CodeExplorer issues
Sysprogs forums Forums VisualGDB CodeExplorer issues
  • #32823
    doxus
    I’m having some issues with getting the code explorer to … well do anything. After updating to 5.6r6 it was showing constantly the “open source file” something something message despite c/cpp/h files being opened. After a bit of fiddling i gave up on it, so i disabled the automatic CodeExplorer popup which resulted in it showing constantly the “Code explorer is not active because no compatible projects are loaded” which is quite puzzling.
    Do you have any advice what should i do to get it running? Or are there any additional prerequisites i need to install besided the newest VGDB version?
    #32824
    Unfortunately, it is hard to suggest anything specific based on the description you provided.
    Please provide complete and detailed steps to reproduce the issue as described below:
    1. The steps should begin with launching Visual Studio. They should include every step necessary to create the project from scratch and reproduce the issue.
    2. Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch.
    3. The steps should include uncropped screenshots of all wizard pages, VisualGDB Project Properties pages and any other GUI involved in reproducing the problem. This is critical for us to be able to reproduce the problem on our side.
    #33108
    Rob Belcham
    I had exactly the same problem. In my case, it’s because I also use VisualAssist and so have the “Regular VC++ IntelliSense” option selected in the IntelliSense settings page. If I switch to “Advanced Clang IntelliSense” then the Code Explorer populates, but I loose the VisualAssist buttons and so I cannot take advantage of the Code Explorer which is a shame.
    #33110
    Indeed, since Visual Assist relies on the regular VC++ IntelliSense engine, it won’t work with the projects using Clang IntelliSense. And disabling Clang IntelliSense naturally disables all features provided by it, such as Code Explorer.
    That said, if you miss specific functionality from VisualAssist that is not provided by the Clang IntelliSense, feel free to use let us know. We might be able to add it to one of the future versions of VisualGDB.
    #35812
    teslasystems
    I have a different issue, but it’s also a Code Explorer issue, so I decided to post here.
    When the Code Explorer is opened, it makes the editor very hard to use, because it freezes the interface almost each time I click somewhere in the editor. For example, I was editing one function, then scroll to some other place in the source file and place the edit cursor there. This action freezes the editor for a couple of seconds while the Code Explorer “thinks” about something… The same happens when I switch between tabs. So, the Code Explorer is unusable in fact, because it makes the editor very unresponsive. If the Code Explorer window is closed or hidden, everything is fine, there are no such freezes.
    • This reply was modified 1 year, 8 months ago by teslasystems.
    #35814
    It looks like your technical support period has expired.
    We would be happy to help you, however we would kindly ask you to renew your technical support and install the latest VisualGDB 6.0R3 that includes the latest fixes and optimizations.
    #35859
    teslasystems
    I just reported about the problem that exists in your product.
