 11030 ms] -data-evaluate-expression “\$xPSR”
[ 11041 ms] ^done,value=”void”
[ 11041 ms] 1003-interpreter-exec console flushregs
[ 11041 ms] 1004-gdb-set $r4=0x0
[ 11041 ms] 1005-gdb-set $r5=0x0
[ 11041 ms] 1006-gdb-set $r6=0x0
[ 11041 ms] 1007-gdb-set $r7=0x20004344
[ 11041 ms] 1008-gdb-set $r8=0x0
[ 11041 ms] 1009-gdb-set $r9=0x0
[ 11041 ms] 1010-gdb-set $r10=0x0
[ 11041 ms] 1011-gdb-set $r11=0x0
[ 11041 ms] 1012-gdb-set $r13=0x20004320
[ 11041 ms] 1013-gdb-set $r0=0xa
[ 11041 ms] 1014-gdb-set $r1=0x0
[ 11041 ms] 1015-gdb-set $r2=0x40000
[ 11041 ms] 1016-gdb-set $r3=0xa
[ 11041 ms] 1017-gdb-set $r12=0x0
[ 11041 ms] 1018-gdb-set $lr=0x8014f4f
[ 11041 ms] 1019-gdb-set $pc=0x801333a
[ 11041 ms] 1020-gdb-set $r15=0x801333a
[ 11041 ms] ~”Register cache flushed.\n”
[ 11042 ms] 1003^done
[ 11043 ms] 1004^done
[ 11044 ms] 1005^done
[ 11046 ms] 1006^done
[ 11050 ms] 1007^done
[ 11051 ms] 1008^done
[ 11052 ms] 1009^done
[ 11052 ms] 1010^done
[ 11053 ms] 1011^done
[ 11054 ms] 1012^done
[ 11054 ms] 1013^done
[ 11055 ms] 1014^done
[ 11055 ms] 1015^done
[ 11056 ms] 1016^done
[ 11056 ms] 1017^done
[ 11057 ms] 1018^done
[ 11057 ms] 1019^done
[ 11058 ms] 1020^done
[ 11058 ms] -stack-list-frames
[ 11072 ms] ^done,stack=[frame={level=”0″,addr=”0x0801333a”,func=”opsy::kernel::scheduler::sleep”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”369″},frame={level=”1″,addr=”0x08014f4e”,func=”drivers::screen::reset”,file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”,line=”95″},frame={level=”2″,addr=”0x08015cca”,func=”<lambda(uint32_t)>::operator()(uint32_t) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”46″},frame={level=”3″,addr=”0x08015d88″,func=”<lambda(uint32_t)>::_FUN(uint32_t)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”78″},frame={level=”4″,addr=”0x080138be”,func=”opsy::kernel::scheduler::terminate_current_task”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”677″}]
[ 11199 ms] 1021-interpreter-exec console flushregs
[ 11199 ms] 1022-gdb-set $r4=0x0
[ 11199 ms] 1023-gdb-set $r5=0x0
[ 11199 ms] 1024-gdb-set $r6=0x0
[ 11199 ms] 1025-gdb-set $r7=0x20000310
[ 11199 ms] 1026-gdb-set $r8=0x0
[ 11199 ms] 1027-gdb-set $r9=0x0
[ 11199 ms] 1028-gdb-set $r10=0x0
[ 11199 ms] 1029-gdb-set $r11=0x0
[ 11199 ms] 1030-gdb-set $r13=0x20000310
[ 11199 ms] 1031-gdb-set $r0=0x0
[ 11199 ms] 1032-gdb-set $r1=0x0
[ 11199 ms] 1033-gdb-set $r2=0x0
[ 11199 ms] 1034-gdb-set $r3=0x0
[ 11199 ms] 1035-gdb-set $r12=0x0
[ 11199 ms] 1036-gdb-set $lr=0x8015c7b
[ 11199 ms] 1037-gdb-set $pc=0x8015c6e
[ 11199 ms] 1038-gdb-set $r15=0x8015c6e
[ 11204 ms] ~”Register cache flushed.\n”
[ 11205 ms] 1021^done
[ 11205 ms] 1022^done
[ 11206 ms] 1023^done
[ 11207 ms] 1024^done
[ 11209 ms] 1025^done
[ 11210 ms] 1026^done
[ 11210 ms] 1027^done
[ 11211 ms] 1028^done
[ 11211 ms] 1029^done
[ 11212 ms] 1030^done
[ 11213 ms] 1031^done
[ 11213 ms] 1032^done
[ 11214 ms] 1033^done
[ 11214 ms] 1034^done
[ 11215 ms] 1035^done
[ 11215 ms] 1036^done
[ 11216 ms] 1037^done
[ 14010 ms] -stack-list-frames
[ 16656 ms] -stack-list-frames 0 0
[ 16656 ms] ~”The target is not responding to GDB commands.\nStop debugging it? ”
[ 16656 ms] ~”(y or n) [answered Y; input not from terminal]\n”
[ 16657 ms] =thread-group-exited,id=”i1″
[ 16657 ms] &”Disconnected from target.\n”
[ 16658 ms] ~”../../gdb-7.12/gdb/thread.c:848: internal-error: int value_in_thread_stack_temporaries(value*, ptid_t): Assertion `tp != NULL && tp->stack_temporaries_enabled’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? ”
[ 16658 ms] ~”(y or n) [answered Y; input not from terminal]\n”
[ 16658 ms] &”\nThis is a bug, please report it.”
[ 16659 ms] &” For instructions, see:\n<http://www.gnu.org/software/gdb/bugs/>.”
[ 16659 ms] &”\n\n”
[ 16659 ms] ~”../../gdb-7.12/gdb/thread.c:848: internal-error: int value_in_thread_stack_temporaries(value*, ptid_t): Assertion `tp != NULL && tp->stack_temporaries_enabled’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? ”
[ 16659 ms] ~”(y or n) [answered Y; input not from terminal]\n”
[ 16659 ms] This application has requested the Runtime to terminate it in an unusual way.
[ 16659 ms] Please contact the application’s support team for more information.And the GDB server log:
<div>C:\Program Files (x86)\SEGGER\JLink_V618b\JLinkGDBServerCL.exe -select USB -device STM32L471RE -speed auto -if SWD -port 53339
SEGGER J-Link GDB Server V6.18b Command Line Version</div>
<div>JLinkARM.dll V6.18b (DLL compiled Aug 18 2017 19:01:12)</div>
<div>Command line: -select USB -device STM32L471RE -speed auto -if SWD -port 53339
—–GDB Server start settings—–
GDBInit file: none
GDB Server Listening port: 53339
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: off
Target connection timeout: 0 ms
——J-Link related settings——
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
——Target related settings——
Target device: STM32L471RE
Target interface: SWD
Target interface speed: auto
Target endian: little</div>
<div>Connecting to J-Link…
J-Link is connected.
Firmware: J-Link Ultra V4 compiled Jul 24 2017 17:05:43
Hardware: V4.00
S/N: 504401633
Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
Checking target voltage…
Target voltage: 3.32 V
Listening on TCP/IP port 53339
Connecting to target…Connected to target
Waiting for GDB connection…Connected to 127.0.0.1
Reading all registers
Read 2 bytes @ address 0x08015EB8 (Data = 0x4814)
Read 4 bytes @ address 0x08015F0C (Data = 0x20004380)
Read 2 bytes @ address 0x080100AA (Data = 0xB480)
Read 4 bytes @ address 0x08015C6E (Data = 0xB580E7FD)
Read 4 bytes @ address 0x08015C7A (Data = 0xB480BD80)
Reading 64 bytes @ address 0x20000300
Received monitor command: reset
Resetting target
Downloading 16352 bytes @ address 0x08000000
Downloading 16352 bytes @ address 0x08003FE0
Downloading 16352 bytes @ address 0x08007FC0
Downloading 16352 bytes @ address 0x0800BFA0
Downloading 128 bytes @ address 0x0800FF80
Downloading 16080 bytes @ address 0x08010000
Downloading 16080 bytes @ address 0x08013ED0
Downloading 2568 bytes @ address 0x08017DA0
Downloading 16328 bytes @ address 0x080187A8
Downloading 16320 bytes @ address 0x0801C770
Downloading 4012 bytes @ address 0x08020730
Downloading 8 bytes @ address 0x080216DC
Downloading 20 bytes @ address 0x080216E4
Downloading 4 bytes @ address 0x080216F8
Downloading 112 bytes @ address 0x080216FC
Writing register (PC = 0x08015EB4)
Read 4 bytes @ address 0x08015EB4 (Data = 0xAF00B580)
Resetting target
Read 2 bytes @ address 0x080130C0 (Data = 0x7A00)
Read 2 bytes @ address 0x08015C6C (Data = 0xBF00)
Read 2 bytes @ address 0x08015C6E (Data = 0xE7FD)
Reading 8 bytes @ address 0x20017FFC
WARNING: Failed to read memory @ address 0x20017FFC
Read 1 bytes @ address 0x20017FFC (Data = 0x24)
Read 1 bytes @ address 0x20017FFD (Data = 0x94)
Read 1 bytes @ address 0x20017FFE (Data = 0x61)
Read 1 bytes @ address 0x20017FFF (Data = 0x63)
WARNING: Failed to read memory @ address 0x20018000
Read 4 bytes @ address 0x20017FF8 (Data = 0x08013BE9)
Downloading 4 bytes @ address 0x20017FF8
Read 4 bytes @ address 0x080168BC (Data = 0xB082B580)
WARNING: Failed to read memory @ address 0xFFFFFFFE
Read 4 bytes @ address 0x20017FF8 (Data = 0x397296CC)
Setting breakpoint @ address 0x08015C6E, Size = 2, BPHandle = 0x0001
Setting breakpoint @ address 0x08015EB8, Size = 2, BPHandle = 0x0002
Starting target CPU…
…Breakpoint reached @ address 0x08015EB8
Read 4 bytes @ address 0x08015EB8 (Data = 0xF7FD4814)
Removing breakpoint @ address 0x08015C6E, Size = 2
Removing breakpoint @ address 0x08015EB8, Size = 2
Read 1 bytes @ address 0x20004538 (Data = 0x00)
Setting breakpoint @ address 0x08015C6E, Size = 2, BPHandle = 0x0003
…Breakpoint reached @ address 0x08015C6E
Read 1 bytes @ address 0x20004538 (Data = 0x01)
Read 4 bytes @ address 0x20004788 (Data = 0x00000001)
Read 4 bytes @ address 0x200047A0 (Data = 0x20000328)
Read 4 bytes @ address 0x2000033C (Data = 0x080188A8)
Reading 8 bytes @ address 0x080188A8
Reading 8 bytes @ address 0x080188B0
Read 4 bytes @ address 0x20000330 (Data = 0x200042F8)
Read 4 bytes @ address 0x2000037C (Data = 0x00000000)
Read 4 bytes @ address 0x2000478C (Data = 0x00000000)
Read 4 bytes @ address 0x00000000 (Data = 0x20017FFC)
Read 4 bytes @ address 0x200042F8 (Data = 0xFFFFFFFD)
Read 4 bytes @ address 0x200042FC (Data = 0x00000001)
Read 4 bytes @ address 0x20004300 (Data = 0x00000000)
Read 4 bytes @ address 0x20004304 (Data = 0x00000000)
Read 4 bytes @ address 0x20004308 (Data = 0x00000000)</div>
<div></div>
<div>The GDB server doesn’t show any visible problem, but the GDB terminal hangs when trying to get the stack frames (whet is weird here is that the task stack frame is ok, it can get it, but going back to the idle task, it hangs).</div>
<div></div>
<div>Any advice?</div>
<div></div>
<div>Thomas.</div>
August 30, 2017 at 10:22 #12225Otatiaro
ParticipantI removed xPSR and CONTROL from the saved registers list, now I get different errors, but this one seems interesting:
-stack-list-frames
Ignoring packet error, continuing…
&”Reply contains invalid hex digit 116\n”
1048^done
&”Quit (expect signal SIGINT when the program is resumed)\n”
../../gdb-7.12/gdb/findvar.c:291: internal-error: value* value_of_register_lazy(frame_info*, int): Assertion `frame_id_p (get_frame_id (frame))’ failed.
&”\n\n”
Please contact the application’s support team for more information.August 30, 2017 at 10:23 #12226Otatiaro
ParticipantThe problem really seems to be when it gets back to the idle task stack frame …
August 30, 2017 at 11:48 #12227Otatiaro
ParticipantOk some more debug on this, I start to see a pattern, it seems to always go into error when it sets back R7 to its original value, then the GDB console gets an error “PC not available”, all commands thereafter are replied with “No registers.”
I am now almost 100% certain my code is correct, as I can see the values injected in the registers are ok (I even changed my code to send them in a increasing sequence from R0 to R15, then the S0-S31 registers if needed), using Ozone from SEGGER if I manually inject the register values I correctly switch from one task to another and get the correct stack frames.
Also, when the command is working, I can see GDB sends a register cache flush, sends now registers values, THEN call -stack-list-frames, but when it fails, the -stack-list-frames is sent BEFORE the registers are fully set.
Working:
1004-gdb-set $r0=0x3e8
1005-gdb-set $r1=0xffffffff
1006-gdb-set $r2=0x1000
1007-gdb-set $r3=0x3e8
1008-gdb-set $r4=0x0
1009-gdb-set $r5=0x0
1010-gdb-set $r6=0x0
1011-gdb-set $r7=0x2000434c
1012-gdb-set $r8=0x0
1013-gdb-set $r9=0x0
1014-gdb-set $r10=0x0
1015-gdb-set $r11=0x0
1016-gdb-set $r12=0x0
1017-gdb-set $r13=0x20004328
1018-gdb-set $r14=0x8015cf7
1019-gdb-set $r15=0x801333a
1003^done
1004^done
1005^done
1006^done
1007^done
1008^done
1009^done
1010^done
1011^done
1012^done
1013^done
1014^done
1015^done
1016^done
1017^done
1018^done
1019^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x0801333a”,func=”opsy::kernel::scheduler::sleep”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”369″},frame={level=”1″,addr=”0x08015cf6″,func=”<lambda(uint32_t)>::operator()(uint32_t) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”55″},frame={level=”2″,addr=”0x08015d88″,func=”<lambda(uint32_t)>::_FUN(uint32_t)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”78″},frame={level=”3″,addr=”0x080138be”,func=”opsy::kernel::scheduler::terminate_current_task”,file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”,line=”677″}]Non working:
1020-interpreter-exec console flushregs
1021-gdb-set $r0=0x1f4
1022-gdb-set $r1=0x0
1023-gdb-set $r2=0x0
1024-gdb-set $r3=0x1f4
1025-gdb-set $r4=0x0
1026-gdb-set $r5=0x0
1027-gdb-set $r6=0x0
1028-gdb-set $r7=0x200083b4
1029-gdb-set $r8=0x0
1030-gdb-set $r9=0x0
1031-gdb-set $r10=0x0
1032-gdb-set $r11=0x0
1033-gdb-set $r12=0x0
1034-gdb-set $r13=0x200083b4
1035-gdb-set $r14=0x8015df9
1036-gdb-set $r15=0x8015df8
1020^done
1021^done
1022^done
1023^done
1024^done
1025^done
1026^done
1027^done
1028^done
1029^done
-stack-list-frames
The target is not responding to GDB commands.Could this be the problem ? This would explain the “PC not available” error message, because it is not set yet, and the subsequent “no registers”, because the register set is not full.
Then this would be a problem on GDB timings/synchronization? Could you confirm (and fix if it’s a problem on your side)?
The weird thing is … it was working the first day (I did a huge refactoring in between to comply with ReSharper naming conventions), I even showed my co-workers the result, could it be a bug introduced in a recent update?
Is there a way to make GDB to validate each command before sending the next one? This would be very slow, but would prove this is the issue.
Thomas.
August 30, 2017 at 12:39 #12228Otatiaro
ParticipantI just tried RealTime Watch, and as soon as I enable “Allow tracing function calls in Real-time Watch”, I get the same kind of errors (locks up but release with errors after a few seconds).
August 30, 2017 at 20:24 #12239support
Thanks, this could be related to Visual Studio trying to asynchronously request the frame list while the registers are still being updated. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.7.1763.msi
We have also added a setting under Tools->Options->VisualGDB->Embedded->Other that allows disabling parallelization of register setting commands.
If you want to use function tracing with your custom RTOS, you would need to modify the profiler framework so that it can store the instrumented call stack information for each thread separately. This mechanism is not documented, so our best advice would be see how this is supported for FreeRTOS and add similar code for handling your RTOS.
August 31, 2017 at 08:29 #12246Otatiaro
ParticipantNop, doesn’t fix it 🙁 Even with parallelization of register setting disabled.
I don’t get it, seems to lock at random:
VisualGDB is licensed to Thomas Legrand at EZNOV
e:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi D:\GIT\remote\Firmware\VisualGDB\Debug\MantaRemote.elf
-gdb-version
~”done.\n”
^done
-list-features
^done
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0801758c”,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”54″,thread-groups=[“i1″],times=”0″,original-location=”main”}
target remote :61337
&”target remote :61337\n”
~”Remote debugging using :61337\n”
*stopped,frame={addr=”0x0801746e”,func=”<lambda()>::operator()(void) const”,args=[{name=”__closure”,value=”0x0″}],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},thread-id=”1″,stopped-threads=”all”
^done
info shared
&”info shared\n”
^done
mon reset
&”mon reset\n”
^done
mon reset
&”mon reset\n”
^done
^done,value=”4″
^done,value=”4″
^done,value=”2″
^done,value=”4″
^done,value=”8″
^done,value=”1″
^done,value=”4″
^done,value=”4″
^done,value=”8″
^done,value=”8″
info target
&”info target\n”
~”\tEntry point: 0x8017588\n”
~”\t0x08010000 – 0x0801a738 is .text\n”
~”\t0x0801a738 – 0x08024c2c is .rodata\n”
~”\t0x08024c2c – 0x08024c34 is .ARM\n”
~”\t0x08024c34 – 0x08024c54 is .init_array\n”
~”\t0x08024c54 – 0x08024c58 is .fini_array\n”
~”\t0x20000070 – 0x20000070 is .jcr\n”
~”\t0x20000070 – 0x20000070 is .tm_clone_table\n”
~”\t0x20000200 – 0x20005574 is .bss\n”
^done
^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080130c0″,func=”screens::screen_base::battery(float, bool, bool)”,file=”src/screens/screen_base.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\screen_base.hpp”,line=”143″,thread-groups=[“i1″],times=”0″,original-location=”*0x080130c0″}
-break-after 2 0
^done
-break-disable 2
^done
~”_ZN7screens11screen_base7batteryEfbb + 184 in section .text\n”
^done
~”Line 143 of \”src/screens/screen_base.hpp\” starts at address 0x80130be <screens::screen_base::battery(float, bool, bool)+182> and ends at 0x80130d0 <screens::screen_base::battery(float, bool, bool)+200>.\n”
^done
^done,files=[{file=”src/user_interface.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\user_interface.cpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/screens/screen_base.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\screen_base.hpp”},{file=”src/screens/splash.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\splash.hpp”},{file=”src/screens/menu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\menu.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”src/graphics/text.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\text.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdint”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdint”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/cpp_type_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\cpp_type_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/type_traits”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\type_traits”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/c++config.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\c++config.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/stl_pair.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\stl_pair.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cmath”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cmath”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/exception_ptr.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\exception_ptr.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug/debug.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug\\debug.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cwchar”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cwchar”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/new”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\new”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/clocale”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\clocale”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdlib”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdlib”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdio”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdio”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/basic_string.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\basic_string.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/predefined_ops.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\predefined_ops.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/new_allocator.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\new_allocator.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/numeric_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\numeric_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdint.h”},{file=”src/graphics/color.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\color.hpp”},{file=”src/opsy/Vendor/STM32/stm32l471xx.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\STM32\\stm32l471xx.h”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stddef.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stddef.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/lock.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\lock.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/reent.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\reent.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\math.h”},{file=”src/opsy/util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/Impl/../svcCallEnum.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\svcCallEnum.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Kernel/Impl/../task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Kernel/../Logs/Severity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\Severity.hpp”},{file=”src/opsy/Kernel/../Data/fifo.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Data\\fifo.hpp”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stdarg.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stdarg.h”},{file=”<built-in>”,fullname=”D:\\GIT\\remote\\Firmware/<built-in>”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/wchar.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\wchar.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/locale.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\locale.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/ctype.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\ctype.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdlib.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdlib.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdio.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdio.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/errno.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\errno.h”},{file=”src/user_interface.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\user_interface.hpp”},{file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”},{file=”src/opsy/Kernel/task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/../Logs/ListenerBase.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\ListenerBase.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Logs/breakOnSeverity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\breakOnSeverity.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/drivers/buzzer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\buzzer.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/drivers/imu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.hpp”},{file=”src/screens/engine.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\engine.hpp”},{file=”src/opsy/Logs/sysviewListener.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\sysviewListener.hpp”},{file=”src/opsy/Kernel/Impl/queue.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\queue.hpp”},{file=”src/opsy/Vendor/STM32/stm32l471xx.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\STM32\\stm32l471xx.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine/_default_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\machine\\_default_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_stdint.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdint.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdint.h”},{file=”src/opsy/Kernel/svcCallEnum.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\svcCallEnum.hpp”},{file=”src/opsy/Kernel/waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Kernel/../Logs/Severity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\Severity.hpp”},{file=”src/opsy/Matrix/point.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\point.hpp”},{file=”src/opsy/Kernel/../Vendor/Segger/SEGGER_SYSVIEW.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_SYSVIEW.h”},{file=”src/opsy/Kernel/../Data/fifo.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Data\\fifo.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/c++config.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\c++config.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/cpp_type_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\cpp_type_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cmath”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cmath”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/type_traits”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\type_traits”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/stl_pair.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\stl_pair.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/exception_ptr.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\exception_ptr.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug/debug.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\debug\\debug.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cwchar”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cwchar”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdint”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdint”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/new”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\new”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/clocale”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\clocale”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdlib”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdlib”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/cstdio”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\cstdio”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/basic_string.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\basic_string.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits/predefined_ops.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\bits\\predefined_ops.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/new_allocator.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\new_allocator.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext/numeric_traits.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\ext\\numeric_traits.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stddef.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stddef.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/lock.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\lock.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/_types.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\_types.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/reent.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\reent.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/math.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\math.h”},{file=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include/stdarg.h”,fullname=”e:\\sysgcc\\arm-eabi\\lib\\gcc\\arm-eabi\\6.2.0\\include\\stdarg.h”},{file=”<built-in>”,fullname=”D:\\GIT\\remote\\Firmware/<built-in>”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/wchar.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\wchar.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/locale.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\locale.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/ctype.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\ctype.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdlib.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdlib.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include/stdio.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\stdio.h”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys/errno.h”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\sys-include\\sys\\errno.h”},{file=”src/graphics/color.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\color.hpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”src/screens/screen_base.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\screen_base.hpp”},{file=”src/user_interface.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\user_interface.hpp”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/reent.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/reent.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/mlock.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/mlock.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/string/strnlen.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-nano-2016q3/newlib/libc/string/strnlen.c”},{file=”../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/strlen-armv7.S”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/strlen-armv7.S”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/sbrkr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/sbrkr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/nano-mallocr.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/string/memset.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/string/../../../../../../../../newlib-nano-2016q3/newlib/libc/string/memset.c”},{file=”../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/memcpy-armv7m.S”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/machine/arm/../../../../../../../../../newlib-nano-2016q3/newlib/libc/machine/arm/memcpy-armv7m.S”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/malloc.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/malloc.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/misc/init.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/misc/../../../../../../../../newlib-nano-2016q3/newlib/libc/misc/init.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/impure.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/reent/../../../../../../../../newlib-nano-2016q3/newlib/libc/reent/impure.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/errno/errno.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/errno/../../../../../../../../newlib-nano-2016q3/newlib/libc/errno/errno.c”},{file=”../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/cxa_atexit.c”,fullname=”/q/gnu/newlib-nano/build-2016q3/arm-eabi/thumb/fpu/cortex_m4/newlib/libc/stdlib/../../../../../../../../newlib-nano-2016q3/newlib/libc/stdlib/cxa_atexit.c”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/lib1funcs.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/lib1funcs.S”},{file=”../../../../../../gcc-6.2.0/libgcc/libgcc2.c”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/libgcc2.c”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/bpabi.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-sf.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-sf.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”,fullname=”/q/gnu/auto/gcc-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/libgcc/../../../../../../gcc-6.2.0/libgcc/config/arm/ieee754-df.S”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_copysign.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_copysign.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_scalbn.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_scalbn.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_nan.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_nan.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_finite.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/sf_finite.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/sf_fabs.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/sf_fabs.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/common/s_rint.c”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/common/s_rint.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/s_rint.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/s_rint.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_nan.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_nan.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_matherr.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_matherr.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_lib_ver.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/common/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/common/s_lib_ver.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_sqrt.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_sqrt.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_pow.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_pow.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log10.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_log10.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_fmod.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/ef_fmod.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_pow.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_pow.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_log10.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_log10.c”},{file=”../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_fmod.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/math/../../../../../../../../newlib-2.4.0.20160923/newlib/libm/math/wf_fmod.c”},{file=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/math/sf_floor.c”,fullname=”/cygdrive/q/gnu/auto/newlib-2.4.0.20160923/newlib/libm/math/sf_floor.c”},{file=”../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/sf_floor.c”,fullname=”/q/gnu/auto/newlib-bu-2.27+gcc-6.2.0+gmp-5.1.3+mpfr-3.1.2+mpc-1.0.2+newlib-2.4.0.20160923-arm-eabi/arm-eabi/thumb/fpu/cortex_m4/newlib/libm/machine/arm/../../../../../../../../../newlib-2.4.0.20160923/newlib/libm/machine/arm/sf_floor.c”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_op.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_op.cc”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_ops.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/del_ops.cc”},{file=”../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/atexit_arm.cc”,fullname=”/q/gnu/auto/noexceptgcc-6.2/arm-eabi/thumb/fpu/cortex_m4/libstdc++-v3/libsupc++/../../../../../../../gcc-6.2.0/libstdc++-v3/libsupc++/atexit_arm.cc”},{file=”src/opsy/Vendor/Segger/SEGGER_SYSVIEW.c”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_SYSVIEW.c”},{file=”src/opsy/Vendor/Segger/SEGGER_RTT.c”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\Segger\\SEGGER_RTT.c”},{file=”src/opsy/Logs/logger.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.cpp”},{file=”src/opsy/Kernel/systemView.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.cpp”},{file=”src/opsy/Kernel/../Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/scheduler.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/graphics/text.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\text.cpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/drivers/screen.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.cpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/drivers/imu.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/drivers/btnInputs.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.cpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/startup.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\startup.cpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/screens/screen_base.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\screen_base.cpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/opsy/Kernel/Impl/queue.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\queue.hpp”},{file=”src/opsy/Kernel/../Data/fifo.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Data\\fifo.hpp”},{file=”src/screens/engine.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\engine.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/opsy/Kernel/Impl/../task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Kernel/Impl/../waitable.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\waitable.hpp”},{file=”src/opsy/util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/screens/engine.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\engine.cpp”},{file=”src/opsy/Kernel/Impl/queue.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\queue.hpp”},{file=”src/opsy/Logs/sysviewListener.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\sysviewListener.hpp”},{file=”src/screens/engine.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\engine.hpp”},{file=”src/drivers/imu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\imu.hpp”},{file=”src/opsy/Matrix/vector.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector.hpp”},{file=”src/opsy/Matrix/Matrix.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\Matrix.hpp”},{file=”src/opsy/Matrix/vector3D.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Matrix\\vector3D.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/drivers/buzzer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\buzzer.hpp”},{file=”src/drivers/btnInputs.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\btnInputs.hpp”},{file=”src/opsy/Logs/breakOnSeverity.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\breakOnSeverity.hpp”},{file=”src/opsy/Vendor/STM32/../cmsis_gcc.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\cmsis_gcc.h”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”src/opsy/Kernel/../Logs/logger.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\logger.hpp”},{file=”src/opsy/Kernel/../Logs/ListenerBase.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Logs\\ListenerBase.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/systemView.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\systemView.hpp”},{file=”src/opsy/Kernel/../util.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\util.hpp”},{file=”src/opsy/Kernel/task.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\task.hpp”},{file=”src/opsy/Vendor/STM32/../core_cm4.h”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Vendor\\core_cm4.h”},{file=”src/graphics/text.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\text.hpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”src/screens/menu.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\menu.hpp”},{file=”src/screens/splash.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\splash.hpp”},{file=”src/screens/screen_base.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\screen_base.hpp”},{file=”src/drivers/power.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\power.hpp”},{file=”src/drivers/screen.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\drivers\\screen.hpp”},{file=”src/opsy/Kernel/scheduler.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.hpp”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/opsy/Kernel/Impl/singleWaiterEvent.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\Impl\\singleWaiterEvent.hpp”},{file=”src/graphics/imageBuffer.hpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\graphics\\imageBuffer.hpp”},{file=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0/array”,fullname=”e:\\sysgcc\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\array”},{file=”E:/SysGCC/arm-eabi/arm-eabi/include/c++/6.2.0/arm-eabi/bits/gthr-default.h”,fullname=”E:\\SysGCC\\arm-eabi\\arm-eabi\\include\\c++\\6.2.0\\arm-eabi\\bits\\gthr-default.h”},{file=”src/screens/menu.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\screens\\menu.cpp”}]
-data-evaluate-expression “&_estack”
^done,value=”0x20017ffc \”$\224a’\”<error: Cannot access memory at address 0x20018000>”
-var-create – * “*((void **)0x20017ff8)”
^done,name=”var1″,numchild=”0″,value=”0xfffffffd”,type=”void *”,has_more=”0″
-var-assign “var1″ 0x7d118a04
^done,value=”0x7d118a04”
-data-evaluate-expression “\*\(\(void\ \*\*\)0x20017ff8\)”
^done,value=”0x7d118a04″
^done
-exec-continue
^running
*running,thread-id=”all”
=breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x0801758c”,func=”main()”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”54″,thread-groups=[“i1″],times=”1″,original-location=”main”}
~”\n”
~”Breakpoint 1, main () at src/main.cpp:54\n”
~”54\t\tlogger::register_listener(bos);\n”
*stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”1″,frame={addr=”0x0801758c”,func=”main”,args=[],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”54″},thread-id=”1″,stopped-threads=”all”
-data-evaluate-expression “opsy::kernel::scheduler::is_started_”
^done,value=”false”
^done
-break-delete 1
^done
-exec-continue
^running
~”\nProgram”
~” received signal SIGTRAP, Trace/breakpoint trap.\n”
~”<lambda()>::operator()(void) const (__closure=0x0) at src/main.cpp:35\n”
~”35\t\t\t__NOP();\n”
*stopped,reason=”signal-received”,signal-name=”SIGTRAP”,signal-meaning=”Trace/breakpoint trap”,frame={addr=”0x0801746c”,func=”<lambda()>::operator()(void) const”,args=[{name=”__closure”,value=”0x0″}],file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},thread-id=”1″,stopped-threads=”all”
^done,value=”true”
-data-evaluate-expression “opsy::kernel::scheduler::active_tasks_count_”
^done,value=”1″
-data-evaluate-expression “opsy::kernel::scheduler::first_task_”
^done,value=”0x20001510 <_ZN7screens6engine5task_E>”
-data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20001510\)\)\.name_”
^done,value=”0x801a908 \”Screen engine\””
-data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20001510\)\)\.stack_pointer_”
^done,value=”0x20003420 <_ZN7screens6engine5task_E+7952>”
-data-evaluate-expression “\(\(opsy::kernel::task\*\)\(0x20001510\)\)\.next_task_”
^done,value=”0x0″
-data-evaluate-expression “opsy::kernel::scheduler::current_task_”
^done,value=”0x0″
^done,value=”0x0″
^done
-stack-list-frames
^done,stack=[frame={level=”0″,addr=”0x0801746c”,func=”<lambda()>::operator()(void) const”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”35″},frame={level=”1″,addr=”0x0801747a”,func=”<lambda()>::_FUN(void)”,file=”src/main.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\main.cpp”,line=”40″},frame={level=”2″,addr=”0x08019158″,func=”opsy::kernel::idle_task::no_return”,file=”src/opsy/Kernel/scheduler.cpp”,fullname=”D:\\GIT\\remote\\Firmware\\src\\opsy\\Kernel\\scheduler.cpp”,line=”148″}]
-stack-list-arguments 0
^done,stack-args=[frame={level=”0″,args=[name=”__closure”]},frame={level=”1″,args=[]},frame={level=”2″,args=[]}]
^done,value=”0x0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[0]”
^done,value=”4294967277″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[26]”
^done,value=”1″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[27]”
^done,value=”536884296″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[28]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[29]”
^done,value=”1″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[2]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[3]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[4]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[5]”
^done,value=”536884468″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[6]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[7]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[8]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[9]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[30]”
^done,value=”7″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[31]”
^done,value=”134320389″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[32]”
^done,value=”134319500″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[33]”
^done,value=”1627587072″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[34]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[35]”
^done,value=”1065353216″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[36]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[37]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[38]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[39]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[40]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[41]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[42]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[43]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[44]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[45]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[46]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[47]”
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[48]”
^done,value=”1084227584″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[10]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[11]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[12]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[13]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[14]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[15]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[16]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[17]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[18]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[19]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[20]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[21]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[22]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[23]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[24]”
^done,value=”0″
-data-evaluate-expression “\(\(uint32_t\*\)\(0x20003420\)\)\[25]”
^done,value=”0″
-data-evaluate-expression “\$r0″
^done,value=”0”
-data-evaluate-expression “\$r1″
^done,value=”0”
-data-evaluate-expression “\$r2″
^done,value=”0”
-data-evaluate-expression “\$r3″
^done,value=”0”
-data-evaluate-expression “\$r4″
^done,value=”0”
-data-evaluate-expression “\$r5″
^done,value=”0”
-data-evaluate-expression “\$r6″
^done,value=”0”
-data-evaluate-expression “\$r7″
^done,value=”536876260”
-data-evaluate-expression “\$r8″
^done,value=”0”
-data-evaluate-expression “\$r9″
^done,value=”0”
-data-evaluate-expression “\$r10″
^done,value=”0”
-data-evaluate-expression “\$r11″
^done,value=”0”
-data-evaluate-expression “\$r12″
^done,value=”0”
-data-evaluate-expression “\$r13″
^done,value=”0x200014e4 <idle+492>”
-data-evaluate-expression “\$r14″
^done,value=”134313083”
-data-evaluate-expression “\$r15″
^done,value=”0x801746c <<lambda()>::operator()(void) const+8>”
-data-evaluate-expression “\$s0″
^done,value=”0”
-data-evaluate-expression “\$s1″
^done,value=”1”
-data-evaluate-expression “\$s2″
^done,value=”0”
-data-evaluate-expression “\$s3″
^done,value=”0”
-data-evaluate-expression “\$s4″
^done,value=”0”
-data-evaluate-expression “\$s5″
^done,value=”0”
-data-evaluate-expression “\$s6″
^done,value=”0”
-data-evaluate-expression “\$s7″
^done,value=”0”
-data-evaluate-expression “\$s8″
^done,value=”0”
-data-evaluate-expression “\$s9″
^done,value=”0”
-data-evaluate-expression “\$s10″
^done,value=”0”
-data-evaluate-expression “\$s11″
^done,value=”0”
-data-evaluate-expression “\$s12″
^done,value=”0”
-data-evaluate-expression “\$s13″
^done,value=”1”
-data-evaluate-expression “\$s14″
^done,value=”5”
-data-evaluate-expression “\$s15″
^done,value=”0”
-data-evaluate-expression “\$s16″
^done,value=”0”
-data-evaluate-expression “\$s17″
^done,value=”0”
-data-evaluate-expression “\$s18″
^done,value=”0”
-data-evaluate-expression “\$s19″
^done,value=”0”
-data-evaluate-expression “\$s20″
^done,value=”0”
-data-evaluate-expression “\$s21″
^done,value=”0”
-data-evaluate-expression “\$s22″
^done,value=”0”
-data-evaluate-expression “\$s23″
^done,value=”0”
-data-evaluate-expression “\$s24″
^done,value=”0”
-data-evaluate-expression “\$s25″
^done,value=”0”
-data-evaluate-expression “\$s26″
^done,value=”0”
-data-evaluate-expression “\$s27″
^done,value=”0”
-data-evaluate-expression “\$s28″
^done,value=”0”
-data-evaluate-expression “\$s29″
^done,value=”0”
-data-evaluate-expression “\$s30″
^done,value=”0”
-data-evaluate-expression “\$s31″
-gdb-set $r0=0x1
~”The target is not responding to GDB commands.\nStop debugging it? ”
~”(y or n) [answered Y; input not from terminal]\n”
=thread-group-exited,id=”i1″
^error,msg=”Disconnected from target.”
-gdb-set $r1=0x20003448
~”Register cache flushed.\n”
^done
-gdb-set $r2=0x0
^error,msg=”No registers.”
-gdb-set $r3=0x1
-gdb-set $r4=0x0
-gdb-set $r5=0x0
-gdb-set $r6=0x0
-gdb-set $r7=0x200034f4
-gdb-set $r8=0x0
-gdb-set $r9=0x0
-gdb-set $r10=0x0
-gdb-set $r11=0x0
-gdb-set $r12=0x7
-gdb-set $r13=0x20003488
-gdb-set $r14=0x8019105
-gdb-set $r15=0x8018d8c
-gdb-set $s0=0x61030200
-gdb-set $s1=0x0
-gdb-set $s2=0x3f800000
-gdb-set $s3=0x0
-gdb-set $s4=0x0
-gdb-set $s5=0x0
-gdb-set $s6=0x0
-gdb-set $s7=0x0
-gdb-set $s8=0x0
-gdb-set $s9=0x0
-gdb-set $s10=0x0
-gdb-set $s11=0x0
-gdb-set $s12=0x0
-gdb-set $s13=0x0
-gdb-set $s14=0x3f800000
-gdb-set $s15=0x40a00000
-gdb-set $s16=0x0
-gdb-set $s17=0x0
-gdb-set $s18=0x0
-gdb-set $s19=0x0
-gdb-set $s20=0x0
-gdb-set $s21=0x0
-gdb-set $s22=0x0
-gdb-set $s23=0x0
-gdb-set $s24=0x0
-gdb-set $s25=0x0
-gdb-set $s26=0x0
-gdb-set $s27=0x0
-gdb-set $s28=0x0
-gdb-set $s29=0x0
-gdb-set $s30=0x0
-stack-list-frames
-stack-list-frames 0 0
-data-evaluate-expression “\$pc”
-stack-list-frames
^done
-gdb-set $r0=0x0
-gdb-set $r1=0x0
-gdb-set $r2=0x0
-gdb-set $r3=0x0
-gdb-set $r4=0x0
-gdb-set $r5=0x0
-gdb-set $r6=0x0
-gdb-set $r7=0x200014e4
-gdb-set $r8=0x0
-gdb-set $r9=0x0
-gdb-set $r10=0x0
-gdb-set $r11=0x0
-gdb-set $r12=0x0
-gdb-set $r13=0x200014e4
-gdb-set $r14=0x801747b
-gdb-set $r15=0x801746c
-gdb-set $s0=0x0
-gdb-set $s1=0x1
-gdb-set $s2=0x0
-gdb-set $s3=0x0
-gdb-set $s4=0x0
-gdb-set $s5=0x0
-gdb-set $s6=0x0
-gdb-set $s7=0x0
-gdb-set $s8=0x0
-gdb-set $s9=0x0
-gdb-set $s10=0x0
-gdb-set $s11=0x0
-gdb-set $s12=0x0
-gdb-set $s13=0x1
-gdb-set $s14=0x5
-gdb-set $s15=0x0
-gdb-set $s16=0x0
-gdb-set $s17=0x0
-gdb-set $s18=0x0
-gdb-set $s19=0x0
-gdb-set $s20=0x0
-gdb-set $s21=0x0
-gdb-set $s22=0x0
-gdb-set $s23=0x0
-gdb-set $s24=0x0
-gdb-set $s25=0x0
-gdb-set $s26=0x0
-gdb-set $s27=0x0
-gdb-set $s28=0x0
-gdb-set $s29=0x0
-gdb-set $s30=0x0
-stack-list-frames
-stack-list-frames
^done,value=”0x0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done,value=”0″
^done
-gdb-set $r0=0x0
-gdb-set $r1=0x0
-gdb-set $r2=0x0
-gdb-set $r3=0x0
-gdb-set $r4=0x0
-gdb-set $r5=0x0
-gdb-set $r6=0x0
-gdb-set $r7=0x0
-gdb-set $r8=0x0
-gdb-set $r9=0x0
-gdb-set $r10=0x0
-gdb-set $r11=0x0
-gdb-set $r12=0x0
-gdb-set $r14=0x0
-gdb-set $r15=0x0
-gdb-set $s0=0x0
-gdb-set $s1=0x0
-gdb-set $s2=0x0
-gdb-set $s3=0x0
-gdb-set $s4=0x0
-gdb-set $s5=0x0
-gdb-set $s6=0x0
-gdb-set $s7=0x0
-gdb-set $s8=0x0
-gdb-set $s9=0x0
-gdb-set $s10=0x0
-gdb-set $s11=0x0
-gdb-set $s12=0x0
-gdb-set $s13=0x0
-gdb-set $s14=0x0
-gdb-set $s15=0x0
-gdb-set $s16=0x0
-gdb-set $s17=0x0
-gdb-set $s18=0x0
-gdb-set $s19=0x0
-gdb-set $s20=0x0
-gdb-set $s21=0x0
-gdb-set $s22=0x0
-gdb-set $s23=0x0
-gdb-set $s24=0x0
-gdb-set $s25=0x0
-gdb-set $s26=0x0
-gdb-set $s27=0x0
-gdb-set $s28=0x0
-gdb-set $s29=0x0
-gdb-set $s30=0x0
-stack-list-frames
-stack-list-frames
^done
-gdb-set $r0=0x0
-gdb-set $r1=0x0
-gdb-set $r2=0x0
-gdb-set $r3=0x0
-gdb-set $r4=0x0
-gdb-set $r5=0x0
-gdb-set $r6=0x0
-gdb-set $r8=0x0
-gdb-set $r9=0x0
-gdb-set $r10=0x0
-gdb-set $r11=0x0
-gdb-set $r12=0x0
-gdb-set $s0=0x0
-gdb-set $s1=0x1
-gdb-set $s2=0x0
-gdb-set $s3=0x0
-gdb-set $s4=0x0
-gdb-set $s5=0x0
-gdb-set $s6=0x0
-gdb-set $s7=0x0
-gdb-set $s8=0x0
-gdb-set $s9=0x0
-gdb-set $s10=0x0
-gdb-set $s11=0x0
-gdb-set $s12=0x0
-gdb-set $s13=0x1
-gdb-set $s14=0x5
-gdb-set $s15=0x0
-gdb-set $s16=0x0
-gdb-set $s17=0x0
-gdb-set $s18=0x0
-gdb-set $s19=0x0
-gdb-set $s20=0x0
-gdb-set $s21=0x0
-gdb-set $s22=0x0
-gdb-set $s23=0x0
-gdb-set $s24=0x0
-gdb-set $s25=0x0
-gdb-set $s26=0x0
-gdb-set $s27=0x0
-gdb-set $s28=0x0
-gdb-set $s29=0x0
-gdb-set $s30=0x0
-stack-list-frames
-stack-list-frames
^error,msg=”No registers.”The log doesn’t show anything, it just gets the stacked values or registers, then try to set them to the real registers to change context, but first register it tries to set, it disconnects. Then everything is replied with error “No registers.”.
If I don’t use the plugin to get threads from my RTOS, everything works fine, so it has to be related, but how ???? I’m stuck on this one for days now …
Thomas.
August 31, 2017 at 19:44 #12251support
It looks like VisualGDB sent the “flushregs” command before the last “evaluate-expression” was complete:
^done,value=”0” -data-evaluate-expression “\$s30″ ^done,value=”0” -data-evaluate-expression “\$s31″ -interpreter-exec console flushregs -gdb-set $r0=0x1 ~”The target is not responding to GDB commands.\nStop debugging it? ” ~”(y or n) [answered Y; input not from terminal]\n” =thread-group-exited,id=”i1″ ^error,msg=”Disconnected from target.” -gdb-set $r1=0x20003448 ~”Register cache flushed.\n”
Did you have to cancel the “-data-evaluate-expression” command via the “GDB Command Taking Too Long” window? If not, it could be caused by some strange race condition and we can add soem extra logging on VisualGDB side to help you diagnose this.
