CMake Custom Shortcuts do not work for Release
Sysprogs forums Forums VisualGDB CMake Custom Shortcuts do not work for Release
  • #32088
    Sottotitolare
    I have successfully imported an existing CMake project with VisualGDB and I can build Debug and Release Builds without any problems.
    However the custom shortcuts do not seem to work properly. Although the configuration page shows the correct values, the custom shortcut only uses the Variable Values of the Debug configuration. My intent is to trigger a copy of the built sources to a different location on the build machine.
    I have attached 2 screenshots showing the problem.
    #32106
    No problem, we have we reproduced and fixed the issue. Please try this build: VisualGDB-5.6.104.4533.msi
