Sysprogs forums › Forums › VisualGDB › Clang-based Intillisense engine "Insert spaces" doesn't work
- This topic has 15 replies, 2 voices, and was last updated 9 years, 8 months ago by
June 6, 2016 at 14:52 #8373
matas
We are using VisualGDB 5.1.7.712 for our ARM firmware developement.
Problem is that Clang-based Intillisense engine doesn’t respect “Insert spaces” instead of tabs setting.
My settings:
Options->Text Editor->C/C++->Tabs: Tab size 4. “Insert spaces”
Options->Text Editor->C/C++(VisualGDB)->Tabs: Tab size 4. “Insert spaces”
Now if I press Ctrl+K, Ctrl+D to auto-format correctly formatted document, it will add tabs everywhere! Why??
If I select “Use native Visual Studio IntelliSense engine” Inside VisualGDB project Properties- everything works as it should.
Any suggestions?June 7, 2016 at 03:56 #8376support
This setting is normally cached, so sometimes it’s not updated immediately. Please try reopening the source file or restarting Visual Studio after changing it.
June 7, 2016 at 14:51 #8378matas
ParticipantThanks for response. However, it did not help. It still inserts tabs after number of restarts.
June 11, 2016 at 03:14 #8391support
OK, please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.4.820.msi
Then open the Clang IntelliSense Console window via the View menu and look for a line like this:
Indentation size: 4, will insert spaces
Does it match your settings? Are tabs still inserted instead of spaces?
June 16, 2016 at 17:02 #8441matas
ParticipantYes, it inserts spaces now. However, Clang IntelliSense now only works for non-stand-alone projects.
Steps to reproduce this new issue:
- Create new Embedded project (using VS20015 Professional). All default settings, selected LPC1549 controller.
- Finish.
- Clang works fine:
[+0:00:00.000] Starting operation: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:00.002] Operation completed: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [0 msec]
[+0:00:03.944] Starting operation: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:03.980] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj: found 0 source files
[+0:00:03.984] Clang IntelliSense not enabled for c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:03.984] Operation completed: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [39 msec]
[+0:00:04.419] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.388] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\acmp_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.405] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\adc_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.417] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\chip_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.429] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\clock_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.442] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\crc_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.454] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\dac_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.466] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\dma_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.484] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\gpio_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.496] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\i2cm_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.509] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\i2cs_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.525] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\i2c_common_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.537] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\iocon_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.550] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\pinint_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.562] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\pmu_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.578] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\ritimer_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.591] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rtc_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.603] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sctipu_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.615] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sct_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.630] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sct_pwm_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.643] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\spi_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.655] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\stopwatch_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.668] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\swm_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.683] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sysctl_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.695] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sysinit_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.708] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\uart_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.723] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\wwdt_15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.735] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\eeprom.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.748] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\iap.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.761] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\ring_buffer.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.777] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\rtc_ut.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.789] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\Common\startup.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.802] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\StartupFiles\ORIGINAL_cr_startup_lpc15xx.c added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.818] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\arm_common_tables.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.830] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\arm_math.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.842] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cm0.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.854] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cm0plus.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.869] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cm3.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.881] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cm4.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.893] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cm4_simd.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.906] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cmFunc.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.922] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_cmInstr.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.934] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_sc000.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.947] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\Include\core_sc300.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.963] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\CMSIS\CMSIS\RTOS\cmsis_os.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.975] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\acmp_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:05.988] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\adc_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.000] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\chip.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.015] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\clock_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.028] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\crc_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.040] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\dac_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.053] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\dma_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.068] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\fmc_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.081] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\gpiogroup_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.093] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\gpio_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.112] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\i2cm_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.125] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\i2cs_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.139] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\i2c_common_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.155] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\inmux_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.168] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\iocon_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.180] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\mrt_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.197] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\pinint_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.209] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\pmu_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.222] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\ritimer_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.237] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\romapi_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.250] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_adc_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.262] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_can_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.274] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_dma_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.290] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_i2c_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.309] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_pwr_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.322] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_spi_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.335] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rom_uart_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.350] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\rtc_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.364] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sctipu_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.381] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sct_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.394] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sct_pwm_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.407] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\spi_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.423] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\swm_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.435] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\sysctl_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.450] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\uart_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.463] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\usbd_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.476] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\wwdt_15xx.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.491] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_15xx\config_15xx\cmsis.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.504] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\eeprom.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.519] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\error.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.535] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\iap.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.549] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\lpc_types.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.565] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\packing.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.578] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\ring_buffer.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.591] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\rtc_ut.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.607] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\chip_common\stopwatch.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.620] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.633] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_adc.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.649] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_cdc.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.662] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_cdcuser.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.678] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_core.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.692] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_desc.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.709] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_dfu.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.722] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_dfuuser.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.741] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_hid.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.756] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_hiduser.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.773] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_hw.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.786] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_msc.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.806] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_mscuser.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.819] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\LPC15xx\lpc_chip\lpc_chip\usbd_rom\usbd_rom_api.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.834] c:\Users\matas\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nxp_lpc\Common\sys_config.h added to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.975] Removing project wrapper for c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.975] Starting operation: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:06.992] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj: found 106 source files
[+0:00:07.154] Operation completed: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [178 msec]
[+0:00:07.148] [0%] gftoCheckingForModifications
[+0:00:07.155] [0%] gftoScanningFile ledblink.cpp
[+0:00:07.156] [2%] gftoScanningFile acmp_15xx.c
[+0:00:07.156] [5%] gftoScanningFile adc_15xx.c
[+0:00:07.157] [8%] gftoScanningFile chip_15xx.c
[+0:00:07.157] [11%] gftoScanningFile clock_15xx.c
[+0:00:07.157] [14%] gftoScanningFile crc_15xx.c
[+0:00:07.158] [17%] gftoScanningFile dac_15xx.c
[+0:00:07.158] [20%] gftoScanningFile dma_15xx.c
[+0:00:07.158] [23%] gftoScanningFile gpio_15xx.c
[+0:00:07.159] [26%] gftoScanningFile i2cm_15xx.c
[+0:00:07.159] [29%] gftoScanningFile i2cs_15xx.c
[+0:00:07.159] [32%] gftoScanningFile i2c_common_15xx.c
[+0:00:07.160] [35%] gftoScanningFile iocon_15xx.c
[+0:00:07.160] [38%] gftoScanningFile pinint_15xx.c
[+0:00:07.160] [41%] gftoScanningFile pmu_15xx.c
[+0:00:07.161] [44%] gftoScanningFile ritimer_15xx.c
[+0:00:07.161] [47%] gftoScanningFile rtc_15xx.c
[+0:00:07.161] [50%] gftoScanningFile sctipu_15xx.c
[+0:00:07.161] [52%] gftoScanningFile sct_15xx.c
[+0:00:07.162] [55%] gftoScanningFile sct_pwm_15xx.c
[+0:00:07.162] [58%] gftoScanningFile spi_15xx.c
[+0:00:07.162] [61%] gftoScanningFile stopwatch_15xx.c
[+0:00:07.163] [62%] gftoScanningFile swm_15xx.c
[+0:00:07.163] [65%] gftoScanningFile sysctl_15xx.c
[+0:00:07.163] [68%] gftoScanningFile sysinit_15xx.c
[+0:00:07.163] [71%] gftoScanningFile uart_15xx.c
[+0:00:07.164] [74%] gftoScanningFile wwdt_15xx.c
[+0:00:07.164] [77%] gftoScanningFile eeprom.c
[+0:00:07.164] [77%] gftoScanningFile iap.c
[+0:00:07.164] [80%] gftoScanningFile ring_buffer.c
[+0:00:07.165] [78%] gftoScanningFile rtc_ut.c
[+0:00:07.166] [79%] gftoScanningFile startup.c
[+0:00:07.166] [82%] gftoScanningFile original_cr_startup_lpc15xx.c
[+0:00:07.166] [84%] gftoScanningFile chip.h
[+0:00:07.166] [48%] gftoScanningFile stopwatch.h
[+0:00:07.167] [50%] gftoScanningFile eeprom.h
[+0:00:07.167] [51%] gftoScanningFile string.h
[+0:00:07.168] [48%] gftoScanningFile ring_buffer.h
[+0:00:07.168] [50%] gftoScanningFile rtc_ut.h
[+0:00:07.168] [50%] gftoScanningFile lpc_types.h
[+0:00:07.169] [50%] gftoScanningFile sys_config.h
[+0:00:07.169] [51%] gftoScanningFile cmsis.h
[+0:00:07.170] [51%] gftoScanningFile romapi_15xx.h
[+0:00:07.170] [47%] gftoScanningFile sysctl_15xx.h
[+0:00:07.171] [48%] gftoScanningFile clock_15xx.h
[+0:00:07.171] [50%] gftoScanningFile iocon_15xx.h
[+0:00:07.171] [51%] gftoScanningFile swm_15xx.h
[+0:00:07.172] [52%] gftoScanningFile pmu_15xx.h
[+0:00:07.172] [53%] gftoScanningFile crc_15xx.h
[+0:00:07.172] [54%] gftoScanningFile gpio_15xx.h
[+0:00:07.173] [55%] gftoScanningFile pinint_15xx.h
[+0:00:07.173] [56%] gftoScanningFile gpiogroup_15xx.h
[+0:00:07.173] [57%] gftoScanningFile uart_15xx.h
[+0:00:07.174] [58%] gftoScanningFile adc_15xx.h
[+0:00:07.174] [60%] gftoScanningFile mrt_15xx.h
[+0:00:07.175] [61%] gftoScanningFile ritimer_15xx.h
[+0:00:07.175] [62%] gftoScanningFile dma_15xx.h
[+0:00:07.176] [63%] gftoScanningFile usbd_15xx.h
[+0:00:07.176] [64%] gftoScanningFile sctipu_15xx.h
[+0:00:07.176] [65%] gftoScanningFile sct_15xx.h
[+0:00:07.176] [66%] gftoScanningFile sct_pwm_15xx.h
[+0:00:07.177] [67%] gftoScanningFile rtc_15xx.h
[+0:00:07.177] [68%] gftoScanningFile wwdt_15xx.h
[+0:00:07.177] [70%] gftoScanningFile fmc_15xx.h
[+0:00:07.178] [71%] gftoScanningFile inmux_15xx.h
[+0:00:07.178] [72%] gftoScanningFile acmp_15xx.h
[+0:00:07.178] [73%] gftoScanningFile dac_15xx.h
[+0:00:07.178] [74%] gftoScanningFile spi_15xx.h
[+0:00:07.179] [75%] gftoScanningFile i2cm_15xx.h
[+0:00:07.179] [75%] gftoScanningFile i2cs_15xx.h
[+0:00:07.179] [76%] gftoScanningFile _ansi.h
[+0:00:07.180] [76%] gftoScanningFile reent.h
[+0:00:07.180] [74%] gftoScanningFile cdefs.h
[+0:00:07.181] [74%] gftoScanningFile features.h
[+0:00:07.181] [75%] gftoScanningFile stddef.h
[+0:00:07.182] [75%] gftoScanningFile string.h
[+0:00:07.182] [76%] gftoScanningFile stdlib.h
[+0:00:07.182] [75%] gftoScanningFile time.h
[+0:00:07.183] [75%] gftoScanningFile stdint.h
[+0:00:07.183] [75%] gftoScanningFile stdbool.h
[+0:00:07.184] [76%] gftoScanningFile core_cm3.h
[+0:00:07.184] [75%] gftoScanningFile iap.h
[+0:00:07.185] [76%] gftoScanningFile error.h
[+0:00:07.185] [77%] gftoScanningFile rom_i2c_15xx.h
[+0:00:07.185] [78%] gftoScanningFile rom_pwr_15xx.h
[+0:00:07.185] [79%] gftoScanningFile rom_uart_15xx.h
[+0:00:07.186] [80%] gftoScanningFile rom_can_15xx.h
[+0:00:07.186] [81%] gftoScanningFile rom_dma_15xx.h
[+0:00:07.186] [82%] gftoScanningFile rom_spi_15xx.h
[+0:00:07.186] [83%] gftoScanningFile rom_adc_15xx.h
[+0:00:07.187] [84%] gftoScanningFile i2c_common_15xx.h
[+0:00:07.187] [85%] gftoScanningFile newlib.h
[+0:00:07.187] [85%] gftoScanningFile config.h
[+0:00:07.188] [86%] gftoScanningFile _types.h
[+0:00:07.188] [86%] gftoScanningFile types.h
[+0:00:07.189] [85%] gftoScanningFile custom_file.h
[+0:00:07.189] [86%] gftoScanningFile assert.h
[+0:00:07.189] [87%] gftoScanningFile _default_types.h
[+0:00:07.189] [87%] gftoScanningFile ansi.h
[+0:00:07.189] [88%] gftoScanningFile ieeefp.h
[+0:00:07.190] [89%] gftoScanningFile stdlib.h
[+0:00:07.190] [90%] gftoScanningFile alloca.h
[+0:00:07.190] [91%] gftoScanningFile time.h
[+0:00:07.190] [91%] gftoScanningFile signal.h
[+0:00:07.191] [92%] gftoScanningFile stdint-gcc.h
[+0:00:07.191] [92%] gftoScanningFile core_cminstr.h
[+0:00:07.191] [93%] gftoScanningFile core_cmfunc.h
[+0:00:07.192] [94%] gftoScanningFile _types.h
[+0:00:07.192] [95%] gftoScanningFile lock.h
[+0:00:07.192] [96%] gftoScanningFile types.h
[+0:00:07.192] [97%] gftoScanningFile sched.h
[+0:00:07.192] [98%] gftoScanningFile limits.h
[+0:00:07.193] [98%] gftoScanningFile signal.h
[+0:00:07.193] [99%] gftoScanningFile syslimits.h
[+0:00:07.194] [100%] gftoDone
[+0:00:07.564] Removing project wrapper for c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:07.672] Starting operation: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:07.672] Operation completed: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [0 msec]
[+0:00:07.797] Starting operation: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:07.813] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj: found 106 source files
[+0:00:07.897] Operation completed: Wrapping c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [99 msec]
[+0:00:07.897] [0%] gftoCheckingForModifications
[+0:00:07.909] [87%] gftoCheckingForModifications
[+0:00:07.910] [0%] gftoBypassed
[+0:00:44.754] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp belongs to a compatible project and will be handled by our engine
[+0:00:44.756] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp belongs to a compatible project and will be handled by our engine
[+0:00:44.757] c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp belongs to a compatible project and will be handled by our engine
[+0:00:44.811] Indentation size: 4, will insert spaces
[+0:00:45.017] Active document changed to c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp
[+0:00:45.030] Starting operation: Parse – Check
[+0:00:45.032] Starting operation: Reparsing c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp
[+0:00:45.173] Starting operation: Exporting parse results
[+0:00:45.182] Operation completed: Exporting parse results [8 msec]
[+0:00:45.182] Checked c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp: 0 error records
[+0:00:45.239] Operation completed: Reparsing c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp [207 msec]
[+0:00:45.239] Operation completed: Parse – Check [209 msec]
[+0:00:45.345] Starting operation: Parse – HighlightBraces
[+0:00:45.353] Operation completed: Parse – HighlightBraces [7 msec]
[+0:01:19.373] Starting operation: Reformatting text
[+0:01:19.417] Operation completed: Reformatting text [44 msec]
[+0:01:19.520] Starting operation: Parse – Check
[+0:01:19.520] Starting operation: Reparsing c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp
[+0:01:19.581] Starting operation: Exporting parse results
[+0:01:19.584] Operation completed: Exporting parse results [2 msec]
[+0:01:19.584] Checked c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp: 0 error records
[+0:01:19.584] Operation completed: Reparsing c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp [64 msec]
[+0:01:19.584] Operation completed: Parse – Check [64 msec]
[+0:01:19.595] Starting operation: Parse – HighlightBraces
[+0:01:19.596] Operation completed: Parse – HighlightBraces [0 msec]
[+0:01:35.619] Starting operation: Reformatting text
[+0:01:35.623] Operation completed: Reformatting text [4 msec]
[+0:01:35.630] Starting operation: Parse – Check
[+0:01:35.630] Starting operation: Reparsing c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp
[+0:01:35.689] Starting operation: Exporting parse results
[+0:01:35.691] Operation completed: Exporting parse results [2 msec]
[+0:01:35.691] Checked c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp: 0 error records
[+0:01:35.695] Operation completed: Reparsing c:\Users\matas\documents\EmbeddedProject3\EmbeddedProject3\LEDBlink.cpp [64 msec]
[+0:01:35.695] Operation completed: Parse – Check [65 msec]
[+0:01:35.704] Starting operation: Parse – HighlightBraces
[+0:01:35.704] Operation completed: Parse – HighlightBraces [0 msec]4. Now select “Convert to stand-alone project with “Copy all BSP” setting.
5. Click ok.
6. Restart visual studio.
7. Shows “Clan IntelliSense unloaded” And log:
[+0:00:00.000] Starting operation: Wrapping C:\Users\matas\Documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj
[+0:00:00.034] C:\Users\matas\Documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj: found 106 source files
[+0:00:00.038] Operation completed: Wrapping C:\Users\matas\Documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [35 msec]
[+0:00:00.039] Object reference not set to an instance of an object. while trying to extract project compiler arguments
[+0:00:00.039] Stack trace:
[+0:00:00.039] at xc1.j3.f_2()
[+0:00:00.039] at fj.BuildProfileForSupportedCppProject(Object c, String b, ICppLanguageService a)
[+0:00:00.039] at ao.i(Project a, IVsHierarchy b, List`1 c)-
This reply was modified 9 years, 9 months ago by
matas.
June 17, 2016 at 21:14 #8446support
Could you share a sample project that always causes the problem? We should be able to fix it easily then.
June 28, 2016 at 16:17 #8491matas
ParticipantJune 30, 2016 at 18:23 #8506support
Thanks, please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.5.904.msi
July 7, 2016 at 10:01 #8532matas
Sorry but same problem remains (using same project I sent you):
[+0:00:00.029] C:\Users\matas\Documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj: found 106 source files
[+0:00:00.032] Operation completed: Wrapping C:\Users\matas\Documents\EmbeddedProject3\EmbeddedProject3\EmbeddedProject3.vcxproj [29 msec]
[+0:00:00.032] Object reference not set to an instance of an object. while trying to extract project compiler arguments
[+0:00:00.032] Stack trace:
[+0:00:00.032] at er1.q3.c1()
[+0:00:00.032] at hl1.BuildProfileForSupportedCppProject(Object a, String c, ICppLanguageService b)
[+0:00:00.032] at d61.l(Project a, IVsHierarchy b, List`1 c)July 9, 2016 at 04:54 #8549support
We are sorry about this bug. To diagnose it quickly we have added extra error logging to this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.5.916.msi
Could you please try it and let us know if the problem still persists and what error message is shown if it does?
July 18, 2016 at 17:24 #8621matas
ParticipantSorry, but link doesn’t work.
P.S. can I somehow subscribe to this forum topic so that I could instantly see once you reply?
July 18, 2016 at 17:58 #8624support
KeymasterSorry, we have disabled the subscription system because somehow spammers were trying to subscribe random addresses there causing us trouble. You can just create a ticket in our support form and we will reply there each time we post a reply here.
The fix is now included in the VisualGDB 5.2 Preview 1: http://visualgdb.com/download/
The new build should add more logging to the Clang IntelliSense Diagnostics Console, so it should show more than just “Object reference not set to an instance of an object”. Could you please double-check the new diagnostics output and let us know if you see anything additional there?
This reply was modified 9 years, 8 months ago by
July 19, 2016 at 13:13 #8643matas
ParticipantHi, thanks for quick reply. Unfortunately, similar error happens. I also tried to re-create project from scratch (as I posted previously in #post-8441).
Here is the project: https://drive.google.com/file/d/0Bym5DDX6haPmc3NRZTJXcVlxT1U
And error message:
[+0:00:00.000] Starting operation: Wrapping C:\Users\matas\Documents\EmbeddedProject4\EmbeddedProject4\EmbeddedProject4.vcxproj
[+0:00:00.052] C:\Users\matas\Documents\EmbeddedProject4\EmbeddedProject4\EmbeddedProject4.vcxproj: found 106 source files
[+0:00:00.055] Operation completed: Wrapping C:\Users\matas\Documents\EmbeddedProject4\EmbeddedProject4\EmbeddedProject4.vcxproj [53 msec]
[+0:00:00.055] VSProjectWrapper: _Instance not set while trying to extract project compiler arguments
[+0:00:00.055] Stack trace:
[+0:00:00.055] at k91.r1.t_2()
[+0:00:00.055] at uh1.BuildProfileForSupportedCppProject(Object c, String a, ICppLanguageService b)
[+0:00:00.055] at tu.f1(Project b, IVsHierarchy c, List`1 a)July 19, 2016 at 19:08 #8651support
It looks like VisualGDB is not getting initialized properly. Does this happen when you open the project from command line, or also when you close the solution and open it again?
August 3, 2016 at 13:24 #8736matas
Sorry, but I can’t understand why you ask these questions after I provided you all project files where you can easily see for yourself. This error occurs not only on my machine.
Matas
