CLang intellisense could not find headers
Sysprogs forums › Forums › VisualGDB › CLang intellisense could not find headers
  • #7289
    SchodMC
    Hi folks,
    I have a problem with Visual GDB and CLANG Intellisense. The normal intellisense finds all of the uses includes, because I set the include path to that files as well as some intellisense include search path. However, when I switch to use CLANG intellisense, I get a lot of errors of undefined classes, defines, includes files that could not be found.
    One solution I found was, to add that directories inside the VisualGDB Intellisense settings. But there I only can enter an absolut path. But we at our company using a system wide variable to point to the root of our build system with the GCC headers. And it seems that I’m not be able to set that variable inside the intellisense settings of VisualGDB. That’s right?
    Now, what can I do?
    Greetings
    Marc
    #7300
    As a temporary workaround we would suggest creating a symbolic link to the shared header directory near your project directory, e.g.:
    cd <project>\..
    mklink /d includes c:\common-include-dir
    Then you can specify the relative path to the directory (e.g. ..\includes) on the IntelliSense page of VisualGDB Project Properties.
