Sysprogs forums › Forums › VisualGDB › Connection establishment take several minutes
- This topic has 6 replies, 2 voices, and was last updated 11 years, 8 months ago by
torben_pi.
June 24, 2014 at 13:06 #856
torben_pi
ParticipantHello VisualGDB-Team,
i´m working with the VisualGDB 4.2 in Visual Studio 2012 to program a raspberry pi.
Unfortunately the connection establishment takes a long time. Before i can debug on the devise i have to wait several minutes everytime…. This is really annoying especially by testing small changes…
Is there a way to make VisualGDB work faster?
The Raspberry is directly connected with the pc…
Thanks in advance!
June 25, 2014 at 13:40 #3256torben_pi
Participantpush
June 27, 2014 at 23:27 #3252support
That should not normally happen. Typically the connection with Raspberry Pi takes less than 10 seconds.
Please try the following to diagnose it:
1. See if your Raspberry Pi CPU is busy doing something else by running the top command.
2. Try addressing it by IP instead of hostname. Does that change anything?
3. Try using Wireshark to see what happens on the network. Is all the time consumed waiting for one packet or are there several packets exchanged in between? Does with the SSH packets, or are there some suspicious ICMP packets in between?July 1, 2014 at 14:28 #3257torben_pi
Participant@bazis wrote:
3. Try using Wireshark to see what happens on the network. Is all the time consumed waiting for one packet or are there several packets exchanged in between? Does with the SSH packets, or are there some suspicious ICMP packets in between?Sorry for the late answer!
1. top command shows strange load…
When no connection to VisualGDB is established CPU usage is low (up to 4%) and idle high (up to 90%). When VisualGDB is connected usage is up to 40% and sy (I guess system) up to 60% so idle is around 0%…2. Already done
July 4, 2014 at 23:39 #3253support
This might be an indication that your Raspberry Pi board is doing some heavy math on the public keys. Does the password-based authentication also take lots of time? Does the output of ‘dmesg’ contain anything suspicious about regenerating keys?
July 7, 2014 at 08:29 #3254torben_pi
dmesg shows no suspicious actions, the last entry is about connecting a keyboard.
What do you mean by password-based authentication? Is there an option to choose between the generated key and a password everytime?
July 7, 2014 at 20:10 #3255support
When setting up a new connection you can uncheck the “setup public key” checkbox.
If that does not help, try reflashing your SD card with a clean image. It looks like a strange Raspberry Pi configuration bug. -
