Sysprogs forums › Forums › VisualGDB › Cross-compiling OpenCV 3 for Raspberry Pi 2
- This topic has 3 replies, 2 voices, and was last updated 7 years, 4 months ago by
October 17, 2018 at 16:28 #22342
nahumb
I have followed the instructions in above tutorial at https://visualgdb.com/tutorials/raspberry/opencv/build/ for opncv-3.4.1.
On step 8 I have noticed that gtk was not found. After watching the log I have found a message stating that package-config was disabled, and followed the recommendation to add
PKG_CONFIG_LIBDIR=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/pkgconfig;C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/usr/share/pkgconfig (as for the path) to the environment section configuration.
This solved the problem and gtk3 was found and build went OK.
However, unlike in the tutorial screenshot where 3 successful builds are shown, I got only 1 and 0 failed.
I wanted to continue to step 10 of the process, however I can’t find the OpenCV build directory mentioned in the tutorial and continue with the make install step.
Please advise.
Thank you,
Nahum Budin.
October 17, 2018 at 21:46 #22346nahumb
ParticipantUpdate.
Deleted the project and restarted all over, this time the build directory was there (must have been a settings I have missed 🙁 ).
(while setting the CMake command configuration, a VS bug was identified- toggling tabs!?.
A ticket was opened with screenshots and video – see the attached. A workaround is to close the CMake Command tab and reopen it – please add this info to the ticket).
Then, when running the make install command, a Microsoft make tool was executed, though the path was updated as specified.
A workaround – using the full path of make: C:\SysGCC\Raspberry\bin\make install.
Next steps of the tutorial to be followed soon…
Nahum.
You must be logged in to view attached files.October 18, 2018 at 21:06 #22352nahumb
ParticipantFinal update.
Continued with the tutorial sample program.
When running, got an error message that libjasper cannot be found.
Solution: make sure to install all required libraries on your Raspberry Pi:
sudo apt-get install libjpeg-dev libtiff5-dev libjasper-dev libpng12-dev
sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev
sudo apt-get install libxvidcore-dev libx264-dev
sudo apt-get install libgtk2.0-dev libgtk-3-dev.Next a new error was reported:
WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
Solution: sudo apt-get install at-spi2-core.
Finally the demo runs well from the debugger.
Now trying to run the executable directly on the Raspi yield a file not found error.
Reason: no command line parameters are available.
Solution: change default file name in the main section:
/// Load source image
String imageName(“/home/pi/Lena.png”); // by defaultNow it runs directly on/from the Raspi. 🙂
My 2 cents.
Nahum.
This reply was modified 7 years, 4 months ago by
nahumb.
October 19, 2018 at 06:00 #22359support
Thanks for sharing this. We have just finished rechecking everything with the latest OpenCV release and the latest Raspberry Pi toolchain and updated the tutorial.
We have also added a few usability features to VisualGDB (e.g. automatic deployment of installed CMake targets), so please use this build if you would like to try the new features.
