Clang IntelliSense: Error: use of undeclared identifier __nop
Sysprogs forums › Forums › VisualGDB › Clang IntelliSense: Error: use of undeclared identifier __nop
  • #7682
    kunzeti
    I’m new in VisualGDB and I try to Import a KEIL µVision Project. Now I get the error, that __nop is undeclared identifier. My Hardware is a LPC1768.
    The Main.cpp is as followed:
    #include “LPC17xx.h”
    #include “stdbool.h”
    int main(void)
    while (ture)
    __nop();
    The current Building and linking Defines in VisualGDB Project Properties -> Embedded Project are:
    DEBUG __ARMCC_VERSION=560020 __arm__ __CC_ARM
    <span class=”hps”>Are the</span> <span class=”hps”>settings</span> <span class=”hps”>correct? Did I forgot something?</span>
    • This topic was modified 10 years, 7 months ago by kunzeti.
    #7694
    This happens because _nop()  is not a GCC compiler extension and VisualGDB IntelliSense does not know about it.
    You can work around it by adding something like #define _nop() to gcc_compat.h in the VisualGDB directory. The definition will only affect IntelliSense, so the code will be compiled the same way as before.
