CI/CD CMD line issue
Sysprogs forums › Forums › VisualGDB › CI/CD CMD line issue
  • #26423
    Markg
    Hello All,
    We are setting up our CI/CD system. Im currently creating an example project to use and demonstrate, but now i’m having a small issue.
    Using the command line im building our project. This is the command:
    D:\git_repo\cicd_test_project\CICD_Test>"C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe" /build "CICD_Test.vcxproj" "CICD_Test.sln" "/config:Debug" "/platform:Win32" VISUALGDB_VERBOSE_OUTPUT=1
    The .bin and .ihex are created correctly. But at the bottom im getting a error:
    ------------------- Memory utilization report -------------------
    Used FLASH: 3128 bytes out of 256KB (1%)
    Used RAM: 52 bytes out of 31KB (0%)
    VisualGDB: Warning: Project/solution/configuration not specified in command line. Your Makefiles will not be auto-updated. Please go to VisualGDBProject Properties and click 'repair command lines'.
    VisualGDB: Warning: No configuration specified, defaulting to 'Debug'. Use '/config:<name>' to override.
    Build/launch failed: Data at the root level is invalid. Line 2, position 1.
    As far as I know the verbose output is the same as when I do a build via visual studio. Do you guys have any ideas?
    #26427
    Looks like you have skipped the “/solution:” prefix before the solution file. Please double-check the command line shown when building the project in Visual Studio and ensure it 100% matches the command line in the CI setup.
    #26438
    Markg
    Thx for the info, I indeed forgot the solution part 🙂
    THis commands works:
    "C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe" /clean CICD_Test.vcxproj /solution:CICD_Test.sln /config:Debug /platform:Win32
