Clean deletes all files on remote host cmake projekt
Sysprogs forums Forums VisualGDB Clean deletes all files on remote host cmake projekt
  • #24282
    I just tested the advanced cmake subsystem. I set the project to access the source files with ssh. Then I did “Clean” from contextmenu:
    —— Clean started: Project: xxx Configuration: Debug VisualGDB ——
    Removing /home/tkunze/xxx/…
    ========== Clean: 1 succeeded, 0 failed, 0 skipped ==========
    tkunze@nb-sys-043:~/xxx$ ls -l
    total 0
    So instead of “make clean” vgdb does a  “rm -rf *”.
    I attached the cgdbcmake file.
    Fortunately it was just a test.
    Yesterday I also tried the cmake-subsystem remote files over SSH and couldn’t get it working with WSL. It only worked after I installed openssh in WSL an choose “localhost” as remote machine instead of WSL.
    Regards,
    Thomas
    #24293
    Sorry, the .vgdbcmake file did not get attached properly. We have just patched the forum engine on our side, so you should be able to upload it again.
    We have also rechecked this on a newly created project and it did get cleant correctly. VisualGDB does have an option to remove the entire remote source directory on clean, however it is hidden and ignored for projects that are using direct SSH file access.
    Please try attaching the .vgdbcmake file again and we will check what is going on.
    #24394
    Here is the file. I will try to reproduce this.
    #24397
    I guess this happened because I cleared “Binary directory” in cmake project settings. My cmake-file doen’t support out-of-source builds. So need to clear this to make builds work.
    #24406
    Thanks for sharing the details – it helped pinpoint the problem on our side. We have added a check for this case and an option to clean the projects via “make clean” in this build: VisualGDB-5.4.103.3020.msi
