CMake – custom target
Sysprogs forums Forums VisualGDB CMake – custom target
  • #21685
    oto313
    I have CMake project and building it with Ninja. I want to build a custom target (see attachment target “paper_sensor_target”). When I click right on target -> Build target, it fails and the output is “VisualGDB: Run “ninja.exe ” in directory “C:/my/projects/Ris/src/Rac/VisualGDB/Debug/interaction_devices/paper_sensor” on local computer
    ninja: error: loading ‘build.ninja’: The system cannot find the file specified.”
    If I want to build any target (with right click -> build) with Ninja it does not work and it does not have to be the custom target. It shows the same message as above.
    I tried also Unix Makefiles but it does not work with the custom target it does not pass the target name to make.
    it runs “Run “C:\SysGCC\arm-eabi\bin\make.exe ” in directory “C:/my/projects/Ris/src/Rac/VisualGDB/Debug/interaction_devices/paper_sensor” on local computer”, so there is no argument paper_sensor_target
    Is there any workaround or can you fix it?
    #21694
    Thanks for reporting this. We have fixed individual target building when using Ninja (and also improved it for regular GNU Make). Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.4.2400.msi
