Create Embeded Project Template
Sysprogs forums Forums VisualGDB Create Embeded Project Template
  • #7392
    NKK72
    It is posible to create project template for embeded project?
    • This topic was modified 10 years, 3 months ago by NKK72.
    #7396
    Yes, but that would involve editing the BSP XML files.
    We don’t have much documentation on that, so you can either try experimenting with the BSP.XML file in %LOCALAPPDATA%\VisualGDB\EmbeddedBSPs\<ID> or look through our open-source BSP generators: https://github.com/sysprogs/BSPTools/
    #7400
    NKK72
    It is quite difficult to work. It is better to be realized through the “Export Template”. Do you plan to hav such an opportunity?
    • This reply was modified 10 years, 3 months ago by NKK72.
    #7404
    Yes, we are planning to add project templates to VisualGDB 5.1
    #7766
    NKK72
    I see that ver 5.1 is out.
    Template support is ready?
    #7768
    Yes, simply use the File->Export VisualGDB Project Template command. We will publish a tutorial on that soon.
    #7780
    NKK72
    I will buy it now.
    #7782
    Good to know it worked. Let us know if you run into any problems.
