I downloaded the software from your website. Installed it on my windows 8 laptop, but it wouldn’t show up on my desktop. I went to the file location and tried opening it from there. But each time I do it brings up the prompt to install.
No matter how many times I reinstall it, it always does the same thing.
Most likely you did not download the full version of the program. I had a similar situation with an application that did not start. The complete removal of the application and the new installation helped. Try it, maybe it will solve your problem.
Most likely you did not download the full version of the program. I had a similar situation with another application that did not start. The complete removal of the application and the new installation helped. Try it, maybe it will solve your problem.
If the problem is not solved, I recommend writing to technical support.
This reply was modified 5 years, 4 months ago by AidenJeffries.
