Changing Visual GDB build variables
Sysprogs forums Forums VisualGDB Changing Visual GDB build variables
  • This topic has 1 reply, 2 voices, and was last updated 12 years ago by ket.
  • #752
    dvdevore
    Is it possible to override a few of the Visual GDB build variables? …such as:
    $(TargetExtension)
    $(TargetPath)
    $(TargetDir)
    I need to change TargetPath/TargetDir so that the library or exe is copied to another bin directory, which can probably be accomplished through a custom build step…but I would like to know anyways how I go about overriding these build variables.
    Thanks!
    #2990
    ket
    VisualGDB build variables are usually derived from the project settings or our generated Makefile.
    For Linux projects the Target-related build variables are derived from the BuildDir variable and TARGETNAME and BINARYDIR from the makefiles. If you change these variables in the makefiles then the library/executable will be built into a different directory under a different name.
