Sysprogs forums › Forums › VisualGDB › compiler and library support for the ISO C++ 2011 standard
- This topic has 6 replies, 2 voices, and was last updated 9 years, 6 months ago by
September 13, 2016 at 08:42 #9047
akhilavit
Participant1>—— Build started: Project: RevLib, Configuration: LinuxConfig x64 ——
1>Build started 13-09-2016 13:10:30.
1>Build:
1> VisualGDB: Sending 1 updated source file to build machine…
1> VisualGDB: Run “make CONFIG=LinuxConfig” in directory “/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/wrk” on ubuntu@192.168.0.54 (SSH)
1> g++ -ggdb -ffunction-sections -O0 -I/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Data -I/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Math -I/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/API -I/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Algo -I/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Topo -I/tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Util -DDEBUG=1 -c ../src/Algo/DataProcessor.cpp -o LinuxConfig/DataProcessor.o -MD -MF LinuxConfig/DataProcessor.dep
1> In file included from /usr/include/c++/4.8/unordered_map:35:0,
1> from /tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Topo/mesh.h:13,
1> from ../src/Algo/DataProcessor.cpp:7:
1>C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54\0000\include\c++\4.8\bits\c++0x_warning.h(32,2): error : #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
1> #error This file requires compiler and library support for the \
1> ^
1> In file included from ../src/Algo/DataProcessor.cpp:7:0:
1>C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54\0013\RevLib\src\Topo\mesh.h(41,9): error : `unordered_map’ does not name a type
1> typedef unordered_map<Edge*, std::vector<Facet*>> NonManifoldEdgeData;
1> ^
1>C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54\0013\RevLib\src\Topo\mesh.h(90,2): error : `NonManifoldEdgeData’ does not name a type
1> NonManifoldEdgeData m_nonManifoldEdgeData;
1> ^
1>C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54\0013\RevLib\src\Topo\mesh.h(385,2): error : `NonManifoldEdgeData’ does not name a type
1> NonManifoldEdgeData GetNonManifoldEdgeData()const{ return m_nonManifoldEdgeData; }
1> ^
1> /tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/src/Topo/mesh.h: In member function `void RevLib::Mesh::ClearNonManifoldEdgeData()’:
1>C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54\0013\RevLib\src\Topo\mesh.h(387,35): error : `m_nonManifoldEdgeData’ was not declared in this scope
1> void ClearNonManifoldEdgeData(){ m_nonManifoldEdgeData.clear(); }
1> ^
1> make: *** [LinuxConfig/DataProcessor.o] Error 1
1> ————————————————————-
1> Command exited with code 2
1> Executable: make
1> Arguments: CONFIG=LinuxConfig
1> Directory: /tmp/VisualGDB/d/User/Akhil/Ubuntu/RevLib/wrk
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.MakeFile.Targets(38,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe” /build “D:\User\Akhil\Ubuntu\RevLib\wrk\RevLib.vcxproj” “/solution:D:\User\Akhil\Ubuntu\RevLib\wrk\RevLib.sln” “/config:LinuxConfig” “/platform:x64″” exited with code 1.
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.91
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========What to do now?
September 13, 2016 at 18:14 #9051support
Please try adding “-std=c++11” to the CXXFLAGS field in VisualGDB Project Properties.
September 14, 2016 at 08:55 #9055akhilavit
Participantthanks. This works and resolves error of compiler version
But it raised many new errors
C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54\0001\include\mm_malloc.h(34,64): error : declaration of C function `int posix_memalign(void**, int, int)’ conflicts with
1> extern “C” int posix_memalign (void **, size_t, size_t) throw ();September 14, 2016 at 09:00 #9056akhilavit
ParticipantError 1 [Clang IntelliSense] Error: ‘vector’ file not found
Is still an error. What would be a problem to understand std::vector?
September 15, 2016 at 01:50 #9063support
KeymasterWe have answered the question about the memalign() function in this thread.
Regarding the <vector> file, can you confirm that it is physically present somewhere under C:\Users\akhils\AppData\Local\VisualGDB\RemoteSourceCache\192.168.0.54? You can also try reloading the cached directories via VisualGDB Project Properties to ensure you get the latest versions of all files.
September 16, 2016 at 08:32 #9070akhilavit
ParticipantError 1 [Clang IntelliSense] Error: invalid argument ‘-std=c++11’ not allowed with ‘C/ObjC’ 1
I get this error now
September 16, 2016 at 17:46 #9075support
This one can be safely ignored and should be solved in the upcoming Beta 1.
If everything else works, we would recommend simply updating to Beta 1 once it is released.
