Sysprogs forums › Forums › VisualGDB › Clang Intellisense Errors
- This topic has 7 replies, 2 voices, and was last updated 10 years, 4 months ago by
October 19, 2015 at 11:32 #7080
NormD
ParticipantI find a lot of Clang errors in the Clang Intellisense Diagnostics Console
VS2008
I include the whole log since I cannot find any way to attach a file
[+0:00:00.000] Starting operation: Wrapping c:\Controller1\Controller1.vcproj [+0:00:00.093] c:\Controller1\Controller1.vcproj: found 32 source files [+0:00:04.921] Operation completed: Wrapping c:\Controller1\Controller1.vcproj [4906 msec] [+0:00:04.937] [0%] gftoCheckingForModifications [+0:00:05.015] c:\Controller1\Msgs.cpp belongs to a compatible project and will be handled by our engine [+0:00:05.031] c:\Controller1\Msgs.cpp belongs to a compatible project and will be handled by our engine [+0:00:05.640] [25%] gftoCheckingForModifications [+0:00:05.890] [50%] gftoCheckingForModifications [+0:00:06.078] [75%] gftoCheckingForModifications [+0:00:06.187] [0%] gftoScanningFile inits.cpp [+0:00:06.234] [8%] gftoScanningFile procexeccont.cpp [+0:00:06.265] [16%] gftoScanningFile ram.cpp [+0:00:06.328] [25%] gftoScanningFile spcocont.cpp [+0:00:06.328] [33%] gftoScanningFile libgen.cpp [+0:00:06.406] Active document changed to c:\Controller1\Msgs.cpp [+0:00:06.421] [41%] gftoScanningFile libhw.cpp [+0:00:06.421] [50%] gftoScanningFile libspco.cpp [+0:00:06.468] c:\Controller1\Inits.cpp belongs to a compatible project and will be handled by our engine [+0:00:06.468] c:\Controller1\Inits.cpp belongs to a compatible project and will be handled by our engine [+0:00:06.437] [58%] gftoScanningFile libsys.cpp [+0:00:06.593] Active document changed to c:\Controller1\Inits.cpp [+0:00:06.593] c:\Controller1\LibSpCo.cpp belongs to a compatible project and will be handled by our engine [+0:00:06.609] c:\Controller1\LibSpCo.cpp belongs to a compatible project and will be handled by our engine [+0:00:06.625] [66%] gftoScanningFile libxml.cpp [+0:00:06.671] Starting operation: Parse - Check [+0:00:06.671] Starting operation: Reparsing c:\Controller1\Inits.cpp [+0:00:06.687] Active document changed to c:\Controller1\LibSpCo.cpp [+0:00:06.687] c:\Controller1\RAM.cpp belongs to a compatible project and will be handled by our engine [+0:00:06.703] c:\Controller1\RAM.cpp belongs to a compatible project and will be handled by our engine [+0:00:06.718] Starting operation: Parse - Check [+0:00:06.718] Starting operation: Reparsing c:\Controller1\LibSpCo.cpp [+0:00:06.765] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:00:06.765] c:\Controller1\inits.cpp has changed since last build. Doing full analysis... [+0:00:06.781] Active document changed to c:\Controller1\RAM.cpp [+0:00:06.781] [75%] gftoScanningFile constants.h [+0:00:06.781] c:\Controller1\Externs.h belongs to a compatible project and will be handled by our engine [+0:00:06.812] [83%] gftoScanningFile externs.h [+0:00:06.843] c:\Controller1\Externs.h belongs to a compatible project and will be handled by our engine [+0:00:06.843] [91%] gftoScanningFile prototypes.h [+0:00:06.843] Starting operation: Parse - Check [+0:00:06.843] Starting operation: Reparsing c:\Controller1\RAM.cpp [+0:00:06.890] [100%] gftoDone [+0:00:06.890] c:\Controller1\ram.cpp has changed since last build. Doing full analysis... [+0:00:06.890] No changed PSFs found, but c:\Controller1\ram.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 0 PSFs. [+0:00:06.890] Starting fpsParsingFileBody on c:\Controller1\ram.cpp [+0:00:07.093] [0%] gftoCheckingForModifications [+0:00:07.109] [25%] gftoCheckingForModifications [+0:00:07.125] [50%] gftoCheckingForModifications [+0:00:07.140] [75%] gftoCheckingForModifications [+0:00:07.156] [0%] gftoBypassed [+0:00:07.187] c:\Controller1\dbget.cpp has changed since last build. Doing full analysis... [+0:00:07.515] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:00:07.515] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:00:07.625] Existing RDB for c:\Controller1\libspco.cpp matches the source file. No rebuild performed. [+0:00:07.625] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:00:07.750] c:\Controller1\libspco.cpp has not changed since last build. Doing a quick recheck... [+0:00:07.812] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:00:07.812] Rebuilding PSF 3 (normal preamble)... [+0:00:07.812] Starting fpsBuildingPreamble on c:\Controller1\inits.cpp [+0:00:10.203] Starting fpsAnalyzingReferences on c:\Controller1\ram.cpp [+0:00:11.609] Completed fpsAnalyzingReferences on c:\Controller1\ram.cpp [+0:00:11.625] Completed fpsBuildingPreamble on c:\Controller1\inits.cpp [+0:00:11.625] Successfully rebuilt PSF 3 (normal preamble)... [+0:00:11.625] Saving PSF 3 (normal preamble)... [+0:00:11.625] Starting fpsSavingPSF on c:\Controller1\inits.cpp [+0:00:11.640] Completed fpsSavingPSF on c:\Controller1\inits.cpp [+0:00:11.640] Successfully saved PSF 3 (normal preamble)... [+0:00:11.640] Starting fpsParsingFileBody on c:\Controller1\inits.cpp [+0:00:12.109] Starting fpsAnalyzingReferences on c:\Controller1\inits.cpp [+0:00:13.125] Completed fpsParsingFileBody on c:\Controller1\ram.cpp [+0:00:13.171] c:\Controller1\ram.cpp has not changed since last build. Doing a quick recheck... [+0:00:13.687] Completed fpsAnalyzingReferences on c:\Controller1\inits.cpp [+0:00:13.703] Saved data for c:\Controller1\ram.cpp is up to date. Skipping reparsing... [+0:00:14.109] Checked c:\Controller1\RAM.cpp: 1 error records [+0:00:14.390] Operation completed: Reparsing c:\Controller1\RAM.cpp [7546 msec] [+0:00:14.531] Operation completed: Parse - Check [7687 msec] [+0:00:14.640] Completed fpsParsingFileBody on c:\Controller1\inits.cpp [+0:00:14.640] c:\Controller1\inits.cpp has not changed since last build. Doing a quick recheck... [+0:00:14.656] No changed PSFs found, but c:\Controller1\dbget.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:00:14.656] Starting fpsParsingFileBody on c:\Controller1\dbget.cpp [+0:00:15.781] Starting fpsAnalyzingReferences on c:\Controller1\dbget.cpp [+0:00:17.078] Completed fpsAnalyzingReferences on c:\Controller1\dbget.cpp [+0:00:17.093] Completed fpsParsingFileBody on c:\Controller1\dbget.cpp [+0:00:17.109] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:00:17.125] c:\Controller1\libspco.cpp has not changed since last build. Doing a quick recheck... [+0:00:17.140] Saved data for c:\Controller1\inits.cpp is up to date. Skipping reparsing... [+0:00:17.156] c:\Controller1\inits.cpp has not changed since last build. Doing a quick recheck... [+0:00:17.171] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:00:17.406] Saved data for c:\Controller1\inits.cpp is up to date. Skipping reparsing... [+0:00:17.796] Active document changed to c:\Controller1\Externs.h [+0:00:17.812] c:\Controller1\Prototypes.h belongs to a compatible project and will be handled by our engine [+0:00:17.812] c:\Controller1\Prototypes.h belongs to a compatible project and will be handled by our engine [+0:00:17.812] Starting operation: Parse - Check [+0:00:17.812] Starting operation: Reparsing c:\Controller1\Externs.h [+0:00:17.812] [0%] gftoCheckingForModifications [+0:00:17.828] c:\Controller1\externs.h has changed since last build. Doing full analysis... [+0:00:17.828] PSF 0 (normal preamble) does not match main file. It will be re-built. [+0:00:17.828] Rebuilding PSF 0 (normal preamble)... [+0:00:17.828] Starting fpsBuildingPreamble on c:\Controller1\externs.h [+0:00:17.875] [25%] gftoCheckingForModifications [+0:00:18.046] [50%] gftoCheckingForModifications [+0:00:17.828] Thread was being aborted. while trying to parse c:\Controller1\Inits.cpp [+0:00:17.828] Stack trace: [+0:00:17.828] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:17.828] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:17.828] at bp.ae.a(qg A_0) [+0:00:17.828] at CppLanguageService.SafeExecutionWrapper
1.<>c__DisplayClass41.a() [+0:00:17.828] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:17.828] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:17.828] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:18.171] Operation completed: Reparsing c:\Controller1\Inits.cpp [11500 msec] [+0:00:18.171] Thread was being aborted. while trying to check source for errors [+0:00:18.171] Stack trace: [+0:00:18.171] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:18.171] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:18.171] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:18.171] Operation completed: Parse - Check [11500 msec] [+0:00:17.828] Thread was being aborted. while trying to parse c:\Controller1\LibSpCo.cpp [+0:00:17.828] Stack trace: [+0:00:17.828] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:17.828] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:17.828] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:17.828] at bp.ae.a(qg A_0) [+0:00:17.828] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:17.828] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:17.828] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:17.828] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:18.171] Operation completed: Reparsing c:\Controller1\LibSpCo.cpp [11453 msec] [+0:00:18.171] Thread was being aborted. while trying to check source for errors [+0:00:18.171] Stack trace: [+0:00:18.171] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:18.171] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:18.171] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:18.187] Operation completed: Parse - Check [11468 msec] [+0:00:18.296] [75%] gftoCheckingForModifications [+0:00:18.625] [0%] gftoBypassed [+0:00:18.984] Saved data for c:\Controller1\dbget.cpp is up to date. Skipping reparsing... [+0:00:19.015] Saved data for c:\Controller1\inits.cpp is up to date. Skipping reparsing... [+0:00:19.031] Saved data for c:\Controller1\ram.cpp is up to date. Skipping reparsing... [+0:00:19.062] Completed fpsBuildingPreamble on c:\Controller1\externs.h [+0:00:19.062] Successfully rebuilt PSF 0 (normal preamble)... [+0:00:19.062] Saving PSF 0 (normal preamble)... [+0:00:19.062] Starting fpsSavingPSF on c:\Controller1\externs.h [+0:00:19.062] Completed fpsSavingPSF on c:\Controller1\externs.h [+0:00:19.062] Successfully saved PSF 0 (normal preamble)... [+0:00:19.062] Starting fpsParsingFileBody on c:\Controller1\externs.h [+0:00:19.078] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:00:19.250] Active document changed to c:\Controller1\Prototypes.h [+0:00:19.265] c:\Controller1\Constants.h belongs to a compatible project and will be handled by our engine [+0:00:19.281] c:\Controller1\Constants.h belongs to a compatible project and will be handled by our engine [+0:00:19.296] Starting operation: Parse - Check [+0:00:19.296] Starting operation: Reparsing c:\Controller1\Prototypes.h [+0:00:19.296] [0%] gftoCheckingForModifications [+0:00:19.296] c:\Controller1\prototypes.h has changed since last build. Doing full analysis... [+0:00:19.296] PSF 0 (normal preamble) does not match main file. It will be re-built. [+0:00:19.296] Rebuilding PSF 0 (normal preamble)... [+0:00:19.296] Starting fpsBuildingPreamble on c:\Controller1\prototypes.h [+0:00:19.359] Starting fpsAnalyzingReferences on c:\Controller1\externs.h [+0:00:19.953] [25%] gftoCheckingForModifications [+0:00:20.171] [50%] gftoCheckingForModifications [+0:00:20.812] Completed fpsAnalyzingReferences on c:\Controller1\externs.h [+0:00:20.875] [75%] gftoCheckingForModifications [+0:00:21.171] Completed fpsParsingFileBody on c:\Controller1\externs.h [+0:00:21.203] c:\Controller1\externs.h has not changed since last build. Doing a quick recheck... [+0:00:21.312] [0%] gftoBypassed [+0:00:21.640] Saved data for c:\Controller1\externs.h is up to date. Skipping reparsing... [+0:00:21.812] Thread was being aborted. while trying to parse c:\Controller1\Externs.h [+0:00:21.812] Stack trace: [+0:00:21.812] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:21.812] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:21.812] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:21.812] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:21.812] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:21.812] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:21.812] at bp.ae.a(qg A_0) [+0:00:21.812] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:21.812] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:21.812] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:21.812] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:21.828] Operation completed: Reparsing c:\Controller1\Externs.h [4015 msec] [+0:00:21.828] Thread was being aborted. while trying to check source for errors [+0:00:21.828] Stack trace: [+0:00:21.828] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:21.828] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:21.828] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:21.828] Operation completed: Parse - Check [4015 msec] [+0:00:21.828] Saved data for c:\Controller1\dbget.cpp is up to date. Skipping reparsing... [+0:00:21.859] Saved data for c:\Controller1\inits.cpp is up to date. Skipping reparsing... [+0:00:21.875] Saved data for c:\Controller1\ram.cpp is up to date. Skipping reparsing... [+0:00:21.890] Completed fpsBuildingPreamble on c:\Controller1\prototypes.h [+0:00:21.890] Successfully rebuilt PSF 0 (normal preamble)... [+0:00:21.890] Saving PSF 0 (normal preamble)... [+0:00:21.890] Starting fpsSavingPSF on c:\Controller1\prototypes.h [+0:00:21.890] Completed fpsSavingPSF on c:\Controller1\prototypes.h [+0:00:21.890] Successfully saved PSF 0 (normal preamble)... [+0:00:21.890] Starting fpsParsingFileBody on c:\Controller1\prototypes.h [+0:00:22.109] Starting fpsAnalyzingReferences on c:\Controller1\prototypes.h [+0:00:22.187] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:00:22.406] Active document changed to c:\Controller1\Constants.h [+0:00:22.453] c:\Controller1\DbGet.cpp belongs to a compatible project and will be handled by our engine [+0:00:22.453] c:\Controller1\DbGet.cpp belongs to a compatible project and will be handled by our engine [+0:00:22.500] Starting operation: Parse - Check [+0:00:22.500] Starting operation: Reparsing c:\Controller1\Constants.h [+0:00:22.593] Active document changed to c:\Controller1\DbGet.cpp [+0:00:22.578] c:\Controller1\constants.h has changed since last build. Doing full analysis... [+0:00:22.578] PSF 0 (normal preamble) does not match main file. It will be re-built. [+0:00:22.578] Rebuilding PSF 0 (normal preamble)... [+0:00:22.578] Starting fpsBuildingPreamble on c:\Controller1\constants.h [+0:00:22.640] c:\Controller1\LibAdd.cpp belongs to a compatible project and will be handled by our engine [+0:00:22.656] c:\Controller1\LibAdd.cpp belongs to a compatible project and will be handled by our engine [+0:00:22.796] Starting operation: Parse - Check [+0:00:22.796] Starting operation: Reparsing c:\Controller1\DbGet.cpp [+0:00:22.796] Active document changed to c:\Controller1\LibAdd.cpp [+0:00:22.859] c:\Controller1\LibDel.cpp belongs to a compatible project and will be handled by our engine [+0:00:22.875] c:\Controller1\LibDel.cpp belongs to a compatible project and will be handled by our engine [+0:00:22.906] Starting operation: Parse - Check [+0:00:22.906] Starting operation: Reparsing c:\Controller1\LibAdd.cpp [+0:00:25.375] Thread was being aborted. while trying to parse c:\Controller1\Prototypes.h [+0:00:25.375] Stack trace: [+0:00:25.375] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:25.375] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:25.375] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:25.375] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:25.375] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:25.375] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:25.375] at bp.ae.a(qg A_0) [+0:00:25.375] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:25.375] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:25.375] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:25.375] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:25.375] Operation completed: Reparsing c:\Controller1\Prototypes.h [6078 msec] [+0:00:25.375] Thread was being aborted. while trying to check source for errors [+0:00:25.375] Stack trace: [+0:00:25.375] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:25.375] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:25.375] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:25.375] Operation completed: Parse - Check [6078 msec] [+0:00:23.156] Saved data for c:\Controller1\dbget.cpp is up to date. Skipping reparsing... [+0:00:23.171] c:\Controller1\dbget.cpp has not changed since last build. Doing a quick recheck... [+0:00:23.531] c:\Controller1\libadd.cpp has changed since last build. Doing full analysis... [+0:00:24.234] Completed fpsAnalyzingReferences on c:\Controller1\prototypes.h [+0:00:24.312] Saved data for c:\Controller1\dbget.cpp is up to date. Skipping reparsing... [+0:00:24.312] Starting fpsParsingFileBody on c:\Controller1\dbget.cpp [+0:00:24.593] Completed fpsParsingFileBody on c:\Controller1\prototypes.h [+0:00:24.593] c:\Controller1\prototypes.h has not changed since last build. Doing a quick recheck... [+0:00:24.968] Saved data for c:\Controller1\prototypes.h is up to date. Skipping reparsing... [+0:00:25.453] Active document changed to c:\Controller1\LibDel.cpp [+0:00:25.453] c:\Controller1\DbPut.cpp belongs to a compatible project and will be handled by our engine [+0:00:25.484] c:\Controller1\DbPut.cpp belongs to a compatible project and will be handled by our engine [+0:00:25.484] Starting operation: Parse - Check [+0:00:25.484] Starting operation: Reparsing c:\Controller1\LibDel.cpp [+0:00:25.468] Completed fpsParsingFileBody on c:\Controller1\dbget.cpp [+0:00:25.671] Thread was being aborted. while trying to parse c:\Controller1\DbGet.cpp [+0:00:25.671] Stack trace: [+0:00:25.671] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:25.671] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:25.671] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:25.671] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:25.671] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:25.671] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:25.671] at bp.ae.a(qg A_0) [+0:00:25.671] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:25.671] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:25.671] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:25.671] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:25.671] Operation completed: Reparsing c:\Controller1\DbGet.cpp [2875 msec] [+0:00:25.671] Thread was being aborted. while trying to check source for errors [+0:00:25.671] Stack trace: [+0:00:25.671] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:25.671] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:25.671] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:25.671] Operation completed: Parse - Check [2875 msec] [+0:00:25.687] c:\Controller1\libdel.cpp has changed since last build. Doing full analysis... [+0:00:25.734] No changed PSFs found, but c:\Controller1\libadd.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:00:25.734] Starting fpsParsingFileBody on c:\Controller1\libadd.cpp [+0:00:25.750] Active document changed to c:\Controller1\DbPut.cpp [+0:00:25.765] c:\Controller1\LibSys.cpp belongs to a compatible project and will be handled by our engine [+0:00:25.781] c:\Controller1\LibSys.cpp belongs to a compatible project and will be handled by our engine [+0:00:25.843] Starting operation: Parse - Check [+0:00:25.843] Starting operation: Reparsing c:\Controller1\DbPut.cpp [+0:00:25.843] Active document changed to c:\Controller1\LibSys.cpp [+0:00:25.843] c:\Controller1\LibXml.cpp belongs to a compatible project and will be handled by our engine [+0:00:25.859] c:\Controller1\LibXml.cpp belongs to a compatible project and will be handled by our engine [+0:00:25.859] Starting operation: Parse - Check [+0:00:25.859] Starting operation: Reparsing c:\Controller1\LibSys.cpp [+0:00:25.859] c:\Controller1\dbput.cpp has changed since last build. Doing full analysis... [+0:00:25.875] c:\Controller1\libsys.cpp has changed since last build. Doing full analysis... [+0:00:25.890] Completed fpsBuildingPreamble on c:\Controller1\constants.h [+0:00:25.890] Successfully rebuilt PSF 0 (normal preamble)... [+0:00:25.890] Saving PSF 0 (normal preamble)... [+0:00:25.890] Starting fpsSavingPSF on c:\Controller1\constants.h [+0:00:25.906] Completed fpsSavingPSF on c:\Controller1\constants.h [+0:00:25.906] Successfully saved PSF 0 (normal preamble)... [+0:00:25.906] Starting fpsParsingFileBody on c:\Controller1\constants.h [+0:00:26.109] Starting fpsAnalyzingReferences on c:\Controller1\constants.h [+0:00:26.343] Active document changed to c:\Controller1\LibXml.cpp [+0:00:26.390] c:\Controller1\LibGen.cpp belongs to a compatible project and will be handled by our engine [+0:00:26.390] c:\Controller1\LibGen.cpp belongs to a compatible project and will be handled by our engine [+0:00:26.437] Starting operation: Parse - Check [+0:00:26.437] Starting operation: Reparsing c:\Controller1\LibXml.cpp [+0:00:26.562] c:\Controller1\libxml.cpp has changed since last build. Doing full analysis... [+0:00:26.750] Active document changed to c:\Controller1\LibGen.cpp [+0:00:26.796] c:\Controller1\LibHw.cpp belongs to a compatible project and will be handled by our engine [+0:00:26.796] c:\Controller1\LibHw.cpp belongs to a compatible project and will be handled by our engine [+0:00:26.828] Starting operation: Parse - Check [+0:00:26.828] Starting operation: Reparsing c:\Controller1\LibGen.cpp [+0:00:26.921] c:\Controller1\libgen.cpp has changed since last build. Doing full analysis... [+0:00:27.375] Active document changed to c:\Controller1\LibHw.cpp [+0:00:27.406] c:\Controller1\LibTcp.cpp belongs to a compatible project and will be handled by our engine [+0:00:27.421] c:\Controller1\LibTcp.cpp belongs to a compatible project and will be handled by our engine [+0:00:27.437] Starting operation: Parse - Check [+0:00:27.437] Starting operation: Reparsing c:\Controller1\LibHw.cpp [+0:00:27.609] c:\Controller1\libhw.cpp has changed since last build. Doing full analysis... [+0:00:27.781] Active document changed to c:\Controller1\LibTcp.cpp [+0:00:27.859] c:\Controller1\ProcExecCont.cpp belongs to a compatible project and will be handled by our engine [+0:00:27.875] c:\Controller1\ProcExecCont.cpp belongs to a compatible project and will be handled by our engine [+0:00:28.062] Starting operation: Parse - Check [+0:00:28.062] Starting operation: Reparsing c:\Controller1\LibTcp.cpp [+0:00:28.062] Active document changed to c:\Controller1\ProcExecCont.cpp [+0:00:28.203] c:\Controller1\SpCoCont.cpp belongs to a compatible project and will be handled by our engine [+0:00:28.156] Completed fpsAnalyzingReferences on c:\Controller1\constants.h [+0:00:28.218] c:\Controller1\libtcp.cpp has changed since last build. Doing full analysis... [+0:00:28.218] c:\Controller1\SpCoCont.cpp belongs to a compatible project and will be handled by our engine [+0:00:28.234] Starting operation: Parse - Check [+0:00:28.234] Starting operation: Reparsing c:\Controller1\ProcExecCont.cpp [+0:00:28.375] c:\Controller1\procexeccont.cpp has changed since last build. Doing full analysis... [+0:00:28.640] Starting fpsAnalyzingReferences on c:\Controller1\libadd.cpp [+0:00:28.875] Active document changed to c:\Controller1\SpCoCont.cpp [+0:00:28.937] c:\Controller1\ProcFcstMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:28.953] c:\Controller1\ProcFcstMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:28.953] Starting operation: Parse - Check [+0:00:28.953] Starting operation: Reparsing c:\Controller1\SpCoCont.cpp [+0:00:28.937] Completed fpsParsingFileBody on c:\Controller1\constants.h [+0:00:28.937] c:\Controller1\constants.h has not changed since last build. Doing a quick recheck... [+0:00:30.109] Thread was being aborted. while trying to parse c:\Controller1\Constants.h [+0:00:30.109] Stack trace: [+0:00:30.109] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:30.109] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:30.109] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:30.109] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:30.109] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:30.109] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:30.109] at bp.ae.a(qg A_0) [+0:00:30.109] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:30.109] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:30.109] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:30.109] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:30.125] Operation completed: Reparsing c:\Controller1\Constants.h [7625 msec] [+0:00:30.125] Thread was being aborted. while trying to check source for errors [+0:00:30.125] Stack trace: [+0:00:30.125] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:30.125] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:30.125] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:30.125] Operation completed: Parse - Check [7625 msec] [+0:00:29.578] c:\Controller1\spcocont.cpp has changed since last build. Doing full analysis... [+0:00:30.015] Completed fpsAnalyzingReferences on c:\Controller1\libadd.cpp [+0:00:30.031] Saved data for c:\Controller1\constants.h is up to date. Skipping reparsing... [+0:00:30.171] Completed fpsParsingFileBody on c:\Controller1\libadd.cpp [+0:00:30.171] c:\Controller1\libadd.cpp has not changed since last build. Doing a quick recheck... [+0:00:30.171] No changed PSFs found, but c:\Controller1\libdel.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:00:30.171] Starting fpsParsingFileBody on c:\Controller1\libdel.cpp [+0:00:30.375] Active document changed to c:\Controller1\ProcFcstMngr.cpp [+0:00:30.390] c:\Controller1\ProcWiFiScan.cpp belongs to a compatible project and will be handled by our engine [+0:00:30.406] c:\Controller1\ProcWiFiScan.cpp belongs to a compatible project and will be handled by our engine [+0:00:30.421] Starting operation: Parse - Check [+0:00:30.421] Starting operation: Reparsing c:\Controller1\ProcFcstMngr.cpp [+0:00:30.484] c:\Controller1\procfcstmngr.cpp has changed since last build. Doing full analysis... [+0:00:30.921] Active document changed to c:\Controller1\ProcWiFiScan.cpp [+0:00:30.953] c:\Controller1\ProcInetComm.cpp belongs to a compatible project and will be handled by our engine [+0:00:30.968] c:\Controller1\ProcInetComm.cpp belongs to a compatible project and will be handled by our engine [+0:00:30.968] Starting operation: Parse - Check [+0:00:30.968] Starting operation: Reparsing c:\Controller1\ProcWiFiScan.cpp [+0:00:31.015] c:\Controller1\procwifiscan.cpp has changed since last build. Doing full analysis... [+0:00:31.296] Active document changed to c:\Controller1\ProcInetComm.cpp [+0:00:31.343] c:\Controller1\ProcTimeMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:31.359] c:\Controller1\ProcTimeMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:31.390] Starting operation: Parse - Check [+0:00:31.390] Starting operation: Reparsing c:\Controller1\ProcInetComm.cpp [+0:00:31.359] Starting fpsAnalyzingReferences on c:\Controller1\libdel.cpp [+0:00:31.453] c:\Controller1\procinetcomm.cpp has changed since last build. Doing full analysis... [+0:00:31.937] Active document changed to c:\Controller1\ProcTimeMngr.cpp [+0:00:31.984] c:\Controller1\ProcPinsMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:32.000] c:\Controller1\ProcPinsMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:32.031] Starting operation: Parse - Check [+0:00:32.031] Starting operation: Reparsing c:\Controller1\ProcTimeMngr.cpp [+0:00:32.125] c:\Controller1\proctimemngr.cpp has changed since last build. Doing full analysis... [+0:00:32.421] Active document changed to c:\Controller1\ProcPinsMngr.cpp [+0:00:32.468] c:\Controller1\LibString.cpp belongs to a compatible project and will be handled by our engine [+0:00:32.484] c:\Controller1\LibString.cpp belongs to a compatible project and will be handled by our engine [+0:00:32.500] Starting operation: Parse - Check [+0:00:32.500] Starting operation: Reparsing c:\Controller1\ProcPinsMngr.cpp [+0:00:32.531] c:\Controller1\procpinsmngr.cpp has changed since last build. Doing full analysis... [+0:00:32.812] Active document changed to c:\Controller1\LibString.cpp [+0:00:32.859] c:\Controller1\ProcUserWork.cpp belongs to a compatible project and will be handled by our engine [+0:00:32.875] c:\Controller1\ProcUserWork.cpp belongs to a compatible project and will be handled by our engine [+0:00:32.890] Starting operation: Parse - Check [+0:00:32.890] Starting operation: Reparsing c:\Controller1\LibString.cpp [+0:00:32.937] Completed fpsAnalyzingReferences on c:\Controller1\libdel.cpp [+0:00:32.953] c:\Controller1\libstring.cpp has changed since last build. Doing full analysis... [+0:00:32.953] No changed PSFs found, but c:\Controller1\libstring.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 0 PSFs. [+0:00:32.953] Starting fpsParsingFileBody on c:\Controller1\libstring.cpp [+0:00:33.031] Completed fpsParsingFileBody on c:\Controller1\libdel.cpp [+0:00:33.046] c:\Controller1\libdel.cpp has not changed since last build. Doing a quick recheck... [+0:00:33.312] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:00:33.312] Rebuilding PSF 3 (normal preamble)... [+0:00:33.312] Starting fpsBuildingPreamble on c:\Controller1\dbput.cpp [+0:00:33.390] Active document changed to c:\Controller1\ProcUserWork.cpp [+0:00:33.406] c:\Controller1\LibState.cpp belongs to a compatible project and will be handled by our engine [+0:00:33.421] c:\Controller1\LibState.cpp belongs to a compatible project and will be handled by our engine [+0:00:33.421] Starting operation: Parse - Check [+0:00:33.421] Starting operation: Reparsing c:\Controller1\ProcUserWork.cpp [+0:00:33.484] c:\Controller1\procuserwork.cpp has changed since last build. Doing full analysis... [+0:00:33.500] No changed PSFs found, but c:\Controller1\procuserwork.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 0 PSFs. [+0:00:33.500] Starting fpsParsingFileBody on c:\Controller1\procuserwork.cpp [+0:00:34.000] Active document changed to c:\Controller1\LibState.cpp [+0:00:34.046] c:\Controller1\ProcUnitMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:34.046] c:\Controller1\ProcUnitMngr.cpp belongs to a compatible project and will be handled by our engine [+0:00:34.093] Starting operation: Parse - Check [+0:00:34.093] Starting operation: Reparsing c:\Controller1\LibState.cpp [+0:00:34.203] c:\Controller1\libstate.cpp has changed since last build. Doing full analysis... [+0:00:34.296] Active document changed to c:\Controller1\ProcUnitMngr.cpp [+0:00:34.296] c:\Controller1\LibMove.cpp belongs to a compatible project and will be handled by our engine [+0:00:34.328] c:\Controller1\LibMove.cpp belongs to a compatible project and will be handled by our engine [+0:00:34.343] Starting operation: Parse - Check [+0:00:34.343] Starting operation: Reparsing c:\Controller1\ProcUnitMngr.cpp [+0:00:34.453] c:\Controller1\procunitmngr.cpp has changed since last build. Doing full analysis... [+0:00:35.078] Active document changed to c:\Controller1\LibMove.cpp [+0:00:35.109] c:\Controller1\ProcUserDisp.cpp belongs to a compatible project and will be handled by our engine [+0:00:35.125] c:\Controller1\ProcUserDisp.cpp belongs to a compatible project and will be handled by our engine [+0:00:35.156] Starting operation: Parse - Check [+0:00:35.156] Starting operation: Reparsing c:\Controller1\LibMove.cpp [+0:00:35.296] c:\Controller1\libmove.cpp has changed since last build. Doing full analysis... [+0:00:35.484] Active document changed to c:\Controller1\ProcUserDisp.cpp [+0:00:35.500] c:\Controller1\ProcNetwComm.cpp belongs to a compatible project and will be handled by our engine [+0:00:35.515] c:\Controller1\ProcNetwComm.cpp belongs to a compatible project and will be handled by our engine [+0:00:35.531] Starting operation: Parse - Check [+0:00:35.531] Starting operation: Reparsing c:\Controller1\ProcUserDisp.cpp [+0:00:35.671] c:\Controller1\procuserdisp.cpp has changed since last build. Doing full analysis... [+0:00:35.671] No changed PSFs found, but c:\Controller1\procuserdisp.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 0 PSFs. [+0:00:35.671] Starting fpsParsingFileBody on c:\Controller1\procuserdisp.cpp [+0:00:35.984] Active document changed to c:\Controller1\ProcNetwComm.cpp [+0:00:38.468] Starting fpsAnalyzingReferences on c:\Controller1\procuserwork.cpp [+0:00:38.687] Starting operation: Parse - Check [+0:00:38.687] Starting operation: Reparsing c:\Controller1\ProcNetwComm.cpp [+0:00:38.968] c:\Controller1\procnetwcomm.cpp has changed since last build. Doing full analysis... [+0:00:39.296] Starting fpsAnalyzingReferences on c:\Controller1\libstring.cpp [+0:00:41.093] Completed fpsAnalyzingReferences on c:\Controller1\procuserwork.cpp [+0:00:41.234] Completed fpsBuildingPreamble on c:\Controller1\dbput.cpp [+0:00:41.234] Successfully rebuilt PSF 3 (normal preamble)... [+0:00:41.234] Saving PSF 3 (normal preamble)... [+0:00:41.234] Starting fpsSavingPSF on c:\Controller1\dbput.cpp [+0:00:41.453] Completed fpsSavingPSF on c:\Controller1\dbput.cpp [+0:00:41.453] Successfully saved PSF 3 (normal preamble)... [+0:00:41.453] Starting fpsParsingFileBody on c:\Controller1\dbput.cpp [+0:00:42.187] Completed fpsAnalyzingReferences on c:\Controller1\libstring.cpp [+0:00:42.437] Completed fpsParsingFileBody on c:\Controller1\procuserwork.cpp [+0:00:42.437] c:\Controller1\procuserwork.cpp has not changed since last build. Doing a quick recheck... [+0:00:42.546] Starting fpsAnalyzingReferences on c:\Controller1\dbput.cpp [+0:00:44.609] Starting fpsAnalyzingReferences on c:\Controller1\procuserdisp.cpp [+0:00:45.703] Thread was being aborted. while trying to parse c:\Controller1\ProcUserWork.cpp [+0:00:45.703] Stack trace: [+0:00:45.703] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:45.703] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:45.703] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:45.703] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:45.703] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:45.703] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:45.703] at bp.ae.a(qg A_0) [+0:00:45.703] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:45.703] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:45.703] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:45.703] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:45.703] Operation completed: Reparsing c:\Controller1\ProcUserWork.cpp [12281 msec] [+0:00:45.703] Thread was being aborted. while trying to check source for errors [+0:00:45.703] Stack trace: [+0:00:45.703] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:45.703] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:45.703] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:45.718] Operation completed: Parse - Check [12296 msec] [+0:00:48.281] Thread was being aborted. while trying to parse c:\Controller1\LibString.cpp [+0:00:48.281] Stack trace: [+0:00:48.281] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:48.281] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:48.281] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:48.281] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:48.281] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:48.281] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:48.281] at bp.ae.a(qg A_0) [+0:00:48.281] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:48.281] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:48.281] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:48.281] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:48.296] Operation completed: Reparsing c:\Controller1\LibString.cpp [15406 msec] [+0:00:48.296] Thread was being aborted. while trying to check source for errors [+0:00:48.296] Stack trace: [+0:00:48.296] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:48.296] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:48.296] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:48.296] Operation completed: Parse - Check [15406 msec] [+0:00:44.953] Completed fpsParsingFileBody on c:\Controller1\libstring.cpp [+0:00:45.015] c:\Controller1\libstring.cpp has not changed since last build. Doing a quick recheck... [+0:00:45.359] Saved data for c:\Controller1\procuserwork.cpp is up to date. Skipping reparsing... [+0:00:47.593] Completed fpsAnalyzingReferences on c:\Controller1\procuserdisp.cpp [+0:00:47.984] Completed fpsAnalyzingReferences on c:\Controller1\dbput.cpp [+0:00:48.000] Saved data for c:\Controller1\libstring.cpp is up to date. Skipping reparsing... [+0:00:48.343] Completed fpsParsingFileBody on c:\Controller1\procuserdisp.cpp [+0:00:48.562] Active document changed to c:\Controller1\LibSpCo.cpp [+0:00:48.625] Thread was being aborted. while trying to parse c:\Controller1\ProcUserDisp.cpp [+0:00:48.625] Stack trace: [+0:00:48.625] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:00:48.625] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:00:48.625] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:00:48.625] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:00:48.625] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:00:48.625] at qg.a(afk A_0, String A_1, ahj A_2) [+0:00:48.625] at bp.ae.a(qg A_0) [+0:00:48.625] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:00:48.625] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:00:48.625] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:00:48.625] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:48.625] Operation completed: Reparsing c:\Controller1\ProcUserDisp.cpp [13093 msec] [+0:00:48.625] Thread was being aborted. while trying to check source for errors [+0:00:48.625] Stack trace: [+0:00:48.625] at bp.a(afk A_0, String A_1, ahj A_2) [+0:00:48.625] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:00:48.625] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:00:48.625] Operation completed: Parse - Check [13093 msec] [+0:00:48.343] c:\Controller1\procuserdisp.cpp has not changed since last build. Doing a quick recheck... [+0:00:48.375] Completed fpsParsingFileBody on c:\Controller1\dbput.cpp [+0:00:48.375] c:\Controller1\dbput.cpp has not changed since last build. Doing a quick recheck... [+0:00:48.390] Saved data for c:\Controller1\procuserdisp.cpp is up to date. Skipping reparsing... [+0:00:48.687] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:00:48.687] Rebuilding PSF 3 (normal preamble)... [+0:00:48.687] Starting fpsBuildingPreamble on c:\Controller1\libsys.cpp [+0:00:48.796] Starting operation: Parse - Check [+0:00:48.796] Starting operation: Reparsing c:\Controller1\LibSpCo.cpp [+0:00:50.546] Completed fpsBuildingPreamble on c:\Controller1\libsys.cpp [+0:00:50.546] Successfully rebuilt PSF 3 (normal preamble)... [+0:00:50.546] Saving PSF 3 (normal preamble)... [+0:00:50.546] Starting fpsSavingPSF on c:\Controller1\libsys.cpp [+0:00:50.546] Completed fpsSavingPSF on c:\Controller1\libsys.cpp [+0:00:50.546] Successfully saved PSF 3 (normal preamble)... [+0:00:50.546] Starting fpsParsingFileBody on c:\Controller1\libsys.cpp [+0:00:51.265] Starting fpsAnalyzingReferences on c:\Controller1\libsys.cpp [+0:00:53.437] Completed fpsAnalyzingReferences on c:\Controller1\libsys.cpp [+0:00:53.828] Completed fpsParsingFileBody on c:\Controller1\libsys.cpp [+0:00:53.843] c:\Controller1\libsys.cpp has not changed since last build. Doing a quick recheck... [+0:00:54.000] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:00:54.000] Rebuilding PSF 3 (normal preamble)... [+0:00:54.000] Starting fpsBuildingPreamble on c:\Controller1\libxml.cpp [+0:00:55.296] Completed fpsBuildingPreamble on c:\Controller1\libxml.cpp [+0:00:55.296] Successfully rebuilt PSF 3 (normal preamble)... [+0:00:55.296] Saving PSF 3 (normal preamble)... [+0:00:55.296] Starting fpsSavingPSF on c:\Controller1\libxml.cpp [+0:00:55.296] Completed fpsSavingPSF on c:\Controller1\libxml.cpp [+0:00:55.296] Successfully saved PSF 3 (normal preamble)... [+0:00:55.296] Starting fpsParsingFileBody on c:\Controller1\libxml.cpp [+0:00:56.093] Starting fpsAnalyzingReferences on c:\Controller1\libxml.cpp [+0:00:58.343] Completed fpsAnalyzingReferences on c:\Controller1\libxml.cpp [+0:00:58.875] Completed fpsParsingFileBody on c:\Controller1\libxml.cpp [+0:00:58.875] c:\Controller1\libxml.cpp has not changed since last build. Doing a quick recheck... [+0:00:58.984] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:00:58.984] Rebuilding PSF 3 (normal preamble)... [+0:00:58.984] Starting fpsBuildingPreamble on c:\Controller1\libgen.cpp [+0:01:00.468] Completed fpsBuildingPreamble on c:\Controller1\libgen.cpp [+0:01:00.468] Successfully rebuilt PSF 3 (normal preamble)... [+0:01:00.468] Saving PSF 3 (normal preamble)... [+0:01:00.468] Starting fpsSavingPSF on c:\Controller1\libgen.cpp [+0:01:00.468] Completed fpsSavingPSF on c:\Controller1\libgen.cpp [+0:01:00.468] Successfully saved PSF 3 (normal preamble)... [+0:01:00.468] Starting fpsParsingFileBody on c:\Controller1\libgen.cpp [+0:01:00.828] Starting fpsAnalyzingReferences on c:\Controller1\libgen.cpp [+0:01:02.718] Completed fpsAnalyzingReferences on c:\Controller1\libgen.cpp [+0:01:03.062] Completed fpsParsingFileBody on c:\Controller1\libgen.cpp [+0:01:03.078] c:\Controller1\libgen.cpp has not changed since last build. Doing a quick recheck... [+0:01:03.156] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:01:03.156] Rebuilding PSF 3 (normal preamble)... [+0:01:03.156] Starting fpsBuildingPreamble on c:\Controller1\libhw.cpp [+0:01:04.593] Completed fpsBuildingPreamble on c:\Controller1\libhw.cpp [+0:01:04.593] Successfully rebuilt PSF 3 (normal preamble)... [+0:01:04.593] Saving PSF 3 (normal preamble)... [+0:01:04.593] Starting fpsSavingPSF on c:\Controller1\libhw.cpp [+0:01:04.609] Completed fpsSavingPSF on c:\Controller1\libhw.cpp [+0:01:04.609] Successfully saved PSF 3 (normal preamble)... [+0:01:04.609] Starting fpsParsingFileBody on c:\Controller1\libhw.cpp [+0:01:04.875] Starting fpsAnalyzingReferences on c:\Controller1\libhw.cpp [+0:01:06.921] Completed fpsAnalyzingReferences on c:\Controller1\libhw.cpp [+0:01:07.312] Completed fpsParsingFileBody on c:\Controller1\libhw.cpp [+0:01:07.312] c:\Controller1\libhw.cpp has not changed since last build. Doing a quick recheck... [+0:01:07.453] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:01:07.453] Rebuilding PSF 3 (normal preamble)... [+0:01:07.453] Starting fpsBuildingPreamble on c:\Controller1\libtcp.cpp [+0:01:08.906] Completed fpsBuildingPreamble on c:\Controller1\libtcp.cpp [+0:01:08.906] Successfully rebuilt PSF 3 (normal preamble)... [+0:01:08.906] Saving PSF 3 (normal preamble)... [+0:01:08.906] Starting fpsSavingPSF on c:\Controller1\libtcp.cpp [+0:01:08.906] Completed fpsSavingPSF on c:\Controller1\libtcp.cpp [+0:01:08.906] Successfully saved PSF 3 (normal preamble)... [+0:01:08.906] Starting fpsParsingFileBody on c:\Controller1\libtcp.cpp [+0:01:09.171] Starting fpsAnalyzingReferences on c:\Controller1\libtcp.cpp [+0:01:10.890] Completed fpsAnalyzingReferences on c:\Controller1\libtcp.cpp [+0:01:11.140] Completed fpsParsingFileBody on c:\Controller1\libtcp.cpp [+0:01:11.140] c:\Controller1\libtcp.cpp has not changed since last build. Doing a quick recheck... [+0:01:11.343] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:01:11.343] Rebuilding PSF 3 (normal preamble)... [+0:01:11.343] Starting fpsBuildingPreamble on c:\Controller1\procexeccont.cpp [+0:01:12.609] Completed fpsBuildingPreamble on c:\Controller1\procexeccont.cpp [+0:01:12.609] Successfully rebuilt PSF 3 (normal preamble)... [+0:01:12.609] Saving PSF 3 (normal preamble)... [+0:01:12.609] Starting fpsSavingPSF on c:\Controller1\procexeccont.cpp [+0:01:12.609] Completed fpsSavingPSF on c:\Controller1\procexeccont.cpp [+0:01:12.609] Successfully saved PSF 3 (normal preamble)... [+0:01:12.609] Starting fpsParsingFileBody on c:\Controller1\procexeccont.cpp [+0:01:13.078] Starting fpsAnalyzingReferences on c:\Controller1\procexeccont.cpp [+0:01:15.140] Completed fpsAnalyzingReferences on c:\Controller1\procexeccont.cpp [+0:01:15.562] Completed fpsParsingFileBody on c:\Controller1\procexeccont.cpp [+0:01:15.562] c:\Controller1\procexeccont.cpp has not changed since last build. Doing a quick recheck... [+0:01:15.656] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:01:15.656] Rebuilding PSF 3 (normal preamble)... [+0:01:15.656] Starting fpsBuildingPreamble on c:\Controller1\spcocont.cpp [+0:01:17.015] Completed fpsBuildingPreamble on c:\Controller1\spcocont.cpp [+0:01:17.015] Successfully rebuilt PSF 3 (normal preamble)... [+0:01:17.015] Saving PSF 3 (normal preamble)... [+0:01:17.015] Starting fpsSavingPSF on c:\Controller1\spcocont.cpp [+0:01:17.015] Completed fpsSavingPSF on c:\Controller1\spcocont.cpp [+0:01:17.015] Successfully saved PSF 3 (normal preamble)... [+0:01:17.015] Starting fpsParsingFileBody on c:\Controller1\spcocont.cpp [+0:01:17.203] Starting fpsAnalyzingReferences on c:\Controller1\spcocont.cpp [+0:01:18.687] Completed fpsAnalyzingReferences on c:\Controller1\spcocont.cpp [+0:01:19.000] Completed fpsParsingFileBody on c:\Controller1\spcocont.cpp [+0:01:19.000] c:\Controller1\spcocont.cpp has not changed since last build. Doing a quick recheck... [+0:01:19.203] Thread was being aborted. while trying to parse c:\Controller1\LibAdd.cpp [+0:01:19.203] Stack trace: [+0:01:19.203] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:19.203] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:19.203] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:19.203] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:19.203] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:19.203] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:19.203] at bp.ae.a(qg A_0) [+0:01:19.203] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:19.203] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:19.203] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:19.203] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:19.203] Operation completed: Reparsing c:\Controller1\LibAdd.cpp [56296 msec] [+0:01:19.203] Thread was being aborted. while trying to check source for errors [+0:01:19.203] Stack trace: [+0:01:19.203] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:19.203] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:19.203] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:19.218] Operation completed: Parse - Check [56312 msec] [+0:01:19.015] Saved data for c:\Controller1\libadd.cpp is up to date. Skipping reparsing... [+0:01:19.343] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:01:19.343] Rebuilding PSF 3 (normal preamble)... [+0:01:19.343] Starting fpsBuildingPreamble on c:\Controller1\procfcstmngr.cpp [+0:01:20.687] Completed fpsBuildingPreamble on c:\Controller1\procfcstmngr.cpp [+0:01:20.687] Successfully rebuilt PSF 3 (normal preamble)... [+0:01:20.687] Saving PSF 3 (normal preamble)... [+0:01:20.687] Starting fpsSavingPSF on c:\Controller1\procfcstmngr.cpp [+0:01:20.703] Completed fpsSavingPSF on c:\Controller1\procfcstmngr.cpp [+0:01:20.703] Successfully saved PSF 3 (normal preamble)... [+0:01:20.703] Starting fpsParsingFileBody on c:\Controller1\procfcstmngr.cpp [+0:01:20.984] Starting fpsAnalyzingReferences on c:\Controller1\procfcstmngr.cpp [+0:01:22.859] Completed fpsAnalyzingReferences on c:\Controller1\procfcstmngr.cpp [+0:01:22.890] Completed fpsParsingFileBody on c:\Controller1\procfcstmngr.cpp [+0:01:22.906] c:\Controller1\procfcstmngr.cpp has not changed since last build. Doing a quick recheck... [+0:01:22.906] No changed PSFs found, but c:\Controller1\procwifiscan.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:22.906] Starting fpsParsingFileBody on c:\Controller1\procwifiscan.cpp [+0:01:23.859] Starting fpsAnalyzingReferences on c:\Controller1\procwifiscan.cpp [+0:01:25.218] Completed fpsAnalyzingReferences on c:\Controller1\procwifiscan.cpp [+0:01:25.375] Completed fpsParsingFileBody on c:\Controller1\procwifiscan.cpp [+0:01:25.375] c:\Controller1\procwifiscan.cpp has not changed since last build. Doing a quick recheck... [+0:01:25.375] No changed PSFs found, but c:\Controller1\procinetcomm.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:25.375] Starting fpsParsingFileBody on c:\Controller1\procinetcomm.cpp [+0:01:26.343] Starting fpsAnalyzingReferences on c:\Controller1\procinetcomm.cpp [+0:01:28.046] Completed fpsAnalyzingReferences on c:\Controller1\procinetcomm.cpp [+0:01:28.109] Completed fpsParsingFileBody on c:\Controller1\procinetcomm.cpp [+0:01:28.109] c:\Controller1\procinetcomm.cpp has not changed since last build. Doing a quick recheck... [+0:01:28.109] No changed PSFs found, but c:\Controller1\proctimemngr.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:28.109] Starting fpsParsingFileBody on c:\Controller1\proctimemngr.cpp [+0:01:29.093] Starting fpsAnalyzingReferences on c:\Controller1\proctimemngr.cpp [+0:01:30.640] Completed fpsAnalyzingReferences on c:\Controller1\proctimemngr.cpp [+0:01:30.687] Completed fpsParsingFileBody on c:\Controller1\proctimemngr.cpp [+0:01:30.687] c:\Controller1\proctimemngr.cpp has not changed since last build. Doing a quick recheck... [+0:01:30.703] No changed PSFs found, but c:\Controller1\procpinsmngr.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:30.703] Starting fpsParsingFileBody on c:\Controller1\procpinsmngr.cpp [+0:01:31.796] Starting fpsAnalyzingReferences on c:\Controller1\procpinsmngr.cpp [+0:01:33.234] Completed fpsAnalyzingReferences on c:\Controller1\procpinsmngr.cpp [+0:01:33.296] Completed fpsParsingFileBody on c:\Controller1\procpinsmngr.cpp [+0:01:33.468] Thread was being aborted. while trying to parse c:\Controller1\LibDel.cpp [+0:01:33.468] Stack trace: [+0:01:33.468] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:33.468] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:33.468] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:33.468] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:33.468] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:33.468] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:33.468] at bp.ae.a(qg A_0) [+0:01:33.468] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:33.468] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:33.468] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:33.468] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:33.484] Operation completed: Reparsing c:\Controller1\LibDel.cpp [68000 msec] [+0:01:33.484] Thread was being aborted. while trying to check source for errors [+0:01:33.484] Stack trace: [+0:01:33.484] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:33.484] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:33.484] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:33.484] Operation completed: Parse - Check [68000 msec] [+0:01:33.296] c:\Controller1\procpinsmngr.cpp has not changed since last build. Doing a quick recheck... [+0:01:33.312] Saved data for c:\Controller1\libdel.cpp is up to date. Skipping reparsing... [+0:01:33.484] No changed PSFs found, but c:\Controller1\libstate.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:33.484] Starting fpsParsingFileBody on c:\Controller1\libstate.cpp [+0:01:34.546] Starting fpsAnalyzingReferences on c:\Controller1\libstate.cpp [+0:01:36.062] Completed fpsAnalyzingReferences on c:\Controller1\libstate.cpp [+0:01:36.109] Completed fpsParsingFileBody on c:\Controller1\libstate.cpp [+0:01:36.109] c:\Controller1\libstate.cpp has not changed since last build. Doing a quick recheck... [+0:01:36.125] No changed PSFs found, but c:\Controller1\procunitmngr.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:36.125] Starting fpsParsingFileBody on c:\Controller1\procunitmngr.cpp [+0:01:37.078] Starting fpsAnalyzingReferences on c:\Controller1\procunitmngr.cpp [+0:01:38.359] Completed fpsAnalyzingReferences on c:\Controller1\procunitmngr.cpp [+0:01:38.421] Completed fpsParsingFileBody on c:\Controller1\procunitmngr.cpp [+0:01:38.453] No changed PSFs found, but c:\Controller1\libmove.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:38.453] Starting fpsParsingFileBody on c:\Controller1\libmove.cpp [+0:01:38.468] c:\Controller1\procunitmngr.cpp has not changed since last build. Doing a quick recheck... [+0:01:39.468] Starting fpsAnalyzingReferences on c:\Controller1\libmove.cpp [+0:01:40.859] Completed fpsAnalyzingReferences on c:\Controller1\libmove.cpp [+0:01:40.906] Completed fpsParsingFileBody on c:\Controller1\libmove.cpp [+0:01:40.906] c:\Controller1\libmove.cpp has not changed since last build. Doing a quick recheck... [+0:01:40.906] No changed PSFs found, but c:\Controller1\procnetwcomm.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 3 PSFs. [+0:01:40.906] Starting fpsParsingFileBody on c:\Controller1\procnetwcomm.cpp [+0:01:41.890] Starting fpsAnalyzingReferences on c:\Controller1\procnetwcomm.cpp [+0:01:43.078] Completed fpsAnalyzingReferences on c:\Controller1\procnetwcomm.cpp [+0:01:43.140] Completed fpsParsingFileBody on c:\Controller1\procnetwcomm.cpp [+0:01:43.406] Thread was being aborted. while trying to parse c:\Controller1\DbPut.cpp [+0:01:43.406] Stack trace: [+0:01:43.406] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:43.406] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:43.406] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:43.406] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:43.406] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:43.406] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:43.406] at bp.ae.a(qg A_0) [+0:01:43.406] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:43.406] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:43.406] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:43.406] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:43.421] Operation completed: Reparsing c:\Controller1\DbPut.cpp [77578 msec] [+0:01:43.421] Thread was being aborted. while trying to check source for errors [+0:01:43.421] Stack trace: [+0:01:43.421] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:43.421] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:43.421] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:43.421] Operation completed: Parse - Check [77578 msec] [+0:01:43.984] Thread was being aborted. while trying to parse c:\Controller1\LibSys.cpp [+0:01:43.984] Stack trace: [+0:01:43.984] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:43.984] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:43.984] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:43.984] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:43.984] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:43.984] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:43.984] at bp.ae.a(qg A_0) [+0:01:43.984] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:43.984] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:43.984] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:43.984] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:43.984] Operation completed: Reparsing c:\Controller1\LibSys.cpp [78125 msec] [+0:01:43.984] Thread was being aborted. while trying to check source for errors [+0:01:43.984] Stack trace: [+0:01:43.984] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:43.984] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:43.984] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:43.984] Operation completed: Parse - Check [78125 msec] [+0:01:44.484] Thread was being aborted. while trying to parse c:\Controller1\LibXml.cpp [+0:01:44.484] Stack trace: [+0:01:44.484] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:44.484] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:44.484] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:44.484] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:44.484] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:44.484] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:44.484] at bp.ae.a(qg A_0) [+0:01:44.484] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:44.484] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:44.484] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:44.484] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:44.500] Operation completed: Reparsing c:\Controller1\LibXml.cpp [78062 msec] [+0:01:44.500] Thread was being aborted. while trying to check source for errors [+0:01:44.500] Stack trace: [+0:01:44.500] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:44.500] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:44.500] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:44.500] Operation completed: Parse - Check [78062 msec] [+0:01:44.703] Thread was being aborted. while trying to parse c:\Controller1\LibGen.cpp [+0:01:44.703] Stack trace: [+0:01:44.703] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:44.703] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:44.703] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:44.703] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:44.703] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:44.703] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:44.703] at bp.ae.a(qg A_0) [+0:01:44.703] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:44.703] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:44.703] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:44.703] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:44.703] Operation completed: Reparsing c:\Controller1\LibGen.cpp [77875 msec] [+0:01:44.703] Thread was being aborted. while trying to check source for errors [+0:01:44.703] Stack trace: [+0:01:44.703] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:44.703] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:44.703] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:44.703] Operation completed: Parse - Check [77875 msec] [+0:01:44.968] Thread was being aborted. while trying to parse c:\Controller1\LibHw.cpp [+0:01:44.968] Stack trace: [+0:01:44.968] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:44.968] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:44.968] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:44.968] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:44.968] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:44.968] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:44.968] at bp.ae.a(qg A_0) [+0:01:44.968] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:44.968] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:44.968] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:44.968] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:44.968] Operation completed: Reparsing c:\Controller1\LibHw.cpp [77531 msec] [+0:01:44.968] Thread was being aborted. while trying to check source for errors [+0:01:44.968] Stack trace: [+0:01:44.968] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:44.968] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:44.968] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:44.968] Operation completed: Parse - Check [77531 msec] [+0:01:45.296] Thread was being aborted. while trying to parse c:\Controller1\LibTcp.cpp [+0:01:45.296] Stack trace: [+0:01:45.296] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:45.296] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:45.296] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:45.296] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:45.296] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:45.296] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:45.296] at bp.ae.a(qg A_0) [+0:01:45.296] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:45.296] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:45.296] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:45.296] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:45.296] Operation completed: Reparsing c:\Controller1\LibTcp.cpp [77234 msec] [+0:01:45.296] Thread was being aborted. while trying to check source for errors [+0:01:45.296] Stack trace: [+0:01:45.296] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:45.296] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:45.296] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:45.312] Operation completed: Parse - Check [77250 msec] [+0:01:45.828] Thread was being aborted. while trying to parse c:\Controller1\ProcExecCont.cpp [+0:01:45.828] Stack trace: [+0:01:45.828] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:45.828] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:45.828] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:45.828] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:45.828] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:45.828] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:45.828] at bp.ae.a(qg A_0) [+0:01:45.828] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:45.828] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:45.828] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:45.828] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:45.828] Operation completed: Reparsing c:\Controller1\ProcExecCont.cpp [77593 msec] [+0:01:45.828] Thread was being aborted. while trying to check source for errors [+0:01:45.828] Stack trace: [+0:01:45.828] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:45.828] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:45.828] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:45.828] Operation completed: Parse - Check [77593 msec] [+0:01:45.875] Thread was being aborted. while trying to parse c:\Controller1\SpCoCont.cpp [+0:01:45.875] Stack trace: [+0:01:45.875] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:45.875] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:45.875] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:45.875] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:45.875] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:45.875] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:45.875] at bp.ae.a(qg A_0) [+0:01:45.875] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:45.875] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:45.875] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:45.875] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:45.890] Operation completed: Reparsing c:\Controller1\SpCoCont.cpp [76937 msec] [+0:01:45.890] Thread was being aborted. while trying to check source for errors [+0:01:45.890] Stack trace: [+0:01:45.890] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:45.890] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:45.890] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:45.890] Operation completed: Parse - Check [76937 msec] [+0:01:46.109] Thread was being aborted. while trying to parse c:\Controller1\ProcFcstMngr.cpp [+0:01:46.109] Stack trace: [+0:01:46.109] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:46.109] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:46.109] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:46.109] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:46.109] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:46.109] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:46.109] at bp.ae.a(qg A_0) [+0:01:46.109] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:46.109] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:46.109] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:46.109] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.109] Operation completed: Reparsing c:\Controller1\ProcFcstMngr.cpp [75687 msec] [+0:01:46.109] Thread was being aborted. while trying to check source for errors [+0:01:46.109] Stack trace: [+0:01:46.109] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.109] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:46.109] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:46.109] Operation completed: Parse - Check [75687 msec] [+0:01:46.265] Thread was being aborted. while trying to parse c:\Controller1\ProcWiFiScan.cpp [+0:01:46.265] Stack trace: [+0:01:46.265] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:46.265] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:46.265] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:46.265] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:46.265] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:46.265] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:46.265] at bp.ae.a(qg A_0) [+0:01:46.265] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:46.265] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:46.265] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:46.265] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.265] Operation completed: Reparsing c:\Controller1\ProcWiFiScan.cpp [75296 msec] [+0:01:46.265] Thread was being aborted. while trying to check source for errors [+0:01:46.265] Stack trace: [+0:01:46.265] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.265] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:46.265] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:46.265] Operation completed: Parse - Check [75296 msec] [+0:01:46.453] Thread was being aborted. while trying to parse c:\Controller1\ProcInetComm.cpp [+0:01:46.453] Stack trace: [+0:01:46.453] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:46.453] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:46.453] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:46.453] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:46.453] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:46.453] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:46.453] at bp.ae.a(qg A_0) [+0:01:46.453] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:46.453] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:46.453] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:46.453] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.453] Operation completed: Reparsing c:\Controller1\ProcInetComm.cpp [75062 msec] [+0:01:46.453] Thread was being aborted. while trying to check source for errors [+0:01:46.453] Stack trace: [+0:01:46.453] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.453] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:46.453] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:46.453] Operation completed: Parse - Check [75062 msec] [+0:01:46.750] Thread was being aborted. while trying to parse c:\Controller1\ProcTimeMngr.cpp [+0:01:46.750] Stack trace: [+0:01:46.750] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:46.750] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:46.750] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:46.750] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:46.750] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:46.750] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:46.750] at bp.ae.a(qg A_0) [+0:01:46.750] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:46.750] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:46.750] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:46.750] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.750] Operation completed: Reparsing c:\Controller1\ProcTimeMngr.cpp [74718 msec] [+0:01:46.750] Thread was being aborted. while trying to check source for errors [+0:01:46.750] Stack trace: [+0:01:46.750] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:46.750] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:46.750] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:46.750] Operation completed: Parse - Check [74718 msec] [+0:01:47.015] Thread was being aborted. while trying to parse c:\Controller1\ProcPinsMngr.cpp [+0:01:47.015] Stack trace: [+0:01:47.015] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:47.015] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:47.015] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:47.015] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:47.015] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:47.015] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:47.015] at bp.ae.a(qg A_0) [+0:01:47.015] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:47.015] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:47.015] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:47.015] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.015] Operation completed: Reparsing c:\Controller1\ProcPinsMngr.cpp [74515 msec] [+0:01:47.015] Thread was being aborted. while trying to check source for errors [+0:01:47.015] Stack trace: [+0:01:47.015] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.015] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:47.015] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:47.015] Operation completed: Parse - Check [74515 msec] [+0:01:47.359] Thread was being aborted. while trying to parse c:\Controller1\LibState.cpp [+0:01:47.359] Stack trace: [+0:01:47.359] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:47.359] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:47.359] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:47.359] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:47.359] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:47.359] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:47.359] at bp.ae.a(qg A_0) [+0:01:47.359] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:47.359] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:47.359] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:47.359] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.359] Operation completed: Reparsing c:\Controller1\LibState.cpp [73265 msec] [+0:01:47.359] Thread was being aborted. while trying to check source for errors [+0:01:47.359] Stack trace: [+0:01:47.359] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.359] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:47.359] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:47.359] Operation completed: Parse - Check [73265 msec] [+0:01:47.531] Thread was being aborted. while trying to parse c:\Controller1\ProcUnitMngr.cpp [+0:01:47.531] Stack trace: [+0:01:47.531] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:47.531] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:47.531] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:47.531] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:47.531] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:47.531] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:47.531] at bp.ae.a(qg A_0) [+0:01:47.531] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:47.531] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:47.531] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:47.531] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.531] Operation completed: Reparsing c:\Controller1\ProcUnitMngr.cpp [73187 msec] [+0:01:47.531] Thread was being aborted. while trying to check source for errors [+0:01:47.531] Stack trace: [+0:01:47.531] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.531] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:47.531] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:47.531] Operation completed: Parse - Check [73187 msec] [+0:01:47.750] Thread was being aborted. while trying to parse c:\Controller1\LibMove.cpp [+0:01:47.750] Stack trace: [+0:01:47.750] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:47.750] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:47.750] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:47.750] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:47.750] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:47.750] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:47.750] at bp.ae.a(qg A_0) [+0:01:47.750] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:47.750] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:47.750] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:47.750] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.750] Operation completed: Reparsing c:\Controller1\LibMove.cpp [72593 msec] [+0:01:47.750] Thread was being aborted. while trying to check source for errors [+0:01:47.750] Stack trace: [+0:01:47.750] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.750] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:47.750] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:47.765] Operation completed: Parse - Check [72609 msec] [+0:01:47.906] Thread was being aborted. while trying to parse c:\Controller1\ProcNetwComm.cpp [+0:01:47.906] Stack trace: [+0:01:47.906] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:01:47.906] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:01:47.906] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:01:47.906] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:01:47.906] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:01:47.906] at qg.a(afk A_0, String A_1, ahj A_2) [+0:01:47.906] at bp.ae.a(qg A_0) [+0:01:47.906] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:01:47.906] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:01:47.906] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:01:47.906] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.906] Operation completed: Reparsing c:\Controller1\ProcNetwComm.cpp [69218 msec] [+0:01:47.906] Thread was being aborted. while trying to check source for errors [+0:01:47.906] Stack trace: [+0:01:47.906] at bp.a(afk A_0, String A_1, ahj A_2) [+0:01:47.906] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:01:47.906] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:01:47.906] Operation completed: Parse - Check [69218 msec] [+0:01:43.140] c:\Controller1\procnetwcomm.cpp has not changed since last build. Doing a quick recheck... [+0:01:43.156] Saved data for c:\Controller1\dbput.cpp is up to date. Skipping reparsing... [+0:01:43.437] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:01:43.437] c:\Controller1\libspco.cpp has not changed since last build. Doing a quick recheck... [+0:01:43.468] Saved data for c:\Controller1\libsys.cpp is up to date. Skipping reparsing... [+0:01:44.000] Saved data for c:\Controller1\libxml.cpp is up to date. Skipping reparsing... [+0:01:44.515] Saved data for c:\Controller1\libgen.cpp is up to date. Skipping reparsing... [+0:01:44.734] Saved data for c:\Controller1\libhw.cpp is up to date. Skipping reparsing... [+0:01:45.093] Saved data for c:\Controller1\libtcp.cpp is up to date. Skipping reparsing... [+0:01:45.312] Saved data for c:\Controller1\procexeccont.cpp is up to date. Skipping reparsing... [+0:01:45.640] Saved data for c:\Controller1\spcocont.cpp is up to date. Skipping reparsing... [+0:01:45.906] Saved data for c:\Controller1\procfcstmngr.cpp is up to date. Skipping reparsing... [+0:01:46.125] Saved data for c:\Controller1\procwifiscan.cpp is up to date. Skipping reparsing... [+0:01:46.296] Saved data for c:\Controller1\procinetcomm.cpp is up to date. Skipping reparsing... [+0:01:46.515] Saved data for c:\Controller1\proctimemngr.cpp is up to date. Skipping reparsing... [+0:01:46.828] Saved data for c:\Controller1\procpinsmngr.cpp is up to date. Skipping reparsing... [+0:01:47.093] Saved data for c:\Controller1\libstate.cpp is up to date. Skipping reparsing... [+0:01:47.375] Saved data for c:\Controller1\procunitmngr.cpp is up to date. Skipping reparsing... [+0:01:47.546] Saved data for c:\Controller1\libmove.cpp is up to date. Skipping reparsing... [+0:01:47.781] Saved data for c:\Controller1\procnetwcomm.cpp is up to date. Skipping reparsing... [+0:01:47.921] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:01:48.734] Checked c:\Controller1\LibSpCo.cpp: 1 error records [+0:01:48.828] Operation completed: Reparsing c:\Controller1\LibSpCo.cpp [60031 msec] [+0:01:49.078] Operation completed: Parse - Check [60281 msec] [+0:01:49.171] Starting operation: Parse - QuickInfo [+0:01:49.250] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:01:49.515] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:01:49.890] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:01:49.921] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:01:50.171] Operation completed: Parse - QuickInfo [1000 msec] [+0:02:29.484] Starting operation: Parse - HighlightBraces [+0:02:29.546] Operation completed: Parse - HighlightBraces [62 msec] [+0:02:33.968] Starting operation: Parse - HighlightBraces [+0:02:33.968] Operation completed: Parse - HighlightBraces [0 msec] [+0:02:46.500] Starting operation: Parse - QuickInfo [+0:02:46.500] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:02:46.515] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:02:46.515] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:02:46.546] Existing RDB for c:\Controller1\libspco.cpp matches the source file. No rebuild performed. [+0:02:46.546] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:02:46.546] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:02:46.578] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:02:46.828] Operation completed: Parse - QuickInfo [328 msec] [+0:03:01.328] Starting operation: Parse - HighlightBraces [+0:03:01.328] Operation completed: Parse - HighlightBraces [0 msec] [+0:03:03.218] Starting operation: Parse - QuickInfo [+0:03:03.218] Operation completed: Parse - QuickInfo [0 msec] [+0:03:03.640] Starting operation: Parse - QuickInfo [+0:03:03.640] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:03.656] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:03:03.656] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:03.671] Existing RDB for c:\Controller1\libspco.cpp matches the source file. No rebuild performed. [+0:03:03.671] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:03.921] Operation completed: Parse - QuickInfo [281 msec] [+0:03:03.687] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:03.703] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:06.515] Starting operation: Parse - QuickInfo [+0:03:06.515] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:06.546] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:03:06.546] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:06.562] Existing RDB for c:\Controller1\libspco.cpp matches the source file. No rebuild performed. [+0:03:06.562] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:06.562] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:06.593] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:07.015] Operation completed: Parse - QuickInfo [500 msec] [+0:03:06.796] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:06.812] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:07.750] Starting operation: Parse - QuickInfo [+0:03:07.750] Operation completed: Parse - QuickInfo [0 msec] [+0:03:08.406] Starting operation: Parse - QuickInfo [+0:03:08.406] Operation completed: Parse - QuickInfo [0 msec] [+0:03:08.828] Starting operation: Parse - QuickInfo [+0:03:08.828] Operation completed: Parse - QuickInfo [0 msec] [+0:03:14.546] Starting operation: Reformatting text [+0:03:14.546] Operation completed: Reformatting text [0 msec] [+0:03:14.828] Starting operation: Reformatting text [+0:03:14.828] Operation completed: Reformatting text [0 msec] [+0:03:16.046] Starting operation: Parse - QuickInfo [+0:03:16.078] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:16.093] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:03:16.093] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:16.906] Starting fpsAnalyzingReferences on c:\Controller1\libspco.cpp [+0:03:19.421] Completed fpsAnalyzingReferences on c:\Controller1\libspco.cpp [+0:03:19.578] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:19.593] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:19.640] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:20.062] Operation completed: Parse - QuickInfo [4015 msec] [+0:03:20.062] Starting operation: Parse - QuickInfo [+0:03:19.859] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:19.875] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:20.078] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:20.109] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:03:20.109] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:20.843] Starting fpsAnalyzingReferences on c:\Controller1\libspco.cpp [+0:03:23.296] Completed fpsAnalyzingReferences on c:\Controller1\libspco.cpp [+0:03:23.343] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:23.359] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:23.375] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:23.859] Operation completed: Parse - QuickInfo [3796 msec] [+0:03:23.859] Starting operation: Parse - HighlightBraces [+0:03:23.593] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:23.625] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:03:23.875] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:24.093] Starting operation: Parse - HighlightBraces [+0:03:24.109] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:24.343] Starting operation: Parse - HighlightBraces [+0:03:24.359] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:25.515] Starting operation: Parse - HighlightBraces [+0:03:25.515] Operation completed: Parse - HighlightBraces [0 msec] [+0:03:27.890] Starting operation: Parse - HighlightBraces [+0:03:27.906] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:28.125] Starting operation: Parse - HighlightBraces [+0:03:28.156] Operation completed: Parse - HighlightBraces [31 msec] [+0:03:28.468] Starting operation: Parse - HighlightBraces [+0:03:28.484] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:28.781] Starting operation: Parse - HighlightBraces [+0:03:28.796] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:28.953] Starting operation: Parse - HighlightBraces [+0:03:29.000] Operation completed: Parse - HighlightBraces [46 msec] [+0:03:29.171] Starting operation: Parse - HighlightBraces [+0:03:29.171] Operation completed: Parse - HighlightBraces [0 msec] [+0:03:29.359] Starting operation: Parse - HighlightBraces [+0:03:29.375] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:29.625] Starting operation: Parse - HighlightBraces [+0:03:29.640] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:29.828] Starting operation: Parse - HighlightBraces [+0:03:29.843] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:33.359] Starting operation: Parse - HighlightBraces [+0:03:33.359] Operation completed: Parse - HighlightBraces [0 msec] [+0:03:33.562] Starting operation: Parse - HighlightBraces [+0:03:33.562] Operation completed: Parse - HighlightBraces [0 msec] [+0:03:45.296] Starting operation: Parse - HighlightBraces [+0:03:45.312] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:46.984] Starting operation: Parse - HighlightBraces [+0:03:47.015] Operation completed: Parse - HighlightBraces [31 msec] [+0:03:49.187] Starting operation: Parse - HighlightBraces [+0:03:49.203] Operation completed: Parse - HighlightBraces [15 msec] [+0:03:51.656] Starting operation: Parse - Check [+0:03:51.656] Starting operation: Reparsing c:\Controller1\LibSpCo.cpp [+0:03:51.671] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:03:51.687] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:03:51.687] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:52.359] Starting fpsAnalyzingReferences on c:\Controller1\libspco.cpp [+0:03:54.593] Completed fpsAnalyzingReferences on c:\Controller1\libspco.cpp [+0:03:54.687] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:03:54.703] c:\Controller1\libspco.cpp has not changed since last build. Doing a quick recheck... [+0:03:54.734] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:03:55.390] Checked c:\Controller1\LibSpCo.cpp: 1 error records [+0:03:55.437] Operation completed: Reparsing c:\Controller1\LibSpCo.cpp [3781 msec] [+0:03:55.609] Operation completed: Parse - Check [3953 msec] [+0:04:24.796] Starting operation: Parse - HighlightBraces [+0:04:24.828] Operation completed: Parse - HighlightBraces [31 msec] [+0:04:36.484] Active document changed to c:\Controller1\Msgs.cpp [+0:04:36.593] Starting operation: Parse - Check [+0:04:36.593] Starting operation: Reparsing c:\Controller1\Msgs.cpp [+0:04:36.687] c:\Controller1\msgs.cpp has changed since last build. Doing full analysis... [+0:04:37.281] PSF 3 (normal preamble) is out of date due to c:\Controller1\constants.h. It will be re-built. [+0:04:37.281] Rebuilding PSF 3 (normal preamble)... [+0:04:37.281] Starting fpsBuildingPreamble on c:\Controller1\msgs.cpp [+0:04:38.281] Active document changed to c:\Controller1\Inits.cpp [+0:04:38.390] Starting operation: Parse - Check [+0:04:38.390] Starting operation: Reparsing c:\Controller1\Inits.cpp [+0:04:39.203] Completed fpsBuildingPreamble on c:\Controller1\msgs.cpp [+0:04:39.203] Successfully rebuilt PSF 3 (normal preamble)... [+0:04:39.203] Saving PSF 3 (normal preamble)... [+0:04:39.203] Starting fpsSavingPSF on c:\Controller1\msgs.cpp [+0:04:39.390] Completed fpsSavingPSF on c:\Controller1\msgs.cpp [+0:04:39.390] Successfully saved PSF 3 (normal preamble)... [+0:04:39.390] Starting fpsParsingFileBody on c:\Controller1\msgs.cpp [+0:04:39.750] Active document changed to c:\Controller1\LibSpCo.cpp [+0:04:39.875] Starting operation: Parse - Check [+0:04:39.875] Starting operation: Reparsing c:\Controller1\LibSpCo.cpp [+0:04:40.453] Starting fpsAnalyzingReferences on c:\Controller1\msgs.cpp [+0:04:41.203] Active document changed to c:\Controller1\RAM.cpp [+0:04:41.375] Starting operation: Parse - Check [+0:04:41.375] Starting operation: Reparsing c:\Controller1\RAM.cpp [+0:04:44.125] Checked c:\Controller1\RAM.cpp: 1 error records [+0:04:44.203] Operation completed: Reparsing c:\Controller1\RAM.cpp [2828 msec] [+0:04:42.968] Saved data for c:\Controller1\ram.cpp is up to date. Skipping reparsing... [+0:04:43.015] c:\Controller1\ram.cpp has not changed since last build. Doing a quick recheck... [+0:04:43.781] Completed fpsAnalyzingReferences on c:\Controller1\msgs.cpp [+0:04:43.796] Saved data for c:\Controller1\ram.cpp is up to date. Skipping reparsing... [+0:04:44.312] Operation completed: Parse - Check [2937 msec] [+0:04:44.406] Active document changed to c:\Controller1\Externs.h [+0:04:44.500] Starting operation: Parse - Check [+0:04:44.500] Starting operation: Reparsing c:\Controller1\Externs.h [+0:04:45.265] Checked c:\Controller1\Externs.h: 0 error records [+0:04:45.296] Operation completed: Reparsing c:\Controller1\Externs.h [796 msec] [+0:04:45.359] Operation completed: Parse - Check [859 msec] [+0:04:45.718] Starting operation: Parse - QuickInfo [+0:04:45.890] Thread was being aborted. while trying to parse c:\Controller1\LibSpCo.cpp [+0:04:45.890] Stack trace: [+0:04:45.890] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:04:45.890] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:04:45.890] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:04:45.890] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:04:45.890] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:04:45.890] at qg.a(afk A_0, String A_1, ahj A_2) [+0:04:45.890] at bp.ae.a(qg A_0) [+0:04:45.890] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:04:45.890] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:04:45.890] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:04:45.890] at bp.a(afk A_0, String A_1, ahj A_2) [+0:04:45.890] Operation completed: Reparsing c:\Controller1\LibSpCo.cpp [6015 msec] [+0:04:45.890] Thread was being aborted. while trying to check source for errors [+0:04:45.890] Stack trace: [+0:04:45.890] at bp.a(afk A_0, String A_1, ahj A_2) [+0:04:45.890] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:04:45.890] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:04:45.890] Operation completed: Parse - Check [6015 msec] [+0:04:46.093] Thread was being aborted. while trying to parse c:\Controller1\Msgs.cpp [+0:04:46.093] Stack trace: [+0:04:46.093] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:04:46.093] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:04:46.093] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:04:46.093] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:04:46.093] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:04:46.093] at qg.a(afk A_0, String A_1, ahj A_2) [+0:04:46.093] at bp.ae.a(qg A_0) [+0:04:46.093] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:04:46.093] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:04:46.093] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:04:46.093] at bp.a(afk A_0, String A_1, ahj A_2) [+0:04:46.093] Operation completed: Reparsing c:\Controller1\Msgs.cpp [9500 msec] [+0:04:46.093] Thread was being aborted. while trying to check source for errors [+0:04:46.093] Stack trace: [+0:04:46.093] at bp.a(afk A_0, String A_1, ahj A_2) [+0:04:46.093] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:04:46.093] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:04:46.109] Operation completed: Parse - Check [9515 msec] [+0:04:46.343] Thread was being aborted. while trying to parse c:\Controller1\Inits.cpp [+0:04:46.343] Stack trace: [+0:04:46.343] at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg) [+0:04:46.343] at System.Runtime.Remoting.Proxies.RemotingProxy.CallProcessMessage(IMessageSink ms, IMessage reqMsg, ArrayWithSize proxySinks, Thread currentThread, Context currentContext, Boolean bSkippingContextChain) [+0:04:46.343] at System.Runtime.Remoting.Proxies.RemotingProxy.InternalInvoke(IMethodCallMessage reqMcmMsg, Boolean useDispatchMessage, Int32 callType) [+0:04:46.343] at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(IMessage reqMsg) [+0:04:46.343] at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) [+0:04:46.343] at qg.a(afk A_0, String A_1, ahj A_2) [+0:04:46.343] at bp.ae.a(qg A_0) [+0:04:46.343] at CppLanguageService.SafeExecutionWrapper1.<>c__DisplayClass41.a() [+0:04:46.343] at ait.a.ExecuteFromThreadIfNeeded[_Ty](BasicFunc`1 func) [+0:04:46.343] at CppLanguageService.SafeExecutionWrapper1.ExecuteSafe[_ReturnTy](Func12 func, Boolean skipIfDisconnected) [+0:04:46.343] at bp.a(afk A_0, String A_1, ahj A_2) [+0:04:46.343] Operation completed: Reparsing c:\Controller1\Inits.cpp [7953 msec] [+0:04:46.343] Thread was being aborted. while trying to check source for errors [+0:04:46.343] Stack trace: [+0:04:46.343] at bp.a(afk A_0, String A_1, ahj A_2) [+0:04:46.343] at gn.a(IVsTextView A_0, ISourceObject A_1, Boolean A_2) [+0:04:46.343] at ak6.a(IParseRequestWrapper A_0, Boolean A_1, Boolean A_2) [+0:04:46.343] Operation completed: Parse - Check [7953 msec] [+0:04:44.906] Completed fpsParsingFileBody on c:\Controller1\msgs.cpp [+0:04:44.906] c:\Controller1\msgs.cpp has not changed since last build. Doing a quick recheck... [+0:04:44.921] Saved data for c:\Controller1\externs.h is up to date. Skipping reparsing... [+0:04:44.921] c:\Controller1\externs.h has not changed since last build. Doing a quick recheck... [+0:04:44.968] Saved data for c:\Controller1\inits.cpp is up to date. Skipping reparsing... [+0:04:44.968] c:\Controller1\inits.cpp has not changed since last build. Doing a quick recheck... [+0:04:44.968] Saved data for c:\Controller1\externs.h is up to date. Skipping reparsing... [+0:04:45.453] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:04:45.921] Saved data for c:\Controller1\msgs.cpp is up to date. Skipping reparsing... [+0:04:46.156] Saved data for c:\Controller1\inits.cpp is up to date. Skipping reparsing... [+0:04:47.234] Operation completed: Parse - QuickInfo [1515 msec] [+0:04:46.687] c:\Controller1\externs.h has changed since last build. Doing full analysis... [+0:04:47.171] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:04:49.015] Starting operation: Parse - QuickInfo [+0:04:49.171] c:\Controller1\externs.h has changed since last build. Doing full analysis... [+0:04:49.343] No changed PSFs found, but c:\Controller1\externs.h is outdated due to itself. Doing a quick PSF-based rebuild with 1 PSFs. [+0:04:49.343] Starting fpsParsingFileBody on c:\Controller1\externs.h [+0:04:49.359] Existing RDB for c:\Controller1\externs.h matches the source file. No rebuild performed. [+0:04:49.359] Completed fpsParsingFileBody on c:\Controller1\externs.h [+0:04:49.734] Operation completed: Parse - QuickInfo [718 msec] [+0:04:49.593] c:\Controller1\externs.h has changed since last build. Doing full analysis... [+0:04:49.656] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:04:50.671] Active document changed to c:\Controller1\LibSpCo.cpp [+0:04:50.812] Starting operation: Parse - Check [+0:04:50.812] Starting operation: Reparsing c:\Controller1\LibSpCo.cpp [+0:04:51.937] Checked c:\Controller1\LibSpCo.cpp: 1 error records [+0:04:52.031] Operation completed: Reparsing c:\Controller1\LibSpCo.cpp [1218 msec] [+0:04:51.140] Saved data for c:\Controller1\libspco.cpp is up to date. Skipping reparsing... [+0:04:52.203] Operation completed: Parse - Check [1390 msec] [+0:04:52.265] Starting operation: Parse - QuickInfo [+0:04:52.265] Operation completed: Parse - QuickInfo [0 msec] [+0:04:52.312] Starting operation: Parse - QuickInfo [+0:04:52.312] Operation completed: Parse - QuickInfo [0 msec] [+0:04:52.468] Starting operation: Parse - QuickInfo [+0:04:52.468] Operation completed: Parse - QuickInfo [0 msec] [+0:04:54.187] Starting operation: Parse - QuickInfo [+0:04:54.234] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:04:54.984] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:04:55.828] Operation completed: Parse - QuickInfo [1640 msec] [+0:04:55.343] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:04:55.609] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:04:57.453] Starting operation: Parse - QuickInfo [+0:04:57.500] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:04:58.578] No changed PSFs found, but c:\Controller1\libspco.cpp is outdated due to itself. Doing a quick PSF-based rebuild with 4 PSFs. [+0:04:58.578] Starting fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:04:58.593] Existing RDB for c:\Controller1\libspco.cpp matches the source file. No rebuild performed. [+0:04:58.593] Completed fpsParsingFileBody on c:\Controller1\libspco.cpp [+0:04:58.593] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:04:58.968] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:04:59.234] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:04:59.296] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:04:59.781] Operation completed: Parse - QuickInfo [2328 msec] [+0:04:59.500] c:\Controller1\libspco.cpp has changed since last build. Doing full analysis... [+0:04:59.578] No changed PSFs found. Doing a CodeComplete run with minimal reparsing. [+0:05:25.078] Active document changed to c:\Controller1\LibSys.cpp [+0:05:25.140] Starting operation: Parse - Check [+0:05:25.140] Starting operation: Reparsing c:\Controller1\LibSys.cpp [+0:05:26.593] Checked c:\Controller1\LibSys.cpp: 1 error records [+0:05:26.671] Operation completed: Reparsing c:\Controller1\LibSys.cpp [1531 msec] [+0:05:25.515] Saved data for c:\Controller1\libsys.cpp is up to date. Skipping reparsing... [+0:05:25.515] c:\Controller1\libsys.cpp has not changed since last build. Doing a quick recheck... [+0:05:25.812] Saved data for c:\Controller1\libsys.cpp is up to date. Skipping reparsing... [+0:05:26.812] Operation completed: Parse - Check [1671 msec] [+0:06:13.390] Rechecking configuration for c:\Controller1\Controller1.vcproj due to a refresh requestOctober 20, 2015 at 05:56 #7082support
The “thread aborted” error does not mean any problems, it simply means that you closed the source file while VisualGDB was still parsing it. Is any functionality broken for you, or are you just concerned with the error messages?
October 20, 2015 at 18:20 #7084NormD
ParticipantI never closed any files. I keep all source files open all the time.
I had a problem where many functions and variable names were showing up with very strange highlighting (things like a function in white text with a black background). When searching for the source of the problems I found the errors. In the end, I closed and reopened VS and the problems went away. I have turned off lots of clang functionality as I got tired of changing a file then waiting while clang rescanned all my files to rebuild its database. I do like its outlining. I think there should be an easier way to configure clang. Digging through the options screen with dozens of values that can be changed with no hints of what each field does is frustrating.
October 20, 2015 at 19:03 #7085support
Thanks for your feedback. The VS colors do sometimes get confused and restarting VS usually helps. Could you please explain the “changing a file then waiting while clang rescanned all my files” thing? We have designed the Clang engine to build the database in the background and only once (or when significant amount of files have been changed). If this is broken, we would certainly like to know so that we could fix it.
Please also let us know which Clang options you found confusing so that we could document them better.
October 21, 2015 at 11:46 #7086NormD
ParticipantSometimes when I change a file (I have not seen an identifiable pattern, like .h files or some such) a small box pops up with a message saying something like “Clang … rebuilding…” (sorry I have not recorded the exact terminology) and says its scanning file 1 of 31, then 2 and 3 and so on. It takes a minute or so to run. I am on an older computer running VS2008, so perhaps its my setup Its annoying. Also if I right-click on a variable and select “show definition” it many times does the same thing. I instead just use the VS “Find in all Open Files” function which works instantaneously.
I set Options->Text Editor->c/c++(VisualGDB)->Advanced->Indexing All Index options to False and it seems to fix the problem. I don’t need/want all the clang auto-complete functionality.
October 26, 2015 at 01:47 #7101support
VisualGDB does that when you open a .h file or another file that is not directly included in your project. It then tries to find a source file that includes the .h file as it will give more precise IntelliSense results.
Normally it should try the previously open source file first and should be fairly fast. However, if you are using an older PC, it could slow things down. You can also disable the entire Clang IntelliSense via Tools->Options->VisualGDB->General->Tweaking->Enable Clang IntelliSense by default.
October 26, 2015 at 23:31 #7110NormD
ParticipantJust to be clear. I work with some 30 files open. Maybe 15 of them are in tabs across the top of VS. If I want to see something from a file that is not displayed I use the black triangle on the right to select the file I want to see. Its moved to the leftmost tab and the other files are rotated right. I keep all files open so I can use Find-In-All-Open-Files function. I keep a small number of files closed because these never change.
I never open or close any files while working. The Clang rescan is not triggered by a file open or close. I don’t see any pattern as to what starts it. I am usually just typing some code and in the middle of typing it takes off.
I any case, I am not pushing you to fix it. I can work around it.
When you say I can set “Enable Clang IntelliSense by default” false to disable Clang, I *thought* that would only enable/disable Clang at VS open. Does that enable/disable it for the current running session?
October 31, 2015 at 01:24 #7136support
We recently fixed the global “Enable Clang IntelliSense by default” so that it applies to the running session as well.
Perhaps we are talking about different windows. Could you attach a screenshot of the window that pops up for you? We should be able to advise you how to disable it then.
