clang-format issues
Sysprogs forums Forums VisualGDB clang-format issues
  • #30411
    mttjcksn
    Hi there,
    I’m using VisualGDB 5.5 with Microsoft Visual Studio Community 2019 Version 16.9.3, and getting unpredictable results with clang-format.
    All project configurations are set to Default Clang for both intellisense and code formatting. I have specified a .clang-format file that works with LLVM clang-format v12 on the command line, but I get all sorts of issues with it in visual studio.
    For example, formatting this line:
    ALIGN_32BYTES(volatile uint32_t buffer[____EXAMPLE_MACRO_1 * ____EXAMPLE_MACRO_2 * ____EXAMPLE_MACRO_3] __attribute__((section(".bufferSection"))));
    using visualGDB clang-format:
    ALIGN_32BYTES(
    volatile uint32_t
    but using llvm clang-format v12:
    Here is an example clang-format file that gives this result:
    <hr />
    Language: Cpp
    # BasedOnStyle: Microsoft
    AccessModifierOffset: -2
    AlignAfterOpenBracket: Align
    AlignConsecutiveMacros: true
    AlignConsecutiveAssignments: true
    AlignConsecutiveDeclarations: false
    AlignEscapedNewlines: Right
    AlignOperands: true
    AlignTrailingComments: true
    # AllowAllArgumentsOnNextLine: true
    # AllowAllConstructorInitializersOnNextLine: true
    AllowAllParametersOfDeclarationOnNextLine: true
    # AllowShortBlocksOnASingleLine: Never
    # AllowShortCaseLabelsOnASingleLine: false
    # AllowShortFunctionsOnASingleLine: None
    # AllowShortLambdasOnASingleLine: All
    # AllowShortIfStatementsOnASingleLine: Never
    # AllowShortLoopsOnASingleLine: false
    AlwaysBreakAfterDefinitionReturnType: None
    AlwaysBreakAfterReturnType: None
    AlwaysBreakBeforeMultilineStrings: false
    AlwaysBreakTemplateDeclarations: MultiLine
    BinPackArguments: true
    BinPackParameters: true
    BraceWrapping:
    # AfterCaseLabel: false
    AfterClass: true
    AfterControlStatement: true
    AfterEnum: true
    AfterFunction: true
    AfterNamespace: true
    AfterObjCDeclaration: true
    AfterStruct: true
    AfterUnion: false
    AfterExternBlock: true
    BeforeCatch: true
    BeforeElse: true
    IndentBraces: false
    SplitEmptyFunction: true
    SplitEmptyRecord: true
    SplitEmptyNamespace: true
    BreakBeforeBinaryOperators: None
    BreakBeforeBraces: Allman
    ColumnLimit: '0'
    In this specific example it looks as if the visualGDB clang-format is ignoring  ColumnLimit: '0'.  There are various other differences between the outputs, such as how array initialisers are formatted, and where line breaks are placed in expressions.
    I would ideally use the visualGDB clang format, because I have issues with the visual studio intellisense when using visualGDB, but so far have not been able to make a usable .clang-format file that gives the same results in llvm clang-format and visualGDB clang-format.
    Any ideas??
    Many thanks, Matt
    #30412
    The VisualGDB’s IntelliSense engine internally uses Clang 6.0. Hence if you are relying on a setting that was added in a newer version, it will not work. We will update the Clang version used by our engine in one of the next VisualGDB releases.
    #30413
    mttjcksn
    Thanks for the reply. I just checked every setting in the example I gave above against the version 6 docs here:
    https://releases.llvm.org/6.0.0/tools/clang/docs/ClangFormatStyleOptions.html
    The only one not present was AlignConsecutiveMacros, so I removed it.  Unfortunately the outcome is still the same.  I have double checked that the file is using this clang-format file by clicking the formatting style button in the editor.
    Is there anything else I am missing?
    Is there a list of clang version differences, or any kind of tool to help me work out what the differences are so I can convert a modern clang format to use the old version 6 format?
    Is it possible to disable VisualGDB’s clang-format but keep VisualGDB’s intellisense?
    Many thanks
    • This reply was modified 5 years, 5 months ago by mttjcksn.
    #30415
    No problem, we can walk you through the various settings and try to suggest a few workarounds, however we would kindly ask you renew your technical support first, as it has expired a while ago.
    #30417
    mttjcksn
    Thanks.  I have had  some luck using BasedOnStyle: LLVM and adding a small number of rules on top of that. Perhaps having a large clang-format file causes more problems than it’s worth!
    #33913
    tajen
    Does that mean, that even though VS2019 uses clang-format 12.0.0, VisualGDB uses clang-format 6?
    And has that been updated in the newest version/what is the current version in VisualGDB?
    #33939
    Visual Studio runs Clang as an external tool and applies the formatting instructions reported by it. This allows quickly switching between Clang versions, but has a few drawbacks, particularly when reformatting just one statement (e.g. when pressing ‘}’), and computing indentation for the new line.
    VisualGDB uses a different approach – clang is integrated into our IntelliSense engine, so it continuously keeps a model of the current source file, and can apply more fine-tuned formats (and provide a GUI editor for formatting settings). The downside here is that switching to a newer clang requires updating our entire IntelliSense engine, and running extensive tests to ensure it won’t break any existing functionality.
    We are currently finishing our work with the new tracing engine, that is being first released with VisualKernel (kernel traces generate huge volumes of data, so we use it to make sure the tracing engine is blazingly fast even under most heavy loads); updating the Clang engine to the latest LLVM/clang version is scheduled right after it.
    #33943
    tajen
    Thanks for the reply. It really helps to understand why thing are as they are.
    We will handle the limitation of clang 6 until it is updated.
