Clang IntelliSense wrong pointer size in embedded projects
Sysprogs forums Forums VisualGDB Clang IntelliSense wrong pointer size in embedded projects
  • This topic has 2 replies, 2 voices, and was last updated 5 years ago by bbr.
  • #30152
    bbr
    it seems like that the clang IntelliSense uses the pointer size of the development machine instead of the target embedded platform. The attachedĀ  project compiles fine but IntelliSense fails on the static assert.
    Is there a option to change this?
    #30156
    This might be related to a bug where VisualGDB would not pass the target selection flags to the IntelliSense engine. Please try this build: VisualGDB-5.6.1.4051.msi
    If it doesn’t solve the problem, please try checking the CppEngineTuningInfo.xml file. It contains a list of rules for determining the target based on the preprocessor flags discovered from the project. Please let us know if your target is listed there and the flags shown in View->Clang IntelliSense Status->Project Structure match any of the targets defined in CppEngineTuningInfo.xml.
    #30157
    bbr
    thank you, the new build solved the issue.
