Sysprogs forums › Forums › VisualGDB › Change path of PICO SDK
- This topic has 5 replies, 3 voices, and was last updated 5 years, 5 months ago by
shabtronic.
April 22, 2021 at 08:59 #30385
Reneg973
ParticipantWhen installing the PICO SDK, it is automatically cloned to %APPDATA%/Local/VisualGDB/PicoSDK/…
Now when compiling I get the following error: “…/pico.h; No such file or directory”. I can locate the header there. So I assume it appears because my APPDATA path is UNICODE. I would like to move it to a different folder. How can I tell VisualGDB, where the new folder is?
April 22, 2021 at 12:41 #30387Reneg973
ParticipantI could fix it by creating a symlink and modifying the file “config_autogen.h” to use the symlink path
April 23, 2021 at 12:21 #30391support
You can simply move the directory manually and then import it into VisualGDB by clicking “Install Raspberry Pi Pico SDK” in the SDK selector (in the wizard or VisualGDB Project Properties) and pointing VisualGDB to the new location of the SDK.
April 24, 2021 at 08:44 #30393shabtronic
ParticipantHey I get the very same problem.
The first time I create a pico project with the wizard, Everything works just fine – I can run and debug it.
The second time I try to run/debug it I get this error:
Severity Description Project File Line
Error FindFirstFileExA(d/:/thevault/pico/picosdk/1.1.0-package/src/common/pico_stdlib/include/pico): The filename, directory name, or volume label syntax is incorrect. Blink2 D:\TheVault\Pico\MyProjects\Blink2\build\VisualGDB\Debug\ninja 0and the build log gives me this:
C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe
ninja: error: FindFirstFileExA(d/:/thevault/pico/picosdk/1.1.0-package/src/common/pico_stdlib/include/pico): The filename, directory name, or volume label syntax is incorrect.————————————————————-
Command exited with code 1
Executable: C:\PROGRA~2\Sysprogs\VISUAL~1/ninja.exe
Arguments:
Directory: D:\TheVault\Pico\MyProjects\Blink2/build/VisualGDB/Debug
Command-line action failed========== Project Build Summary ==========
Blink2 built in 00:00
========== Build: 0 Succeeded, 1 Failed, 0 Skipped ==========If i switch to release mode for the first time – it compiles and runs fine, the second time tho I get the same issue!
looks like a issue with “d/:/the” part of the file name?
I’ve tried to mess about with ninja files.e.t.c. – but honestly I don’t know what I’m doing
I would be great to be able to get this working – I’d be able to debug stuff 🙂 hahah
This reply was modified 5 years, 5 months ago by
shabtronic.
April 24, 2021 at 09:13 #30395support
It looks like you are using a toolchain that outputs dependency files in a format incompatible with Ninja. Please try using our latest ARM toolchain instead and it will work out-of-the-box.
April 24, 2021 at 09:17 #30396shabtronic
ParticipantHey thanks for your reply!
ok I will try that.
Yes I pointed at my old arm toolchain – that I setup by hand – so yeah it’s probably in a right old state.
As you suggest, I will use the pico wizard to install your arm toolchain – and see what happens.
Hope it works – because so far visualGDB is superb ( apart from the compile issue).
esp loving the Embedded memory explorer!
[Edit] I tried your toolchain link – and it all works fantastically now – so happy – thank you!
I’ll post back when I get it working!
shabtronic.
