Configure VisualGDB Remote source cache
Sysprogs forums › Forums › VisualGDB › Configure VisualGDB Remote source cache
  • #665
    How can I configure Visual GDB Remote source cache.
    By default all my files are in:
    C:Documents and SettingsLocal SettingsApplication DataVisualGDBRemoteSourceCache
    As there are several people working on the same project we have some trouble to use the same .vcproj which must have a different path for each user.
    I want to set a path which is independant of the user.
    Regards
    Damien
    #2708
    ket
    Please download and install VisualGDB version 4.1r4, we changed the source cache to depend on the variable %LOCALAPPDATA% there. So, the source cache is stored per user but the project file is not dependent on a particular user’s directories.
    After installing the new version, go to VisualGDB Project Properties, change something in Makefile settings and press on Apply to rerun the toolchain tests. You can then check in the usual VS settings’ NMake page whether the directories now depend on %LOCALAPPDATA%.
    #2709
    Thank you
    #2710
    I have the same issue for local project headers is it possible to have the same kind a variable for it?
    Damien
    #2711
    ket
    Which headers do you mean here? Usually the headers in you project are included by relative paths anyway.
    #2712
    Let’s say my project is locally in C:myprojectproject, my headers are in C:myprojectheaders by default I will have in Intellisens directories “C:myprojectproject/..headers”.
    As we are several to work on this project with svn we don’t have the same path so that there are conflicts on vcproj each time we commit it on the line “IncludeSearchPath=”
    Damien
    #2713
    We have fixed it in VisualGDB 4.1r7. Thanks for reporting this issue.
